BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > possible to get speed limit info on 2014 HUD?
VIBE Motorsports
      11-27-2017, 01:09 PM   #1
PabloK
PabloK's Avatar
Drives: F30
have a 2018 4 series loaner.
The hud shows the speed limit right next to your current speed... love it.
Possible to get this on my 2014? Bimmer-tech?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2012 E70 X5 50i / 2007 X5 3.0is
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-27-2017, 01:19 PM   #2
marcu
marcu's Avatar
Netherlands
36
Drives: 440i Coupe 2018
Do you have speed limit info in the regular dash? Then it is a matter of selecting it to show in hud, using idrive.
Otherwise you need some additional hardware and coding to get this done
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD
2009 Alfa 159
2005 Alfa 156
      11-28-2017, 12:10 AM   #3
PabloK
PabloK's Avatar
Drives: F30
I do not have speed limit info on the car. 2014 w/ NBT.
Do you know what kind of hardware I need? Has anyone done this retrofit?
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-28-2017, 01:31 AM   #4
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
https://m.ebay.com/itm/Speed-Limit-I...77?_mwBanner=1
This is what might be useful for you.
And here is the thread on it that I used to get speed limit on HUD and dash cluster.
Finally added Speed Limit Info http://f30.bimmerpost.com/forums/sho....php?t=1203393
PabloK306.50
      11-28-2017, 02:16 AM   #5
PabloK
PabloK's Avatar
Drives: F30
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-28-2017, 04:07 PM   #6
PabloK
PabloK's Avatar
Drives: F30
Gabreigns,
I purchased from the exact seller that you posted. How did your install go?
Does your HUD show the speed limit in a white box or the circle?
Appreciate your help on this.
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-28-2017, 07:52 PM   #7
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
Awesome! Mine shows in the red circle like how it is in Europe as I like the color in the HUD instead of the US black and white rectangular board.
The Install was very simple. It does get tight behind the cluster but doable with zip ties and such.
PabloK306.50
      11-28-2017, 11:42 PM   #8
PabloK
PabloK's Avatar
Drives: F30
Nice, yea I think the red circle looks better than the white box. Do you mind me asking what Nav setup you have? I'm 2014 NBT (2018maps) with 6WB display.
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-28-2017, 11:46 PM   #9
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
Yup, Same setup as yours on hardware. 2014 NBT with 6wb. But my maps I think are 2017-1.
      11-28-2017, 11:48 PM   #10
PabloK
PabloK's Avatar
Drives: F30
My harness just shipped, can't wait to get this done!
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      11-29-2017, 01:58 AM   #11
mhhforyou
mhhforyou's Avatar
28
Drives: F36 420da
2014 BMW 420da  [0.00]
To retrofit OEM 8TH you need:
Kafas2 camera
windshield
Kafas2 ecu
rear mirror
harness (F15)
1x FSC
      11-29-2017, 02:25 AM   #12
mbfanos
Drives: 328i
Same setup. Installed this 3 weeks ago and it's been perfect
PabloK306.50
      11-29-2017, 09:26 AM   #13
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
It's been 6 months with that unit and no issues.
I loved how no splicing or cutting was needed to install it.
PabloK306.50
      11-29-2017, 11:42 PM   #14
FSociety
2020 X3M/X4M Coming Soon
FSociety's Avatar
Dominican Republic
2580
Drives: X4 M40i LeaseTakeOver
Send a message via AIM to FSociety
i have speed limit in my NBT + HUD in my X4 M40i
Tweaked CTSTurbo FMIC + *NEW* X4 M40i CTSTurbo DP *PM for info* + BM3 4.19s 0-60 | 12.4@110 1/4 mile
@bmwX4M40i
      11-30-2017, 12:21 AM   #15
PabloK
PabloK's Avatar
Drives: F30
Kafas2 camera
windshield
Kafas2 ecu
rear mirror
harness (F15)
1x FSC
I believe my 2014 with tech package came with this
Kafas2 camera
windshield
Kafas2 ecu
rear mirror
What is 1xFSC? coding?
2009 E60 M5
2004 E46 M3 Conv
2017 WK2 SRT
      12-02-2017, 07:08 PM   #16
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
2016 BMW 435ix  [0.00]
Yeah PNP with the eBay box is nice, but I don't like the fact units designation will always show as km\h on dash
There is another unit from Germany that shows correct units, but it requires splicing.
Now if we can get a unit that does both that would be perfect...
F32 435ix//Mineral Gray Metallic//Black Dakota Leather//Alum Blade Trim//M Sport Pkg//Prem Pkg//Tech Pkg//Driver Assist Pkg//Lighting Pkg//Cold Weather Pkg//Dyn Handling Pkg//HK Sound+BavSound Stg2//437M Wheels//M4 Mirrors w/NWC CF Covers//MPerf Pedals-CF Rear Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//CF Side Grilles//MPE w/CF Tips+CGP VSC-1//Dinan CF Intake//AA FMIC//ER CP+TIC//3.5bar TMAP/DV+//AA OBD Flash Tune Stg2
      12-02-2017, 07:17 PM   #17
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
Too true!
      12-02-2017, 07:35 PM   #18
1QuikWS6
No 55mph
1QuikWS6's Avatar
Too true!
Outta curiosity, don't think this question has been asked before
With the eBay unit, once it is installed, I know you can turn On/Off the speed display in the HUD thru iDrive, can you also turn OFF the dash display if you wanted - or is it permanent?
I would get this if I can turn Off the dash display with the incorrect units, only really need it visible in one place
      12-02-2017, 07:41 PM   #19
Gabreigns
Gabreigns's Avatar
371
Drives: F3x
Too true!
Once the unit is installed, I know you can turn On/Off the speed display in the HUD thru iDrive, can you also turn OFF the dash display if you wanted - or is it permanent?
Oh yes you can. But you will have to code it. I will have to dig up the code for you. Unless someone else has it.
Right now in my case it always displays in the HUD and I turned it off in the instrument cluster to not be shown when I cycle through the options using BCC button on the indicator stalk.
