03-19-2021, 12:45 AM | #1 |
Rep 60
AC compressor Disengaging
I recently took my 17 F34 330i GT to the dealer to get the AC system charged due replacing a broken AC line. They charged the system but found the compressor to not kicking on for very long and dragging. They quoted me almost $2k to replace the compressor. Of course I declined.
So when turning on the AC, the compressor turns on for a few seconds and then turns off. I see the clutch kicking in when initially turning it on and it spins, but like the dealer said, it turns off not too long after. No cool air is coming out of the vents with the AC on. Anyone have any experience with this? Could it be something else or is the compressor toast and needs replacing? Could it be the AC relay or replacing some minor part of the compressor? |
03-19-2021, 09:58 AM | #2 |
Rep 4,877
I've had issues where I had the fan level at the lowest setting which caused the system to freeze up, and the compressor to turn off.
Others have mentioned the high pressure switch (I think it was the high, not low...) fails causing symptoms like you are describing. That is a simple and cheap fix if that is the case. |
03-19-2021, 09:59 AM | #3 |
Rep 1,906
the Freon carries the lubricant for the compressor, so it would seem possible that if the a/c system was operated with zero or low Freon that the bearings and seals in the compressor may have been damaged.
03-19-2021, 02:27 PM | #4 | |
Rep 60
03-19-2021, 03:03 PM | #6 |
Rep 60
03-19-2021, 04:12 PM | #7 |
Rep 1,906
See attached pic, item #4 I believe is what above poster is referring to.
https://www.fcpeuro.com/products/bmw...181464#reviews Good luck/Bill |
03-19-2021, 07:52 PM | #9 | |
Rep 60
Today I checked the AC and compressor and it was working after not working for 2 weeks. The clutch was engaged and spinning with the AC from a cold start. The radiator fan wasn't spinning, im guessing thats normal when you start your car in the morning even if AC is on? Anyways ill continue to monitor it and if it stops working ill see if I can replace that sensor. |
03-19-2021, 07:54 PM | #10 | |
Rep 60
03-19-2021, 07:58 PM | #11 |
Rep 4,877
The AC compressor runs and different times to keep the seals lubricated otherwise they dry out and you lose refrigerant. In "olden days" the compression would kick in with the windshield defroster on some brands.
I've never looked at mind to see when it's cycling or not, so I'm not much help there. |
03-19-2021, 08:08 PM | #12 |
Rep 1,906
Some compressors are 'variable volume' design (like in my X3)....they are 'continuously engaged' so to speak, always running.
But after reading this F30 forum for a while it seems compressors in these sedans are older style. |
03-19-2021, 08:30 PM | #13 |
Rep 60
Yes I've read that too, but I'm still not sure how these compressors are supposed to function properly.
As for the pressure sensor, does the refrigerant from the AC lines have to be vacuumed out prior to replacing it or can I go ahead and replace it without vacuuming it out? |
03-21-2021, 11:58 PM | #15 |
Rep 60
So with the AC on, the cool air from the vents comes and goes. Seems the compressor engages and then disengages constantly. There should be constant cold air coming with the AC on right?
03-22-2021, 09:54 AM | #16 | |
Rep 1,906
You should feel a reasonably constant stream of cool air entering the cabin; no major air temp swings. |
03-22-2021, 04:53 PM | #17 |
BMW CCA 69606
86
Rep 227
How long was the AC system discharged w/broken line?
Your compressor has both a magnetic clutch and a capacity control valve. The compressor should be able to run continuously under all but extreme light cooling loads, like 40F temps and sustained high vehicle (and therefore compressor) speeds. You need to scan the IHKA module with ISTA. Hard to believe the dealer didn't do this. Bad pressure switch, bad evap temp sensor, bad clutch, stuck capacity control valve, bad electrical connection(s) and likely other issues could cause short cycling of clutch. I would not attempt to change pressure switch/sensor w/o discharging system. |
03-23-2021, 06:53 PM | #19 | |
Rep 60
03-30-2021, 04:59 PM | #21 | |
Rep 1,906
May need Mr. A/C specialist to pinpoint issue. |
03-30-2021, 05:00 PM | #22 |
Rep 4,877
That's either a faulty high pressure sensor or an actual over-filling of the refrigerant in the system.
Or a blockage as mentioned above. That is possible if it sucked in crude with the broken line. You'll need to take it somewhere they can hook the gauges to it to properly diagnose. |
Wgosma806.00 |
