01-16-2017, 10:06 AM | #1 |
Rep 118
NBT HU http-server error when flashing
Hi to all,
I tried to flash (2 different) NBT HU from 2012 to latest BMW firmware. All gone well during 3 first steps blFlash, swDeploy, cdDeploy: about 20 minutes, then during ibaDeploy, the flash process stops and I have an error message about Http-Server.. I don't use any emulator, the HU is the one for the car from factory, I use direct Esys (no Token), and the HU I-step was the original car one (the correct one) As I said, tried with 2 different NBT Hu, exactly the same problem. Now, the HU starts normally, but works on factory configuration: no CAFD on it. when I try to inject CAFD by detecting it, I have SGBMIDs error.. what is normal I guess: according to VCM, the HU is always on the old I-Level, while the HU was flashed to 015_003_503 (latest I-Step for NBT HU) Can someone help please ? |
01-16-2017, 11:35 AM | #3 |
Rep 118
Ok ! I will try and let you know.
By the way, I retried the flash just by choosing only ibadeploy, same problem.. of corse, when calculating SVT-Ist, I chose 015_003_503 i-level, otherwise it rejected with the other error: SG.. |
01-21-2017, 12:13 PM | #5 |
Rep 2,302
Yes, you are right.
At Esys 3.27.1 there is not such a checkbox. I'm using Esys 3.28.1. You can update the program, but i'm not sure if this will solve your problem. |
