Extreme Power House
      01-14-2018, 03:32 PM   #12871
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by Moonstone71 View Post
Hi Shawn,*
Can you please send me the link to the latest program and data files too ?*
Thanks in advance.
Cheers Tim
Originally Posted by D_D View Post
Hi Shawn,
can you send me the latest ESYS and psdzdata?
thanks!
PM's sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-14-2018, 05:20 PM   #12872
dynamik
Drives: 2016 340i xDrive
Can a fellow forum member please send me the link to the latest program and data files?
Thank you in advance!
      01-14-2018, 05:29 PM   #12873
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
Anyone have the code handy for unlock on engine stop?
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      01-14-2018, 05:32 PM   #12874
shawnsheridan
PM sent.
      01-14-2018, 06:02 PM   #12875
dynamik
PM sent.
Thanks Shawn.
Requested Launcher PRO 3.x.
      01-15-2018, 03:58 AM   #12876
pikuko
Drives: 128I
Shawn,
Could you send me the lastest files for coding while I get a response from token master.
      01-15-2018, 08:34 AM   #12877
shawnsheridan
Originally Posted by pikuko View Post
Shawn,
PM sent.
      Yesterday, 02:57 PM   #12878
LIVY435IGC
Drives: 2015 435i Gran Coupe
How do I find the default settings for AC system for turning on when car is started.
I can't find that anywhere. Currently the car won't turn off the ac upon start. After a few minutes, the AC button will flash and that point the air can be turned off. Also, the MAX AC button does not do anything anymore.
      Yesterday, 03:04 PM   #12879
Almaretto
Almaretto's Avatar
Drives: Coded '16 F10/F15 MSport
IHKA module
      Yesterday, 03:28 PM   #12880
LIVY435IGC
Originally Posted by Almaretto View Post
IHKA module
So the only 2 are
3002- Memory_Off nicht-aktiv
3003 - MEMORY_UMLUFT nicht_aktiv
When using bimmercode, there were 3 options
AC on with auto : Default for this?
AC Memory: Default for this?
AC circulation setting memory: Default for this?
Thanks for the quick response!
      Yesterday, 03:55 PM   #12881
Almaretto
Almaretto's Avatar
So the only 2 are
It depends on vehicle. G-series has more active.
Usually, MEMORY_UMLUFT and MEMORY_OFF are set to nicht_aktiv from factory. AC_ON_WITH_AUTO to aktiv.
You can set them however you want depending on desired behavior.
      Yesterday, 05:09 PM   #12882
LIVY435IGC
So I went back and changed the Standard mode on Bimmercode to the default and in expert mode.
Upon changing the Air Condition Memory : it looks as the simple and expert are in conflict. When I change in expert, the opposite results in simple and vice versa.
End result is that AC won't turn off, MAX AC is not functioning
Thoughts on what i should do next?
      Yesterday, 05:16 PM   #12883
Almaretto
Almaretto's Avatar
After coding HVAC, sometimes car must idle at low rpm for 10 minutes before it works again.
      Yesterday, 05:23 PM   #12884
LIVY435IGC
Thanks, Ill give that a shot. Hopefully that clears up my issue.
      Yesterday, 07:31 PM   #12885
Nupe1911
Drives: 2014 F10 535i
Can you please email the link to the latest program and data files?
Thanks!
      Yesterday, 07:36 PM   #12886
shawnsheridan
Thanks!
PM sent.
      Yesterday, 08:07 PM   #12887
LIVY435IGC
I think the 10 minute did the trick. Still can't get the Max AC to work thou
