BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Replacing side air vents BMW F32
      03-22-2018, 02:21 AM   #1
MHL
MHL's Avatar
Drives: '20 BMW G22 and '22 Volvo S60
Hello!
I want to do a DIY with replacing the side air vents from my four series coupe.
They are now matched to the paint and prefer the black glossy one. I have orderd them on ebay.
Is there someone willing to check for me in ISTA what the procedure is for replacing the vents? Or did someone else already did this DIY and can tell me what to do.
Any help is much appreciated!
      03-22-2018, 06:44 AM   #2
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: M4CPC // HP4 Comp.
Had you used the search before...?
Thats beyond from simple and done within 15 minutes.
Refer to this site for detailed view of the part.
Assuming that you are not familiar with German:
- Protect the painted surface above of the circled 1 at the top picture.
- Pry out the breather outta their 2 pin holes
- use a heatsource to ease the removal of the breather from the glue strips. Those had to be changed and couldnt be reused.
- clean the surface, replace broken insert clips
- reapply the breather and press gently to make the glue strips steady adhesive
Dont forget pictures
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
MHL13.00
      03-22-2018, 03:34 PM   #3
MHL
MHL's Avatar
Yes i did google a lot. Only not in German. Thank you for the link and the translation. Much appreciated. The vents are one the way from a country far far away. So it can take a while. I'll add pictures to the DIY
Thanks again!
Dang3r12508.50
      03-22-2018, 09:22 PM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Then you'd use this: https://www.newtis.info/tisv2/a/en/f...rip/1VnXfjIBDB
MHL13.00
      03-24-2018, 11:00 AM   #5
MHL
MHL's Avatar
Originally Posted by Billfitz View Post
This should do the trick! Thank you Billfitz
