BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 335i LED Conversion (work in progress)
      02-06-2015, 03:42 PM   #89
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Thank you! It appears that the Weisslichts are brighter than stock. I wish they would hurry up and make something for the 4 series.
      02-06-2015, 07:18 PM   #90
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Wait you got the brake light LED's from Bimminan? How come they don't have them listed for both the F30 & F32?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      02-06-2015, 07:23 PM   #91
tboooe
tboooe's Avatar
925
Sorry. I got brake lights from Horizon LED in England.
      02-06-2015, 07:26 PM   #92
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Nvm just found out F30's have the same bulbs for Turn signals and brakes... Why did BMW make the F32 Different!
      02-07-2015, 01:25 AM   #93
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
How are they in your opinion? Brighter than stock and error free?
      02-11-2015, 02:26 AM   #94
akirax
Drives: BMW F30
Hi, brake lights bulbs are red or white? the bulb I mean.
Thanks!
      02-11-2015, 08:25 AM   #95
tboooe
tboooe's Avatar
925
They are almost as bright as stock and error free. Check out my build thread for a video I took.
Thanks!
The stock bulb is white. The LED I used is red.
      02-11-2015, 08:46 AM   #96
akirax
Drives: BMW F30
Thanks!
      02-25-2015, 02:21 PM   #97
tjlees
England
349
Drives: F30 Chav Mobile
Many thanks for the brilliant advice on this thread.
bimmian.com WeissLicht LED rock!
For all you Brits, I ordered: WLF303YYY - Fogs, WTS302FAY - Front amber indicator, WTS302RAY - Rear amber indicator, WTS302RRY - Rear red outer brake and WTS302VWY - white reverse for my F30.
That translated into:
... and this nice little package arrived:
The bmw user manual can be used for fitting most of the bulbs as per above. For the fronts indicators, for me it was a made whole lot easier by jacking the car front up and allowing the wheel/tyre to drop and thus permitting better entry to the access panel and subsequent bulb removal/replacement.
For the fogs, (sorry if this is a repeat) turning the wheel inwards and removing some of the wheel arch panel screws permitted the fog bulb to be replaced - see http://f30.bimmerpost.com/forums/sho...d.php?t=871554 for a good guide.
I got confused with the flickering, thinking it was just while the bulb was on - but no, every 5 or seconds a pulse is sent to each LED resulting in ... err a flicker. Normally OEM bulb would not register the pulse to the naked eye, but those damn good LEDs do. Coding is needed then.
      02-25-2015, 02:32 PM   #98
tboooe
tboooe's Avatar
925
Bimmian lights are nice...wish they made something for the F32 brake and reverse lights.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      02-25-2015, 03:49 PM   #99
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
Zain didn't get back to you? I heard from him and Joe. Ordered 50W backups (P21W) and front turns (PY21W). Zain's expecting the 50W brakes in the first part of March.
      02-25-2015, 03:54 PM   #100
tboooe
tboooe's Avatar
925
No man! WTF. So he said he has the reverse lights? The ones on the 4 series is like the front turn signals, it requires the bulb base. I am not sure if he can get those. It was the same situation with the front turn signals. All they had was the bulb but not the base so I ended up buying the Bimmian front turn LEDs.
My build thread
      02-25-2015, 03:58 PM   #101
Mike_L
So your backups are PY24W? I had those on the E70. Those aren't what I have on the F34. He only has those in Amber.
http://www.horizonleds.co.uk/cree-le...y24w-cree-leds
Wait, just checked the ETK. Your front turns are PY24W. The rears are PW16W. They look similar, but he doesn't have those listed at all.
      02-25-2015, 04:01 PM   #102
tboooe
tboooe's Avatar
925
Reverse is PW16W. According to the pic image on realoem.com it has the bulb base.
My build thread
      02-25-2015, 04:22 PM   #103
Mike_L
The base is different. No idea what these jumbles mean, but they're the codes for the bases. Google just pulled up the Wiki page I got them from.
PW16W - WP3.3×14.5-8
PY24W - PGU20-4
      02-25-2015, 04:25 PM   #104
tboooe
tboooe's Avatar
925
Yeah the base looks smaller for the PW16W. I mentioned this to Zain and I think I scared him away! LOL!
My build thread
      02-27-2015, 07:01 AM   #105
Steve33
Steve33's Avatar
Drives: 2018 SQ5
I've stated that on here numerous times
      02-28-2015, 09:53 AM   #106
tjlees
England
349
Yep read that - For some reason I thought the flickering was when the light was on but that is the current variation which the resistors in WeissLicht LED minimises/stops.
      09-08-2015, 06:58 PM   #107
david51
david51's Avatar
France
538
Drives: bmw M3 F80
good
      09-24-2015, 10:15 AM   #108
coldfyre22
Drives: 2013 335i MSport EBII
Do any of you have the white front turn signal bulbs instead of the amber?
I would love to see pictures/video to see how close in hue/temperature they are to the halo's when using them at night with the headlights on and how big the brightness/intensity difference is between them and the halos and headlights, since theyre "8x" brighter than OEM.
Thanks!
      12-05-2020, 01:56 AM   #109
BlackBetsy
Drives: 2015 BMW 328i Xdrive
Thanks for writing up this great forum. I have a 2015 328i , what bulbs would work for my front turn signals... Im going for the clear/white bulb look that does not appear colored (the standard yellow/amber) with daytime/running lights but when the turn signal is activated it will have amber lighting. Hopefully this exist and Im not wasting your tine 🤣.. my bulb is a Py21w. Thanks!
