03-04-2016, 01:49 PM | #23 |
Rep 131
Ouch! That sucks. Glad they fixed it, but that inconvenience of having to bring it back would upset me a little because you know they had to have noticed it when it crackled and popped under the weight of the car.
03-07-2016, 08:05 PM | #24 | |
Rep 1,056
03-08-2016, 10:19 AM | #25 |
Rep 131
03-17-2016, 10:02 PM | #26 | |
2006 TIME Person Of The Year
9720
Rep 6,445
03-18-2016, 10:24 AM | #27 |
Rep 131
05-29-2016, 10:59 AM | #28 |
Rep 749
Drives: 2016 528i Executive Edition
So for those lowered cars, it would be a good idea to use ramps (purchased or homemade) to get the car up a bit so that the jack can get under the car to reach the central jacking point.
I do not have ramps. So would this method also be fine? I would think if I have 2 Jack's, could I use one jack at one of the front corner jack points to lift the car a up a few inches, or just enough to get the second jack under the front central jack point? Then from there, Jack the car up further, remove the jack on the corner and then put jack stands under the two front corner jack points? Thoughts? |
05-29-2016, 02:59 PM | #29 | |
Curmudgeon and Pedant
690
Rep 3,489
I've used the two jack method quite a bit. Lift one corner (I used a floor jack) then put a stand under that corner, then move to the other corner and do the same. |
05-29-2016, 05:24 PM | #30 | |
Rep 749
I'm new to this and I've been doing my wheel changes simply using a floor jack at the front corner, jacking it up just high enough that both wheels on the same side are off the ground, swap the wheels, and then lower. I do throw a spare tire under the car though as a partial safety precaution. The more I'm reading the more I'm realizing that although I've not had any issues doing it this way thus far, I'm best to start doing this properly and more safely. I just need to figure out how best to do it. I've seen the homemade ramps people have made with the 2 x 6's and that's something I can make too in order to get the front up high enough to get the jack to reach the front centre jack point. But I'd rather not waste time doing that if I can simply use a jack to lift the car just enough to reach that front central jack point. Or would it be dangerous to try and start jacking the car up from that front centre jack point with the car not level due to the one side of the car being jacked up? More I'm thinking about it, the more it does seem kind of dangerous this way. Maybe I'll just make the ramps and call it a day. |
05-29-2016, 07:25 PM | #31 | |
690
Rep 3,489
I then place the jack stand underneath the suspension, usually where the control arms attach to the body - super solid place. You can just buy regular ramps, and a single 2x6 cut into 4 pieces to extend the ramp by 18" or so. (You don't need to create a complete 1' high ramp with wood.) |
05-30-2016, 01:25 AM | #32 | |
Rep 749
Unfortunately I'm not exactly sure which location you are referring to when you say control arm attached to the body. But I'm in the shop doing an oil change so I'll confirm with the tech where it would be safe to use the jack stand as you have described. Thanks! |
05-30-2016, 10:36 AM | #33 | |
690
Rep 3,489
http://www.realoem.com/bmw/enUS/show...diagId=31_0715 |
05-30-2016, 02:57 PM | #34 | |
Rep 749
For the back, I figure I could simply jack up at the diff, and then put the two jack stands on the actual jack points in front of the rear wheels. But I've included a couple pictures of the back as well. Could you circle the section you place the jack stand? (First 2 pictures) For the front though, I'm not so sure. Do you think you can also circle the areas where I could place the jack stand in the front if I'm jacking the car up from the front jack point? Also, if I were to use the front central jack point, where would I place the floor jack? (Last 3 pictures) Thanks in advance! |
06-01-2016, 08:29 PM | #35 |
Rep 1,503
Is it truly safe to jack up the rear from the diff on these cars? I've read so much conflicting information
FBO M235i r
F80 M3 |
06-02-2016, 07:42 AM | #36 | ||
Rep 3,947
Also, not all lifts can accommodate the position of the jack points on the outer edges of these cars. Those pucks come in handy in this case when you find that you have to rest the car on some portion of the lift arms instead of the jack pads of the lift. Quote:
I'm not sure if it's truly safe to jack up the rear from the diff. The diff was the rear jacking point for my 2008 Subaru Legacy GT. I would imagine that rear subframe part right behind (and above) the diff would be jack-worthy. It just might be hard getting a jack to that location. |
06-02-2016, 03:17 PM | #37 |
Rep 749
Can anyone point out the central jack point for the front of the car in one of the images above?
06-03-2016, 11:16 AM | #38 |
Rep 15
Drives: 2014 335i xdrive 8at
photo 9 in link for a front central jacking point
http://f30.bimmerpost.com/forums/sho...8#post17636768
Sort of like Mark Twain’s story…when he was fifteen he was surprised that his father had been able to live so long, considering how little he knew.
06-03-2016, 04:04 PM | #39 |
Rep 749
Thanks tempest.hazard!
For others, it appears this circled part is an acceptable central jack point. I guess I'll use a block of wood as a buffer for this as well. Thanks! |
09-04-2016, 07:35 PM | #40 | |
SQUEAKY
104
Rep 322
