01-07-2018, 12:10 PM | #23 |
Rep 160
I had to deal with this kind of problems, a lot.
It could be a user error like leaving the car unlocked with some accessory running, you know, genuine power draw. Or, it could be a problem with the car's battery management. I had a lot of issues with my 2013 (battery, battery charging module, ECU) and zero problems wuth my 2017. Even in the really cold weather I have not seen once the battery drain warning. So as I said, unless you did something to drain the battery, it's likely the car's fault.
Current: 2017 330i xDrive M Sport
Past: 2013 328i xDrive, 2008 335XI 6MT, Legacy SPEC.B, MazdaSpeed6(best of all) Last edited by Bassthe1st; 01-07-2018 at 06:56 PM.. |
01-07-2018, 04:09 PM | #24 |
Rep 16,143
There's always some accessories running. You might think that the car is 'off', but it's never totally off. Between that and the greatly decreased ability of a battery to hold charge in very cold weather a battery maintainer should not be considered an optional device, it should be considered mandatory.
01-07-2018, 05:47 PM | #25 |
Rep 718
Got the same warning this morning after the car sat for 3 days in near zero temps. Drove it for about 40 minutes with no accessories on. The warning went away.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
04-19-2020, 08:16 PM | #26 |
Rep 1,170
I know this is a very old thread but did anyone find the solution to this I am having similar problems but I don't seem to figure it out
bmw m2
04-20-2020, 03:45 AM | #27 |
Rep 418
For me, it was the comfort access. One of the door handle sensors was faulty. It believed it was being touched, so was in a constant state of readiness to start the car. Therefore, after just a few days, the battery was flat. Repaired under warranty, problem solved. Car could be left for up to 4 weeks without use and would start without issue. But it happened again to a different handle less than 3 months later. Just more reasons to have the damned feature disabled permanently.
04-20-2020, 04:04 AM | #28 |
Rep 22
This happened to me as well with a week old car..let me know what exactly the issue is..
advrider651070.50 |
04-20-2020, 11:36 AM | #29 | |
Rep 1,170
or maybe like disconnect a fuse and see if the problem goes away? i keep getting two codes witch are B7F67B COMBI:wake-up line status faulty (hardware line) 804086 driver KL15WUP: short circuit battery voltage
bmw m2
04-20-2020, 11:40 AM | #30 |
Rep 1,170
have you been able to figure it out?
bmw m2
01-30-2021, 01:34 PM | #31 |
Rep 47
I got the exactly same message last week, I'm in Canada so the tempreture dropped to -20c last week or so. Could be just the sensor from bmw doesn't like the sudden tempreture change…but I'm taking my car back to dealer next week to figure out what is going on.
Current: 2017 M3 DCT MGM on Silverstone leather
2018 340i xDrive M Performance Edition 1/200 - Sold 2014 Jaguar XFR 5.0 Supercharged - Sold 2014 Audi S4, Supercharged V6 Stage 2+ tune - Sold 2015 C63 (W204) 507 Edition Coupe - Sold |
03-08-2021, 08:15 PM | #34 |
Rep 131
This problem is driving me nuts. Currently have a 1 amp discharge pretty much no matter what I do. No faults seem to drive me in any direction. I have let the car "sleep" for 10ish minutes with all of the fuses removed from the FEM and rear distribution box to include the red heavy gauge input lines and still sitting at one volt. I separately pulled every fuse out of the front electronic module and still had around a 1 amp draw.. I have also pulled the instrument cluster out and still same 1 amp draw. It's been awhile since i had to code so I am researching the LIN troubleshooting next but after that I don't know what to do next. Any troubleshooting tips would be appreciated.
03-15-2021, 10:36 AM | #36 |
Rep 233
But the car starts!!!
I've been getting this warning as well with a six year old battery and cold winter mornings. Considering that none of the people who have written replies have had a no-start problem, I'm not gonna give it much concern.
I was planning a new batt for this year anyway. And I carry a jump start pack just in case. I do really appreciate all the input that people have provided here to give me some peace of mind on the subject. I was starting to get worried! Feel better now...
2015 Mineral White 335xi Sport trim
03-18-2022, 08:15 AM | #37 | |
Rep 2
Drives: Bmw 340i (2016), Bmw M3 (1995)
I have this same problem, I have went through about 3 batteries within 3 months. if the car is not started within a week or two it will drop to about 4 volts and cannot be charged and the longer the battery stays on the shorter the window gets, for example just had one on for about 3 months and the car went two days without being started and it dropped to 4 volts. I have a go fast bits boost gauge and snow performance meth gauge on the car but they are both wired in to the fuse box and have fuse taps to turn off when the car is off and on when it is on, could one of those be what is draining the battery? |
03-18-2022, 08:41 AM | #38 | |
Rep 4,906
03-18-2022, 10:41 AM | #39 |
Rep 16,143
If you're turning them off they can't drain the battery, but something is. You need to use a clamp style current meter to find it, testing every wire.
