BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > My screen won't work??
proTUNING Freaks
      11-17-2023, 03:39 PM   #1
GraveChair
Drives: 2016 435xi f36
I just upgraded from my 6.5' display and got an OEM 8.8' display. but when I turned it on the right side of the screen is black I am sure I did the coding right
I did resolution to 8.8' and breites display. Did I purchase a faulty screen or am I doing something wrong?
      11-17-2023, 03:53 PM   #2
Homersbud
Drives: BMW X1
did you use bimmercode to code in the change? if so, use esys as that generally fixes the problem.
      11-17-2023, 06:27 PM   #3
GraveChair
I did use BimmerCode I set the resolution to 8.8’ and display to breites
Also what is esys? Is that an app? How do I use that
      11-17-2023, 06:56 PM   #4
Homersbud
Drives: BMW X1
it’s a windows piece of software.
you need an enet cable & windows laptop then you connect to the car and code in the changes.
https://f30.bimmerpost.com/forums/sh....php?t=1711432
      11-18-2023, 09:03 PM   #5
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Check other settings that may be applicable:
CID_Apix_Mode = APIX1
CID_COM_Mode = MMI
CID_COLOR_DEPTH = 24bit
CID_DISPLAY_RES = 1280x480
CID_DISPLAY_SIZE = 8.8
CID_TOUCH = aktiv
CID_HMI_TOUCH = aktiv
DISPLAY_VARIANTE = breites_display
DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
DIMMUNGSVARIANTE = neue_dimmung
