03-18-2018, 11:52 PM | #1 |
Rep 55
Sold my 2015 WRX for a 2015 335I - Impressions
I recently sold my 2015 WRX Manual (newer FA20 twin scroll motor) for a 2015 335Ix manual. When it comes to aesthetics, comfort and features, I do not miss my WRX. However, I do miss the exhilarating and forgiving experience of driving my WRX. It's lightweight agility, built to hammer transmission, thrilling low end torque, and flat four "makes all the right sounds" motor are hard to move on from. My WRX was stage 2, which in the rally world translates to a turbo back exhaust and an aggressive tune. I was also running some other boltons like intake, tgv deletes, boost controller, etc.
Absolutely no regrets, especially when approaching my alpine white 335I at night and seeing the under handle LEDs light up while using comfort access to sink into the amazing interior equipped in sport line - Loving the red accents on the black interior. I am a little confused though on the capabilities of my new car. The throttle response is too unpredictable to launch without bogging or execute rev match consistently, the rear feels too heavy to throw around corners and I feel like I am violating the transmission when catching gear during WOT. My gut tells me most of these discoveries are a result of overactive hardware and software, overriding driver input, but I'm not convinced. It's possible I'm failing to recognize the unleashed potential of a stock vehicle. After all, a simple stage 1 remap on the WRX eliminated an infamous rev hang issue that completely changed the way the car responded to spirited driving. Is my 335Ix going to just be faster once I begin modding or will some of these challenges also resolve? |
03-19-2018, 12:48 AM | #2 | |
Rep 2,639
Second, at least you don't have to worry about blowing your engine with a n55 like the FA20. Third and lastly, Its much easier to get more power than the WRX, thats for sure. Xdrive 335i weighs about 3900lbs with driver inside, WRX weighs about 3500ish with driver so you will feel the difference there. Not to mention sway bars on the 335i are 23 front 12 rear, which is why the rear is so heavy. The suspension is also more softer for comfort. Everything can easily be solved with coilovers, FBO, and sways. Trust me, BMWs straight six makes much better sounds than a subaru ever will. I personally hate how the FA20s sound, and even more the EJ (don't even get me started.)
eluded3032.00 |
03-19-2018, 01:01 AM | #3 | |
Rep 55
Thanks for the feedback and I agree the 335i is the superior car.
While I would have preferred an Msport, I had a strict criteria including alpine white exterior, AWD and 6spd Manual. The sacrifice was Msport trim, but I definitely do not mind the exclusive red accents throughout the interior with the Sport Line. Quote:
03-19-2018, 01:14 AM | #4 | |
Rep 2,639
It has extra coolers, adaptive suspension option, more aggressive bodykit that has functional vents for the kit, and a small bump in power with the MPPK. It also has the upgraded transmission for the 8AT and I believe 6MT as well.
03-19-2018, 01:43 AM | #5 | |
2JZ-GTE
3032
Rep 3,992
Awesome to see another purist on the board. I know we need them. We seem to be a dying breed. If you don't have the M sport suspension on the car, you should probably look into coil overs or what not. If you have the all wheel drive X Drive, well that's a whole different issue, you can do searching suspension for that… For power, it's well-documented on here. JB4 with Dow pipe. Pictur3s? |
03-19-2018, 02:08 AM | #6 | ||
Rep 1,876
Chaungo, I can tell from your signature that you care about the noise the car makes.. that Borla Atak catback exhaust with catless DP must sound thunderous!!
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
03-19-2018, 11:14 AM | #7 | |
Rep 55
Yes absolutely,
The primary reason I got out of the WRX was for comfort and presentation. Quote:
03-19-2018, 11:20 AM | #8 | |
Rep 55
I'm aware the Msport comes with many enhancements at a very low cost difference. The only trade off I don't mind with the Sport Line compared to the Msport is the red over the blue accents. Looks good with white on black (I have dark tint, black wheels, black kidneys, black lip spoiler, black leather, etc).
BTW, I'm unsure if this was an option or if it is included with Sport Line, but my car definitely has the Msport suspension. The dealer mentioned it's part of the Sport Line package, but it's possible it might be an a la carte option the original owner bought into. My biggest regret not having Msport is the steering wheel.. Quote:
03-19-2018, 11:42 AM | #9 | |
Rep 55
Pictures attached,
I do like my manual transmission and any car that doesn't come with one is not in my consideration. Quote:
03-19-2018, 11:51 AM | #10 |
Rep 2,653
SportLine bro's! Congrats on the pick up. Don't let the M-Sport fans get you down!
03-19-2018, 12:06 PM | #12 | |
Rep 100
Tuning the car will transform your vehicle. You'll probably end up missing the WRX even less if you go FBO plus a tune. Myself I have a catted DP, IC, axleback exhaust, CP and a stage 2 OTS tune from BM3. My car went from a powerful Lux/sport sedan to a straight jerkmobile and I love every second of it As others have mentioned, this car is bigger and fatter so if you'll need to upgrade suspension and tires (if you're still on run flats) if you want to get close to the same level of "toss-ability" as a WRX. To Sum up: Congrats on the new car, now spend 4k more to make it better Last edited by bobalis; 03-19-2018 at 12:39 PM.. Reason: Corrected exhaust type |
03-19-2018, 12:14 PM | #13 | |
Rep 3,288
You can use this site to break down your VIN to see what equipment your car came with (perhaps you have adaptive and that's what the dealer was calling "sport suspension): https://www.bmwvin.com/ Best to know what you're starting with before you think about changing anything. |
03-19-2018, 01:05 PM | #15 |
Curmudgeon and Pedant
690
Rep 3,489
As others have said, all xDrive cars come with the xDrive suspension. No sport suspension, no msport suspension. So if you want something with less roll, you need to "upgrade" to coilovers (personally, due to the roads we drive on around here, I prefer the xDrive suspension in my wife's 328xd.) And someone thought that Adaptive was included in msport - that is untrue: Adaptive is a separate option (included only with the recent Track Package). You'll have to run the VIN to see if you have it.
We had an alpine white 525i E34 ('91); I have always liked the color. Great spec for that car. Some people like to remove the clutch delay valve (CDV) to increase the immediacy of the clutch and help launches. Frankly, while a tune (especially a flash tune rather than JB4) will help the tip-in/startoff problems, things are better with the 8at. Yeah, I know all about the MT love, but the AT is better from any objective standpoint (performance and mileage.) Note that the new M5 with 8at just crushed Mercedes, Porsche and CTS-V in the Car & Driver that just came yesterday. BTW: it does 0-60 in 2.8s, 1/4 in 10.9 (IIRC) - another case of BMW under-stating performance figures. |
03-19-2018, 07:43 PM | #16 | |
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
Poon Stick42.50 |
03-19-2018, 08:11 PM | #17 |
Rep 797
I too came from WRX land. If you want a MT the options are slim these days.
The bimmer just needs a ton of mods to be what I'd like it to. I never had much of an itch to do anything to the wrx (mine was a 2013 2.5, loaded). It didn't need much. The chassis on that car was great. Even the stock tires were good. It underserved of course but it didn't pitch too much and it _stuck. I was about to do the brakes and the Cobb stage 2, but it developed a very stupid very small yet very experiensive mechanical problem I wasn't willing to do. Subaru problems. Plus people kept revving etc, I am not 23 anymore. Oh and the interior was a rattle trap pile of junk. (Sadly the 340 isn't all that much better in the cabin noises department). The 340 just needs a bunch of mods. At some point I wonder if a used M3 would make more sense. Cosmetics, wheels, tires, coilovers, brakes, bushings. Now that the stock suspension is thankfully in the bin (where it belongs, absolute rubbish) I think the transmission mount bushing and the open diffs are the worst. As soon as the brakes are fried they'll be changed as well. But it's getting there. Most people on here will just talk about exhausts and tunes, which is well and good, but to me the power level is good enough for now while it drives like a pig. |
03-19-2018, 09:04 PM | #18 |
Rep 55
It sounds like the AWD will require some necessary suspension mods to have the car become an autocross contender However, my first mod is always a tuning platform and I have heard endless mixed reviews regarding JB4 vs MHD. Unfortunately my COBB Accessport would work if my 335I was a 2014, but it does not have a supporting application for 2015+.
I could use some help in deciding whether to go JB4 or MHD. I am not concerned about a couple hundred dollars cost difference and a few extra ponies will not make the difference for me. My primary objective is to tune with the platform that is more elusive from becoming the suspect of a denied warranty claim. My understanding is that JB4 leaves less of a trace, but it requires some physical manipulation when reverting back to stock. I appreciate any updated thoughts on this matter. |
03-19-2018, 11:35 PM | #19 | |
Rep 2,639
MHD is still in beta and weeks away from full release. It also takes a long time to unlock and flash a map. JB4 is a piggyback and does not control AFR or such.
03-20-2018, 12:01 AM | #20 | |
Rep 1,502
However, sadly BMW has been dialing in more and more understeer to the 3-series over the years so it actually feels less balanced than it is in reality. On your particular vehicle it’s compounded by the tall, soft springs and shocks as others have mentioned. If you got staggered tires that also adds to the understeer factor. If you’re into modding and want more neutral balance, then the springs and shocks are obvious places to start. IIRC the xDrive models and non-adjustable shocks (THP has the adjustable shocks) are 20mm taller than RWD sport suspension models. Add a little thicker sway bar (or go to a square tire setup if you’re running staggered) if you want to make the tail livelier. Regarding the throttle being unpredictable - are you driving in sport mode? Sport mode boosts the early part of the throttle pedal to be more responsive. Comfort mode uses a more linear throttle map. One or the other might address your issue. You might also be activating traction control on your launch if the tires are spinning, which would retard the throttle. You’d need to turn off all the nannies if you want to do a burnout. |
03-20-2018, 12:28 AM | #21 |
Rep 1,288
Think'in of going this route.... don't want to really lower it... this is .8" drop (20mm) which would be nice and still handle urban streets... what about bump stops?
https://www.tirerack.com/suspension/...M+Sport+Brakes http://www.bimmerworld.com/Bilstein-...35-207481.html https://propartsusa.com/products/Meg...waAt8xEALw_wcB https://propartsusa.com/products/Meg...caAtMZEALw_wcB |
03-20-2018, 12:56 AM | #22 | |
Rep 808
This is from my experience running both spring setups and coilovers on two different cars. And I'll throw in another vote for bootmod3. I just went with their tune as well as supporting mods and would highly recommend at least going stage 1 |
mods, stage, sti, subaru, wrx |
