07-20-2016, 02:13 PM | #45 | |
Rep 1,349
Drives: BMW F80 M3
07-20-2016, 02:44 PM | #46 | |
Rep 4,323
I ended up doing a Dinan Stage 1, which is essentially the same, but allowed me to use a dealer to do the install (which ironically saved me a lot of money). Once tuning is sorted out (and hopefully install is ok), I'll see if I can post numbers. Direction I was given was Enzo BEF + JB4. I suspect there are tuners that will eventually be able to control boost entirely through a BEF, but for now, this is all I have, and I need something.
07-20-2016, 04:35 PM | #47 | ||
Rep 1,782
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
07-21-2016, 02:20 AM | #48 |
Rep 181
We will be running 18psi with pump gas (94 octane here). Enzo estimates 450-480 at crank, wish seems ambitious.. Will be booking AWD dyno once car is ready (it's xDrive).
07-21-2016, 02:25 AM | #49 |
Rep 181
UPDATED - July 20, 2016
Update! ECU en route to be delivered today. Part installation started on car yesterday. Hopefully she will be ready in coming days! Shout out to Enzo Performance in NY. Amazing, fast and responsive service!
07-21-2016, 10:22 AM | #50 | |
Rep 4,323
The stage 1 tune is <<<<<< Enzo's 400R for sure, and much less than the Enzo 400R+ JB4.
07-21-2016, 10:27 AM | #51 | ||
Rep 1,782
07-22-2016, 08:53 AM | #52 | |
Rep 1,127
View post on imgur.com |
07-22-2016, 02:30 PM | #53 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
PM sent
FBO-PS1 and stuff
07-22-2016, 04:23 PM | #54 | ||
Rep 4,323
07-22-2016, 07:19 PM | #55 |
Rep 181
UPDATED - July 22, 2016 - Need Help!
Any feedback/ideas would be appreciated! Need help. Posted JB4 logs on:
http://www.n54tech.com/forums/showthread.php?p=485485 MAP 0, we did our first run, idles just fine at first and no codes at startup, but at WOT very little power and goes into limp-mode right away, misfires codes, then starts shaking at idle around 1K RPM until you turn off. Restart engine, idles just fine, until WOT again. At first it was cylinder 2, so we switched the spark-plug with cylinder 1 and then code was in cylinder 1. We then got a replacement plug and now it's saying cylinder 2 again. I did some searching and some people say plugs, or coils, or DP/intake sensors were connected wrong. Not sure where to start. Attached are logs and screenshot of codes. Any idea where to start? |
07-22-2016, 08:43 PM | #56 |
Rep 1,127
datapoint: my tuner/shop asked to put in M3 plugs as part of the install of a stage 2.
Also looking at your n54 thread you are setting the boost to 20 psi ? That is quite high for 91 octane no? I think misfires with the stock fueling and high boost are a bit of an unspoken issue amoung the tuners. Last edited by zinner; 07-22-2016 at 08:49 PM.. |
07-22-2016, 09:33 PM | #57 | |
Rep 181
07-22-2016, 09:38 PM | #58 | |
Dream crusher
984
Rep 2,421
- plugs - coils - injectors - walnut blast All of the above is contingent on miles on vehicle. If you feel it's an octane problem and timing is too advanced just boost the octane with some e85 mix or classic over the counter MMT. Some 76 gas stations sell 100oct. My spark plugs were best kept stock and tapped down.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-23-2016, 12:56 PM | #59 | |
Rep 181
Anyway to tell from logs if JB4 (or intake/DP sensors) are connected properly?? |
07-23-2016, 10:09 PM | #60 |
Rep 4,323
Has your fuel pressure regulator been checked? I wonder if that's causing the issue.
Doesn't throw a code, you need to let a dealer probe to find out. 18psi seems like a lot too, my stack+flash is max at 16psi (see below)
07-23-2016, 10:29 PM | #61 |
Rep 1,782
My JB4 on map 7 is 18 PSI. Granted I dont run it often maybe every 2 tanks of fuel but that is only for a few days until the e85 range goes to 0 lol
07-24-2016, 02:36 PM | #62 |
Rep 1,349
Drives: BMW F80 M3
Checked your log on N54tech. Your HPFP is reason for the misfires. From the FP_H in the log it seems it's crashing. It should be 10+ preferably more. On EWG I have not often seen it go below 15.
Your AFR is lean (normal for EWG), boost is low and yet you still get misfires. I would say a hardware issue. I suggest if you can go back stock flash easily do that first. Now that I think of it JB4 does not log all data on map0. Maybe try a log on map4 and we get a better view. But I think with the change to OBD on map0 it also displays a lot of data. Either flash side or hardware issue with HPFP or LPFP that feeds the HPFP. |
07-24-2016, 04:21 PM | #63 | |
Rep 181
07-24-2016, 04:33 PM | #64 | ||
Rep 1,349
Drives: BMW F80 M3
07-25-2016, 02:30 PM | #65 |
Rep 181
Update - July 25
Update! Thank you for all your feedback, but still need help. Please see updated logs here:
http://www.n54tech.com/forums/showthread.php?p=485491 - We changed all the plugs back to stock, no more misfires or error codes! The plugs that were recommended (NGK LKAR8A-9) cracked, so I think these are the wrong plugs for the car. Any feedback on what plugs we should be using? - Ordered the EWG connector cable for the JB4, should be here in a couple of days. - Did another run on MAP0 - No errors, but also no log readings on "FF" parameter. The FF connector was not connected properly, so we moved it to the fuel rails and cleared the codes. - Did two more runs, on MAP0, one on MAP2. No misfires or errors, but car feels slower than stock. I still suspect the JB4 isn't connected properly. Any feedback based on new logs? - Confirmed with Enzo that bench flash without JB4 (or just MAP0) will run stock boost level. JB4 needed to increase boost. |
07-25-2016, 05:35 PM | #66 | |
Rep 1,782
