11-17-2023, 03:39 PM | #1 |
Rep 13
My screen won't work??
I just upgraded from my 6.5' display and got an OEM 8.8' display. but when I turned it on the right side of the screen is black I am sure I did the coding right
I did resolution to 8.8' and breites display. Did I purchase a faulty screen or am I doing something wrong? |
11-17-2023, 06:27 PM | #3 |
Rep 13
11-17-2023, 06:56 PM | #4 |
Rep 800
it’s a windows piece of software.
you need an enet cable & windows laptop then you connect to the car and code in the changes. https://f30.bimmerpost.com/forums/sh....php?t=1711432 |
11-18-2023, 09:03 PM | #5 |
Rep 1,582
Check other settings that may be applicable:
CID_Apix_Mode = APIX1 CID_COM_Mode = MMI CID_COLOR_DEPTH = 24bit CID_DISPLAY_RES = 1280x480 CID_DISPLAY_SIZE = 8.8 CID_TOUCH = aktiv CID_HMI_TOUCH = aktiv DISPLAY_VARIANTE = breites_display DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 DIMMUNGSVARIANTE = neue_dimmung
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
ReMiii4021.50 |
