07-12-2015, 05:23 PM | #111 |
Rep 464
Hi Everyone,
I am also new to BMW. I recently picked up a 2014 435i xDrive Executive, Premium, M-Sport and Adaptive LED headlights. Finished installing and coding the M Performance Brake kit on Friday with the help of this forum group. Thank you. I believe I have all of the requisite HW to get SLI working. I have VO 8TH and coded KAFAS2, HU_NBT, KOMBI and REM_BODY. I have the "---" in the HUD display. I understand I have to purchase the 7E FSC in order to enable SLI. is there anything else I have to do? Are the signage already in the Nav database or do I have to download/install a signage file? Does anyone have a source? Shawn? Mario? Others? Thank you Larry |
07-12-2015, 09:12 PM | #112 | |
Rep 40,752
02-19-2016, 04:30 PM | #113 | |
Rep 35
I am finalising an order for a 330e right now. Current plan was to get 5AS driver assist and 5AC high beam assistant as well as 5DF (ACC with stop'n'go) I decided not to go for 5AG (LCW/Active Blind Spot Detection) as it required adding the (expensive) folding mirror option - along with taxes putting the price of that single option up over US$1400 in my territory. If I understand the current coding setup correctly, if I was to purchase 8TH (SLI) and 5AG (LCW) instead, I might be able to add 5AS and 5AC via coding after purchase. This is because purchasing 8TH SLI results in getting a KAFAS2, and purchasing 5AG gets me the steering wheel vibrator? Does purchasing 5AG on it's own get me the KAFAS2 system component or is driver assist or speed limit information also required? Have I completely misunderstood the situation? Would all of the various features of 5AS be likely to work as the vibrator would be in the steering wheel from 5AG and the various required/optional elements from 5DF would also be present? Has anyone coded HBA successfully on an LCI with SLI?Was a new FSC code required for either of the above? |
02-19-2016, 05:54 PM | #114 | |
Rep 40,752
You cannot just code 5AS though as Front Collision Warning and Pedestrian Detection require FSC Enabling Codes that you will not have. You can code 5AC, but, you will still be missing the Steering Wheel Stalk with the HBA Toggle Switch to turn it On and Off. 5AG will not get you KAFAS Camera, as Lane Change Warning (Active Blind Spot Detection) uses Radar Sensors, not Camera. 5AD Lane Departure Warning uses KAFAS Camera though.
02-20-2016, 04:11 AM | #115 | |
Rep 35
is there any source for the FSC codes around or will it be cheaper to have the stealership just add these options? really dislike the fact that these type of safety options are installed on the car but DISABLED by BMW unless paid for as options, seems unethical at the very least. Last edited by catharsis; 02-21-2016 at 09:57 AM.. |
02-20-2016, 05:49 AM | #116 | |
Rep 40,752
As for FSC Codes, typically they can be purchased, but they are normally expensive. Personally, I would always take a factory option over a retrofit if you can swing it.
07-24-2016, 06:15 PM | #117 |
Rep 16
Hi guys, I have prb need help !!
After updating my Navi map to latest version, the speed limit info (speed limit signs read by KAFAS radar) stopped shown any road signs in HUD and Instrument cluster... Anything I can code to get it working again?? Note: everything is stock (HUD, KAFAS, Connected drive) nothing retrofitted. |
07-24-2016, 06:25 PM | #118 | |
Rep 40,752
07-24-2016, 06:48 PM | #119 | |
Rep 16
From that date SLI stopped showing anything, Think because Northern Africa map doesn't have data for SLI. Today I revert back to Europe Next 2016-2 and SLI Still not working. Last edited by hghabri; 07-24-2016 at 06:55 PM.. |
07-24-2016, 06:59 PM | #120 | |
Rep 40,752
07-24-2016, 07:17 PM | #121 |
Rep 16
07-24-2016, 07:30 PM | #122 |
Rep 40,752
Does Europe NEXT map provide any coverage for Northern Africa, either in previous 2013 version and / or in current 2016-2 version?
07-24-2016, 07:31 PM | #123 |
Rep 16
07-24-2016, 07:38 PM | #124 |
Rep 40,752
I don't know then. It is difficult to image it worked when 2013 version was installed if that map did not include Northern Africa coverage. But assuming you are right, then BMW either changed something with NBT firmware or Map SLI data that prevents Camera readings at all unless it is receiving local Map Data.
I am not sure what you are trying to do though. If it were a choice between having Camera SLI readings from Road Signs and no Navigation Map or vice versa, most everyone would prefer the Navigation map.
07-24-2016, 07:56 PM | #125 | |
Rep 16
07-24-2016, 08:55 PM | #126 | |
Rep 40,752
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-24-2016 at 09:05 PM.. |
07-24-2016, 09:04 PM | #127 |
Rep 16
07-24-2016, 09:05 PM | #128 |
Rep 40,752
Car does have factory Option 8TH Speed Limit Info, correct?
07-24-2016, 10:50 PM | #130 |
Rep 16
S609A NAVIGATIONSSYSTEM PROFESSIONAL Navigation system Professional
S610A HEAD-UP DISPLAY Head-up display S654A DAB TUNER DAB tuner S676A HIFI LAUTSPRECHERSYSTEM HiFi speaker system S698A AREA-CODE 2 Area-Code 2 for DVD S6ACA INTELLIGENTER NOTRUF Intelligent emergency call S6AEA TELESERVICES TELESERVICES S6AKA CONNECTEDDRIVE SERVICES Connected Drive Services S6AMA REAL TIME TRAFFIC INFORMATION Real-Time Traffic Information S6ANA CONCIERGE SERVICES Concierge Services S6APA REMOTE SERVICES Remote Services S6NRA APPS Apps S6NSA KOMFORTTELEFONIE MIT ERW. SMARTPHON Comfort telephony w/ enhanced Smartphone S6WAA INSTRUMENTENKOMBI. M. ERW. UMF. Instrument panel with extended scope S710A M LEDERLENKRAD M leather steering wheel S715A M AERODYNAMIKPAKET M Aerodynamics package S760A INDIVIDUAL HOCHGLANZ SHADOW LINE High gloss shadow line S775A INDIVIDUAL DACHHIMMEL ANTHRAZIT Headlining anthracite P7VBA COMFORT PAKET Comfort Package P7VDA SICHT PAKET Sicht Packet P7VGA WAERMEKOMFORT PAKET Heat comfort package P7XPA NAVIGATIONSPAKET CONNECTEDDRIVE Navigation package Connected Drive L801A DEUTSCHLAND-AUSFUEHRUNG NATIONAL VERSION GERMANY S879A DEUTSCH / BORDLITERATUR On-board literature, German S8KAA OELWARTUNGSINT. 30.000KM/24MONATE Dummy-SALAPA S8THA SPEED LIMIT INFO SPEED LIMIT INFO |
07-26-2016, 01:38 AM | #131 | |
Rep 183
Hi Mario,
How have you gone with this retrofit? As SLI is available in Australia now, I'm assuming you have had more luck. http://www.motorline.bmw.com.au/com/...on-system.html Quote:
07-27-2016, 07:16 AM | #132 | |
Always on track!
Rep 90
Drives: 328i
