10-22-2017, 06:56 PM | #23 | |
Rep 4,325
http://f30.bimmerpost.com/forums/sho...d.php?t=745349 Last edited by alohasurftoad; 10-22-2017 at 07:10 PM.. |
10-22-2017, 07:18 PM | #24 |
Rep 81
Drives: 2018 BMW 440i F32 Coupe 6MT
Mine is F32 2018 440i
10-22-2017, 09:35 PM | #25 |
Rep 4,325
it is 72.56. you can get larger than 72.56 if you desire but then you may need hubcentric rings.
if you think it's 72.6 and feel safer getting it then i'm not going to try and convince you it's 72.56, haha EDIT, my bad, maybe you're correct... https://www.wheel-size.com/size/bmw/...trim-440i-eudm not sure if they are rounding 72.56 to 72.6 or not, though. many peeps here use apex wheels which are 72.56 personally i'd get 72.56 but if you're more comfortable with 72.6 that's cool. Last edited by alohasurftoad; 10-22-2017 at 09:54 PM.. |
10-23-2017, 12:34 AM | #26 |
Rep 81
I saw it on the same site and that was my only source. It seems like the site is saying that F30 is also 72.6. So you could actually be right that they're rounding it up. Maybe I'll go to 1010 again to see if they're willing to let me try to put the Konig on to see if it fits.
My second option is the Enkei M52 http://www.1010tires.com/Wheels/Enke...ed/Matte+Black |
10-23-2017, 10:17 AM | #27 |
Rep 4,325
http://www.1010tires.com/Wheels/Fast...bboremax=73.00
too bad these are sold out... http://www.1010tires.com/Wheels/Fast...bboremax=73.00 2nd thought, maybe you should consider DAI or Replika, at least they (437M knock-offs) look good. Last edited by alohasurftoad; 10-23-2017 at 10:24 AM.. |
10-24-2017, 01:37 AM | #28 |
Rep 81
10-24-2017, 02:52 AM | #29 |
Rep 4,325
I don't know if its poor...There's not much info when I search about DAI or replika. The listed ones, I have heard of before but they may not necessarily be good. My recommendations are from online information. I'd definitely be bummed if you chose something I recommend and it didn't work out.
FAST wheels seem to be decent Last edited by alohasurftoad; 10-24-2017 at 03:51 AM.. |
10-24-2017, 03:59 AM | #30 |
Rep 81
I think those 2 are just gravity cast. The saleperson at 1010 actually recommended me those 2 brands as well as Riva, which is rimalloycanada, made in China. Replika is made in Canada. He said as long as I'm not buying some random replica from eBay then I should be fine. Picking winter wheel is just part of it. I also wanted to learn more about their construction since there are too much mixed information.
10-25-2017, 01:16 PM | #31 | |
Rep 7,047
Good info, thanks. Here is a good site that gives good and short explanation of casting and forging in general. http://www.atcgroup.com.au/CustomCas...ngForging.aspx |
kokoli8428.00 |
10-25-2017, 01:26 PM | #32 | |
Rep 7,047
There are recommendations on tire age, mounted and never mounted. I've read to not mount tires that have reached 5-6 years of age from the date of manufacture and have never been mounted. There is also suggestion to replace tires that are 6 years old from date of manufacture, while in use/mounted. And, there is also recommendation to replace tires that are 10 years old from date of manufacture, also while in use/mounted. TireRack.com has information on this as well. Here: https://www.tirerack.com/tires/tiret...sp?techid=184& If the tires are nearing 5-6 years of age, I would set their value/price quite low even if they don't have much mileage wear. The reason is their compound life. If a 60K mile wear tire has only 10K miles of wear, but it's also 6 years old, then the compound may well expire before the mileage wear the tread. It's your call of course, but if I were buying I would want new tires if the mounted tires are 6+ years old. So, for me 6+ year old tires, even with a good amount of tread, would be worthless as I wouldn't want to use them. Tires are the ONLY thing that keeps a vehicle on the road. For me, tires are not an area where going cheap makes sense. I'd buy lower cost wheels, but not low cost, specifically "cheap", tires. Last edited by RPM90; 10-25-2017 at 01:33 PM.. |
10-25-2017, 02:05 PM | #33 | |
Rep 2,639
I have a set of 18s used for winters and they are pretty damn light, and look pretty good. Not too expensive too, I bought a set of 18x9 ET30 for 900$.
10-26-2017, 07:37 PM | #34 | |
Rep 81
1. $1835.92 225/45/18 XL 95V 2. $1859.92 225/45/18 95H Seems like #1 is a better choice base on the price, speed rate, and XL. I just don't understand why the better one is cheaper than the one without XL and slower speed rate |
10-26-2017, 07:38 PM | #35 |
Rep 81
That was one of my top pick but they don't have them in stock anymore for the size that I need, which is 18x8 ET35
10-30-2017, 01:53 PM | #36 |
Rep 1,710
I just installed a pair of aftermarket winter rims and tires for the first time. I was driving home on the new wheels and the tire pressure light came on. But then later the traction control light started flashing and killed the power briefly. The car is not liking the new wheels I'm assuming. Just wondering if this has happened to anyone else?
11-27-2017, 09:50 PM | #37 |
Rep 81
Thanks guys for all your inputs. I finally got my Enkei M52 installed with SottoZero 3. M52 is not my first choice but all the other ones that you guys suggested are sold out. I guess I'll have to live with hat for now.
