03-09-2018, 04:33 PM | #45 | |
Rep 231
I might go for the grey ones then instead or try an alternate, Veemann do a similar one in the fs range the fs19 ?? Looks very similar except it lacks the step inside the wheel. |
03-09-2018, 05:53 PM | #46 | |
Rep 2,029
03-09-2018, 05:55 PM | #47 |
Rep 2,598
03-09-2018, 06:37 PM | #49 |
Occasional Lurker
190
Rep 589
Always thought they looked darker
Current: F87 M2 Competition
Gone: F36 420D M Sport, F30 Tanzanite M-sport, E90 lci Bluewater M-sport, E90 Le mans M-sport, E46 lci 320d SE Topaz blue, E36 318d Compact Montreal blue, E36 318d Compact Titan silver |
03-09-2018, 07:03 PM | #50 |
Rep 2,029
03-10-2018, 01:00 AM | #51 | |
Rep 231
Did your friend with the silver ones on the white car have the same issues as Maxwell with worm and bubbling of the lacquer or have the held up as well as yours Darth?? Sorry for all the questions and hijacking the thread ! |
03-10-2018, 09:19 AM | #52 |
Rep 227
Something tells me that this morning the trigger has been pulled...
Now I will have something to do this afternoon, looking for MPS4S. If they won't work, they should be up for sale by next weekend Last edited by Oompah; 03-10-2018 at 09:28 AM.. |
03-10-2018, 11:21 AM | #54 |
Rep 227
Yup, they are very clean.
Just a mark or two that a clumsy tyre fitter left. They were under a grand which I think is pretty decent. Now, keeping in mind what you said about 245/35 not being suitable as I'm an xdrive, I'm looking at 235 40/ 265 35 on mps4s. Around 800 so far, still browsing. I guess I'll end up on 1800 all in all, which is exactly what you said. |
03-10-2018, 11:39 AM | #55 | |
Rep 231
03-10-2018, 12:06 PM | #56 | |
Rep 2,598
I paid £750 delivered for BMW * rated MPSS in 245/35 & 265/35. As you mention for x-drive you need to be within 1% front to rear so the most logical set up is 235/40 & 265/35. You could do 225/40 & 255/35 but personally I think that’s too stretched! |
03-10-2018, 12:30 PM | #59 |
Rep 227
Also, I'm amazed how light they are. 10kg vs 13.5kg on 442's.
It would be interesting to see the difference in handling. Saying that, anything will be better than 442 + rft I have on now. |
03-10-2018, 01:54 PM | #60 | |
Rep 2,598
They do make a difference to the handling too, some of it maybe the MPSS though |
03-12-2018, 01:12 PM | #61 | |
Rep 227
Ok, so just to make sure - before I pull the trigger on tires.
235 40 19 wont rub on a full lock, right? I am on h&r springs as you know... 265 35 19 at the back isn't an issue either? Thanks matey Quote:
03-12-2018, 02:46 PM | #62 |
Rep 2,598
Should be fine based on the research I’ve seen / read!
However being x-drive there isn’t much info from the US forums as there aren’t many over there! |
03-12-2018, 03:07 PM | #64 |
Rep 2,598
03-16-2018, 09:20 AM | #65 |
Rep 227
Right, fitted and to be honest I am not sure what to think.
I am on h&r springs and I was hoping i will lose the saggy rear look if the wheel will come our of the wheel arch a little - I dont think this happenned. Rear 265/35 is a little too close to the fender for my liking I have to say, I worry that with heavy weight at the back, i will rub. It makes want to install a different spring at the back and lift it up a little bit, 5-7mm would be ideal in my opinion. Front 235/40 is close but no rubbing yet. I wil Some pics, dirty and all that but taken just after the wheels were fitted. |
