08-13-2015, 09:12 PM | #1 |
Rep 498
USB port charging problem with iPhone 6
I notice that when my iPhone 6 is low on battery (eg. <5%), even if I have it plugged into the USB port in the arm rest, the battery will still drain down. This doesn't happen when the iPhone is at say 20-% or higher.
My guess is that the phone draws more amperage/charge when it's low on power and I also have background apps running which adds to the problem. However it's crazy that the USB port in a 2025 car cannot accommodate this. My other guess is that the armrest USB port is 1A whereas the iPhone 6 and 6 plus can charge at 2A. Anyone else notice this problem? I could fix this by getting a cigarette lighter USB charger with higher amperage but then I lose USB connectivity to idrive which I use daily for spotify control. Any ideas? |
08-17-2015, 05:41 AM | #2 |
Rep 3,288
I gave up charging on that port and put a plug-in charger in the power outlet in front of the drink holders. A friend uses his USB port for charging and didn't get why I was having a problem. It appears that his Enhanced USB is higher power than my basic USB. He can run 2.5" HDD's for music off of his and I can't off of mine, too.
08-17-2015, 08:47 AM | #3 |
Schmollbraten
12512
Rep 1,985
Ahem...my manual says clearly DO NOT USE THE USB OUTLET FOR CHARGING. Maybe the voltage output is beyond the detection border of cellphones, dunno. Use the cigarette lighter port w/adaptor into the fwd console.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
08-17-2015, 10:28 AM | #5 | |
Rep 498
I can't believe a 2915 car over $25k who of ever include a data only USB port. Makes zero sense. If the enhanced USB option equips the car with higher powered USB ports then that is a reason to get that $500 feature. |
09-01-2015, 12:23 PM | #6 |
Rep 1,127
USB ports are limited to 500ma by the spec, they 1/2 A ports are detected by the device when the data pins are shorted. You can buy charging cables with the data shorted out, that might help, but then no data between car and phone.
Not sure about iphone but the Androids will tell you if it's changing via USB (500ma) or AC (1/2A) |
09-01-2015, 01:53 PM | #7 | |
Rep 41
http://www.amazon.com/Certified-iXCC...9WRWAMYVGTB0EW
2014 428i XDrive EBII - M-Sport, Premium, Driver Assistance, Cold, Lighting, Nav, Black Kidney Grills /// Current
BMS Stage 1, Roof Wrap /// Future Mods |
09-21-2015, 11:56 AM | #8 |
Rep 24
Drives: F30 - 318d - Red
Hmmm, that's dumb of BMW ... Most smartphones will start charging anyway once they're connected to a USB port ... I hope that my 2016 car will not have this issue ...
09-21-2015, 11:52 PM | #9 |
Rep 942
Mine works just fine, must be 2A as it will even charge an iPad. 2014 car, pro nav, don't have EBT but coded it in.
2016 F80 M3
09-23-2015, 11:10 AM | #10 |
Rep 24
Thanks for the info RalphyBMW
You've made my day
