04-10-2015, 09:44 AM | #90 | |
Rep 19,982
Interested to hear how you get on...
04-10-2015, 10:24 AM | #91 |
Rep 9,709
04-10-2015, 01:16 PM | #92 |
Rep 630
I want to order also these yellowstuff pads . Do you have to have new sensors for that ???
M5 CP Alpine white
04-10-2015, 01:21 PM | #93 | |
Rep 32,881
Obviously if you look at them and they show no sign of damage then they're fine. |
04-10-2015, 02:05 PM | #94 | |
Rep 9,709
Rears done, fronts tomorrow. |
04-10-2015, 02:07 PM | #95 | ||
Rep 32,881
Although I managed to get a used mint condition front sensor for £8 from eBay!! |
05-01-2015, 06:41 AM | #96 |
Rep 9,709
UPDATE:
Always difficult with brakes as it takes a while to bed them in and by the time they do you have often lost the reference feel from the old ones. However have had the EBC Yellowstuff in and bedded in, so thought I would share the views. So far very happy, the friction levels are clearly superior to the standard BMW items. They are an organic material pad rather than the ceramic type that BMW supply, however, the wheel dust is not significantly more as is usual with an organic. I have had a few squeals but this is when inching with brakes applied very lightly. Now this might start a thread by some owners, but not me, I can live with that. Under heavy braking they are noticeably smoother and quieter than the BMW sets. I don't get the hum when standing on the pedal like before, but then again you can't stand on the pedal as it locks up pretty sharpish....in fact it catches out the ABS momentarily on occasion. Initial bite? Well not really improved things here, I sense there is a 'soft start' built into the BMW braking system, and the pads have not changed that. What you do get is the first bite after being a bit 'bitey'. I quite like the general feel. I am having a little issue with the extra assistance (brake pre-tension or whatever it is called) given by the anti collision system (part of active cruise control). What happens is when it pre-tensions and you hit the brakes, it stands you on the nose. I can of course turn this function off, but will live with it for a while longer. So in conclusion, the Yellowstuff's are a great streetable pad, with no adverse 'cold brake' syndrome. They add massive capability to the brakes being able to brake harder with less brake pedal pressure, but ultimately won't stop the car any better than the stock sets. Warning: they might be a little too sensitive for many drivers and don't give the graduation that you get with the stock set. No idea on life expectancy yet. Track day tomorrow will give them a proper test. |
05-01-2015, 07:03 AM | #99 |
Rep 418
I don't think they'll be at their maximum yet. The fancy bedding in surface must be gone by now but in their current state they are at their minimum surface contact area (on account of the 'V' shape of the material). Judging by my experience with the Ultimax 2's on my S4, which were utterly superb considering their lack of performance focus, you have much more to come in the next 1500 miles, I think. I look forwards to hearing about them.
05-01-2015, 07:11 AM | #100 | |
Rep 9,709
05-01-2015, 07:57 AM | #101 |
Rep 19,982
Will be interesting to see how they get on tomorrow. I'm awaiting my revised revised front braided hoses from HEL so will be on standard fluid still, which is a shame as was looking forward to seeing how they were going to be.
05-01-2015, 08:06 AM | #102 |
Rep 9,709
Indeed....I am still on standard fluid too, which is the only niggle I have about tomorrow. Car is 2 years old in June, so brake fluid is in the 'time to change' window. Fingers crossed it doesn't have much water in it.
05-01-2015, 08:48 AM | #103 |
Car OCD
263
Rep 595
Drives: 2017 EBII F36 430d M Sport
Not from the UK but thought I'd share anyway
I am also hitting the track tomorrow and have done basic upgrades to the brakes system (standard OEM 335i system - 340mm front rotors): Pagid RS29 pads at the front, StopTech Street Performance pads at the rear, ECS tuning SS lines and high temperature fluid. Pics of lines and Pagids in place: As it can be seen on the picture, Pagids do not come the extra little weights (anti-vibration and squealing?) like the OEM pads but it does not seem to make any difference. Resistance to fading seems to have improved (in fact, I was not yet able to get the brakes to fade, but I have not reached track speeds on open road either...). Full braking power can be applied quicker, but is still controllable enough to avoid the wheels to lock/ABS to jump in. Pagids are known for squealing a lot, but it only really happens when they start to run hot. I also know that it is not advised to use race pads on the street, but they perform just as well as the stock pads at low temperature. I am eager to see how this setup will work on the track. The DE takes place at Atlanta Motorsports Park that is a relatively slow track and is not very tough on the brakes. If everything goes well, the next step will be Road Atlanta. I'll report after the week end
2017 BMW F36 430D M Sport Estoril Blue, 2002 E46 M3 Imola Red & 2006 Porsche Cayman S Artic Silver
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL Last edited by ATLBlue; 05-01-2015 at 09:32 AM.. |
05-01-2015, 09:02 AM | #104 | |
Rep 418
Just wondering how the pedal 'feel' had changed for you wth these upgrades, in comparison to stock? NISFAN reports little change from stock with higher torque pads, despite improved actual performance. So I think we're interested in the improvement from lines and fluid too. |
05-01-2015, 09:49 AM | #105 | |
Car OCD
263
Rep 595
The benefit of the lines and fluid will only be noticeable on the track when the brakes start running real hot. I am bringing my infrared thermometer to find out how hot I am running getting off the track too.
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL |
05-01-2015, 10:21 AM | #106 | |
Rep 9,709
05-01-2015, 03:15 PM | #107 | |
Rep 32,881
06-19-2015, 08:30 AM | #109 | |
Rep 418
Update please
Just wondering how, after 6 months in, you feel about the pads NISFAN? General observations, behaviour and so on would be nice Thanks |
