BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Clock wont show 12hr on instrument cluster
      12-17-2012, 12:16 AM   #1
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
For some reason the clock on the instrument cluster under the temperature wont show the time in 12hr mode, it shows 24hr style. On the idrive it shows 12hr, in settings i checked and its in 12hr mode. But when i switch it to 24hr in settings it doesnt seem to accept the setting. Anybody have any idea what is going on? Can coding fix this problem?
      12-17-2012, 12:27 AM   #2
UhhItsANT
Also can someone check there car to see if this is normal? I have extended instrument cluster.
      12-17-2012, 07:02 AM   #3
bcl0328
Drives: 2012 328i
same issue here.
      12-17-2012, 07:03 AM   #4
BMWrules7
Drives: 2015, 740 LdX, Alpine White
For laughs, reset idrive:
Hold in radio volume control knob for 30 seconds.
      12-17-2012, 10:24 AM   #5
vern
Drives: 2012 F30 335i Sport 2006 X3
Thumbs up
Had the same problem. Checked and rechecked in the i drive square between 12 hour and 24 hour a few times and it stayed in the 12 hour and everything is ok. Good luck
cheers
vern
      12-17-2012, 11:58 AM   #6
UhhItsANT
Resetting it didn't do anything.
      12-17-2012, 11:59 AM   #7
UhhItsANT
cheers
vern
I tried nothing either. When I select 24hr it still says its in 12hr mode selected. 24hr setting doesn't seem to do anything.
      12-17-2012, 12:28 PM   #8
UhhItsANT
Originally Posted by bcl0328
same issue here.
Do you have any coding done to your car?
      12-18-2012, 12:51 AM   #9
UhhItsANT
Bump again. Anybody know what's wrong? Is it normal to show 24hr format in cluster?
      12-18-2012, 06:27 AM   #10
SamS
Not normal. Take to dealer.
      12-18-2012, 11:40 AM   #11
Frogman
Drives: 2012 F30 328i
I have the extended cluster and have coded some things on my car.
Switching between 12h to 24h mode changes both the dash cluster time and the iDrive screen time display as expected.
You are testing this with the car time after 1:00pm, right?
      12-18-2012, 01:07 PM   #12
bcl0328
Drives: 2012 328i
nope
      12-18-2012, 08:49 PM   #13
UhhItsANT
yeah i am testing after. i tried testing before in the morning also. but when i do i change the time to like 1pm so i can see if it changes or not.
Is there anyway to reset the idrive and cluster. like a hard reset?
      12-18-2012, 08:50 PM   #14
UhhItsANT
Originally Posted by bcl0328 View Post
nope
did you get your fix yet or you just live with it? are you able to switch between 12hr and 24hr format on drive? mine stays at 12hr no matter what i select for the setting. it just stuck in 24hr format on cluster so annoying.
      12-18-2012, 11:15 PM   #15
Frogman
Yeah, just push and hold the volume button for 30 seconds or so. You can let go when the idrive screen goes blank. I'm guess that it won't help, but it can't hurt!
      12-18-2012, 11:33 PM   #16
UhhItsANT
that didnt work.
      12-18-2012, 11:37 PM   #17
David328M-Sport
101
Seriously? About the annoying bit. I've been a 24hr person since the late 70's (my first full time job) and even before then, always thought 24hr time was the best. No misunderstandings as to what time it is.
Every time indicator in my office & home, which can be set to 24hr time is set in that manner.
Try it for a while without the frustration. You might like it.
      12-19-2012, 12:00 AM   #18
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Outside of the military, I would think 24 would cause more frustration given how few people use it, in the States at least. Were you often waking up at 7 am and unsure whether it was morning or evening?
      12-19-2012, 12:39 AM   #19
Frogman
that didnt work.
Wow, that's like a fail-safe reboot. You're pushing and holding the volume past the click (like for on/off), right? You have to hold it it for a long time. How long did you keep it pushed? Try up to 60 seconds.
I've never seen that fail to reboot the CIC.
      12-19-2012, 04:42 AM   #20
UhhItsANT
I been trying it but I'm so not use to it. Lol. I prefer the 12hr format.
      12-19-2012, 04:43 AM   #21
UhhItsANT
that didnt work.
Ooooh. The reset work. It turned off I drive and came back on. What I meant was the clock didn't get fix still. Still 24hr format.
      12-19-2012, 11:25 AM   #22
Frogman
Did you code your car? If so, have you tried resetting everything back to the factory defaults?
If that doesn't fix it, it's probably time to take it to the dealer.
