01-08-2015, 12:57 PM | #89 |
Rep 390
I haven't started my installation but have watched the video several times and reviewed the comments here. I find myself wondering if it is possible to do the installation without fully detaching the door panel so that the non speaker wires, etc remain intact. Any thoughts?
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
01-08-2015, 01:18 PM | #90 | |
Rep 140
01-08-2015, 01:20 PM | #91 | ||
Rep 390
Best,
01-08-2015, 01:55 PM | #92 |
Rep 1,748
The more you can separate the panel from the door, the easier it is to put the sound deadening on. I would disconnect the top lighting connector for sure.
01-08-2015, 01:57 PM | #93 |
Rep 187
Drives: 2013 F30 BMW 328i
Yeah I detached the first panel I removed completely and then reattached it. After that I left the panel mainly attached and worked around it. I would just be sure to relieve stress on the wires when doing it you could easily pull them off the door or damage them if you are not careful. The best practice is to completely detach the panel. Now I am headed out to my car for a listen...
01-08-2015, 02:34 PM | #94 | |
Rep 140
I feel like mine aren't loud enough for some reason. Don't know if it's just me. It gets distorted at 95% volume but regular listening I keep it around 75%. |
01-08-2015, 06:29 PM | #95 | ||
Rep 187
01-08-2015, 08:43 PM | #97 |
Rep 187
So I went out and listened and sure enough my driver door was making contact with the wires. Pulled it off pulled the wires through and put it back together. Wish I had thought of that before I put it together the first time. But the good news was three were done without issue. Hopefully nothing loosens up with travel and gets pulled off.
01-08-2015, 09:01 PM | #99 |
Rep 13,010
HiFi OEM amp for MY2015 is significantly weaker (and about 40% physically smaller) than past HiFi OEM amp.
01-08-2015, 09:25 PM | #100 | |
Rep 187
01-08-2015, 11:21 PM | #101 | |
Rep 1,748
For those that haven't seen it, here's the bigger and stronger 7-channel hifi amp next to the OEM speaker, lol. Last edited by Fronzdan; 01-08-2015 at 11:52 PM.. |
01-09-2015, 05:51 AM | #102 | |
Rep 13,010
MY2012-2014: MY2015: When I replaced all my OEM speakers with the Eton PnP kit (while keeping the OEM amp in place as a test) I experienced the same "aren't loud enough for some reason" as the above forum member. I did not experience that issue with other F30 or even the F10 (used same OEM amp) from MY2012-MY2014. Those OEM amps handle aftermarket speakers quite well. |
01-09-2015, 07:08 AM | #103 |
Rep 1,086
Looks like BMW is cutting cost everywhere specially where you can't see.
Im satisfied with the outcome of my 2013 335i I also have a question... When you go to BAVSOUND website and your are choosing your car model, on 2013 they have well defined 2013 328i then well defined 2013 335i, whay is that? Do they have any difference in terms of sound hardware?
2016 M3, Mineral White, SO Leather, MANUAL - ED 11/26/2015
2013 335i, Blue, M-Sport, Auto w/Sport Trans - ED 06/10/2013 |
01-09-2015, 07:13 AM | #104 |
Rep 3,300
Wow. I've been off of the HiFi amp in my '13 for quite a while (wasn't loud enough). I can't imagine why BMW would make the thing LESS powerful.
01-09-2015, 08:19 AM | #105 | |
Rep 187
01-09-2015, 08:59 AM | #106 | |
Rep 390
<<<<<<<<<update>>>>>>>>> Based on Technics response below my speculation seems wrong. Sorry for any confusion.
Best,
01-09-2015, 10:04 AM | #107 | |
Rep 13,010
Please remember that there was a 2013 E92 and E93 335i. |
01-09-2015, 07:00 PM | #108 | |
Rep 140
I think my next car I am just going to opt for the sound upgrade instead of going aftermarket. It's just so much easier when you're leasing. |
01-10-2015, 06:52 AM | #109 |
Rep 3,300
Everything I've got is PnP installed on my leased car. Nothing modified or cut. It will come out and find its way into my next car when my lease is up.
01-11-2015, 11:06 PM | #110 |
Rep 1,035
Just installed my Bavsound Sound One upgrade this weekend and wanted to chime in with my first impressions. I've give my review of the audio quality later as i haven't had a chance to immerse myself in the system yet.
But as far as the installation process itself, here are some of the lessons learned. I know installation notes have been covered extensively by many others, so rather than repeating all the same stuff, here are some things that are maybe a little different, new, or things i had not read about.
