10-29-2018, 04:43 PM | #1 |
Rep 17
Adding tweeters to base system
Hi,
I have F30 LCI with base audio system (6 speakers) powering by no-nav headunit (EntryNav). Sound is not that bad for me but I want to add tweeters in the front doors to improve little bit sound and car interior. My solution is to add front door covers with Harman Kardon tweeters and replace front mid-tone speakers as my stock one doesn't have second connector for the tweeter. This thread https://f30.bimmerpost.com/forums/sh...hlight=tweeter My question for you guys is this metode safe for the system and headunit. I know that front mids and subs are connected in parallel. Will just adding OEM HK tweeter and changing mid to HK make any damage in terms of total impedance. Think that OEM HK tweeters have some sort of crossover. Thanks for help I just want to be sure before ordering parts. |
10-29-2018, 05:08 PM | #2 |
Rep 16,083
You don't need to replace the midbasses to get the tweeter output, just tap the wires to the midbasses. You do have to be sure the tweeters are capacitor protected. Impedance isn't a problem, because the impedance of the midbasses rises as frequency rises, going up rapidly above 4kHz.
10-29-2018, 06:11 PM | #3 |
Rep 17
Here are tweeters and mids in set that that I am watching. I think these HK tweeters have capacitors on the wire. These mids have already connector for tweeter so this is better option for me because I dont want splice any wire on the car.
Other option is to use wire splitter from ebay or HIFI mid-range speaker (both are 4 oms I think). I just dont want to damage my headunit with new speakers. |
10-30-2018, 03:05 AM | #5 |
Rep 17
My idea is if I already remove door trims to replace tweeter why not replace midrange speaker also to achive better sound. I saw on forum that few memebers done that with harman kardon upgrade but other people saying that it can be dangerous for the amp in the headunit.
Thats way I asking for little help |
10-30-2018, 07:18 AM | #6 | |
Rep 16,083
I have measured the specs and response of the stock drivers of my hi-fi system, and they are very high quality, replacement driver advertising claims to the contrary notwithstanding. |
10-30-2018, 11:17 AM | #7 |
Rep 17
So you think that harman kardon mids arent any better than my stock base audio front speakers.
But I still have my concern if I can replace front speakers and add tweeters. I dont wont to damage my idrive with amp overload. At the and I just wont to add tweeters without cutting wires. Can somebody tell me can I do this and how? |
10-30-2018, 11:27 AM | #8 |
Rep 16,083
If the Harmon speakers are better it would only be in their power handling. You don't have enough power from your head for it to matter.
I already told you why adding the tweeters won't cause an impedance problem. I can see that it's probably not an explanation that you understand, but you don't have to understand it. I understand it, because I design speakers for a living. Splicing into the wires to the midbasses is very easy. Find a friend who's done it to help. |
10-30-2018, 04:16 PM | #9 |
Rep 17
Thanks for your help I understood your answer but I don't have much experience in car audio and just a little bit confused reading many articles on net what can be done and what cant.
I will buy than only two Harman Kardon tweeters and two plastic door covers than connect directly to existing stereo system speakers in parallel. I hope that will improve sound a little. |
10-30-2018, 05:08 PM | #10 |
Rep 16,083
I should have mentioned before another tweeter option. I added these to my rear doors:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This is how they look: JBL (a Harmon company) is sold worldwide, so I assume you could get them, or the Infinity REF-275tx 135W, which is exactly the same. The high pass filter that comes with them is much better than just a capacitor as comes with the BMW Harmon tweeter. I would think it could be mounted on the original pieces on the front doors the same way I mounted them on my rear doors. They will work at least as well as the Harmon tweeter and probably save you a lot of money as well. |
07-15-2021, 02:47 PM | #11 | |
Rep 117
If I was to buy a set like the jbl one and just fit those would it do any damage or should it be ok? Thank Stu |
07-15-2021, 09:52 PM | #13 |
Rep 2,180
Understand that adding tweeters to the Stereo (BMW name) system will make your audio sound brighter than standard. This is because the OEM HU output signal is tuned for the mids to make up for the lack of tweeters - adding tweeters will make two drivers output highs instead of only one.
You may compensate for this brightness by using a 2-way crossover with adjustable tweeter attenuation with your tweeters. Instead of wiring the tweeters in parallel with the mids, wire the mids and the tweeters to the 2-way crossover and then adjust the tweeter output to your taste. MB Quart and Eton offer adjustable 2-way crossovers or a fixed crossover designed especifically for the BMW Stereo system. |
07-16-2021, 05:12 AM | #14 | |
Rep 117
Thanks again👍 Thanks Bilifitz. I was just double checking I had read it right. Thanks again 👍 |
07-16-2021, 07:41 AM | #15 |
Rep 16,083
Sure. It's wise to be concerned about the effect on impedance when adding another driver, because the overall load is the square root of their sum. However, because of the inductance of the midrange voice coil its impedance rises with frequency. This is an impedance sweep of the Hi-Fi midrange:
The minimum impedance is roughly 3 ohms, rising above 1kHz. At 4kKz, where the tweeter comes into play, the midrange impedance is up to 5 ohms, rapidly rising above that, so the combined impedance of the two remains within the amp's comfort zone. Below 4kHz the tweeter impedance rises as well, from the effect of the high pass filter. |
07-16-2021, 11:36 AM | #16 | |
Rep 2,180
This means that Navigation Professional HU outputs will be stable if you add a 4ohms tweeter to the mids - OEM tweeter + mids + woofers in parallel = 2ohms. For OEM HU that are not 2ohms stable then BMW adds a cap to the mid to keep it from becoming 2ohms in parallel with the woofers. The capacitor is to protect the OEM HU output impedance limit, not for sound quality. The easiest way to know if your OEM HU will be stable when adding 4ohms tweeters to the Stereo system is to check if the OEM mid has a cap in it or not - if there is a cap in the mid then OEM HU is not stable at 2 ohms, no cap then OEM HU is stable at 2ohms. |
10-10-2023, 06:22 PM | #17 | |
Rep 9
I have a basic F30 2015 with stock 6 speaker setup at the moment (and a slim subwoofer under the passenger seat (that I can remove it if I can achieve my main objective detailed below). I'm looking for the best value for money option (and less invasive process) to improve the sound experience (power and quality). The biggest difficulty would be buying the original wiring harness and dismantling the entire car to install OEM solutions (HK or HI-FI)(besides the harness + amplifier being super expensive here in Brazil). For all these reasons I decided to buy the VIBE POWERBOX 65.4 BMW3 amplifier. The problem now is choosing the ideal speaker option for this configuration (that are compatible with this amplifier). I'm a little lost about the impedance and the OEM setup of the speakers (front speakers in parallel, how the subwoofers works with the door speakers, etc). (The HI-FI subs seems to have 2 ohms). Can you help me with that? Can I use BMW HI-FI speakers with this Vibe amplifier? Should I keep my stock speakers and just install this amp? My IDrive is the CIC. Hope you can help me. Thank you in advance. |
10-10-2023, 09:34 PM | #18 |
Rep 16,083
If you have the base system, with no separate amp, you should upgrade the speakers to handle the extra power that the Vibe amp will provide. The Hi-Fi or H-K speakers are as good as any, and can usually be found used at a low price, being sold by those who believed the advertising and replaced them with third party speakers. There are threads by others who've added amps to their base systems, search them out. It's an easy enough job if you know what you're doing, but if you don't it's probably best to get professional help.
10-11-2023, 05:41 AM | #19 | |
Rep 9
And about the impedance of the HI-FI subwoofers?? Can I change my stock subs (4 ohms I think) to the 8" HI-FI 2 ohms ones?? I'll look for these threads!! Thank you again. |
10-11-2023, 07:56 AM | #20 |
Rep 16,083
The Hi-Fi woofer nominal impedance is 3 ohms, with DCR of 2.4 ohms. If you have the base system your current woofers are 6.5 inches, so you may need to replace the enclosures as well as the woofers.
10-11-2023, 08:37 AM | #21 | |
Rep 9
Here in Brazil I can find it used, woofers + enclosures (the HI-FI. HK is hard to find). Its plug and play, right?! |
