08-07-2018, 06:52 PM | #23 |
Rep 967
Drives: 2016 F36 435x MSport
Self serve emissions...that sounds damn convenient
08-07-2018, 07:31 PM | #24 | ||
A family of bimmers
2757
Rep 7,743
Being flashed has nothing to do with passing emissions. It's the elimination of a cat that is the problem
08-08-2018, 10:46 AM | #26 |
Rep 1,499
Yep. I'm using OBD Fusion (iPhone) and it has a monitors tab so going to see what it shows with OTS tune vs. modified stock tune.
08-08-2018, 11:32 AM | #27 |
Rep 967
awesome, ill do the same for added verificaiton
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
08-08-2018, 10:51 PM | #28 |
Rep 928
Why not run a catted high flow downpipe? Small loss in power and can still have all 4 sensors ready? Plus pass the sniffer in states that put sensor up the tailpipe?
08-09-2018, 06:31 AM | #29 |
Rep 963
Price difference. Not to mention all catted DPs are not created equal. I had a challenge HFC and it threw a CEL in the first week. There's only one or two companies that guarantee no CEL and the price of those DPs is why people have been trying to find a solution for catless.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
Bimmertodd8852.50 |
08-09-2018, 01:20 PM | #30 | |
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
08-09-2018, 01:32 PM | #31 |
Rep 77
It's not about the maker of the high-flow cats, it's about the concentration they're using.
From what I understand, OEM is 400 CEL, and if you stick with 300 CEL cats chances are you wouldn't throw a code. Most makers use 200 CEL though, so make sure you check before you buy. |
08-09-2018, 03:53 PM | #32 |
Rep 63
I think the ideal situation would be is how do we set all readiness monitors to ready minus the cat monitor. I wonder if that is possible through a map editor in BM3 and doesn't require deeper coding.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
08-09-2018, 05:47 PM | #34 | |
Rep 928
08-10-2018, 07:56 AM | #35 |
Rep 1,499
So this is what my monitors look like running the Stage 2 E30 map. After I run through this take of E30 I'll flash to stock and review monitors again. Next, I'll flash the modified stock map (as per post earlier in this thread) and test again.
08-10-2018, 08:20 AM | #37 |
Rep 1,499
Can you get your inspection early? Best bet is to swap out the DP after inspection.
08-10-2018, 09:38 AM | #38 |
Rep 2,658
08-10-2018, 05:35 PM | #40 |
Rep 2,658
Just spoke to my local guy. He says as long as only one monitor is on, I'm good to go. Here we go!
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
08-13-2018, 11:45 AM | #41 |
Rep 160
So excited to let you guys know that my f32 n55 EWG passed emission test today with stock tune and catless downpipe and without any other mods (simulator or spacer) today.... if you are near Boston or in Massachusetts, you know it's hard to pass without cat. But my guy at a trusted shop just had the inspection stickered !!!!
So much effort spent on reading the posts in the forum ... purchased VRSF dp fix...looked through the tutorials.... nothing worked on EWG... until my guy told me the car needs to be driven in a specific manner so the monitors come on while still before the o2 sends a CEL... I don't know how he did it but he just drove it for some miles and had it passed! .. and he has done three cars successfully...all 2014+ N 55 EWG. |
08-13-2018, 12:25 PM | #42 | |
Rep 1,499
That's awesome news. Any way that you can source the driving procedure and post it here?
08-13-2018, 04:25 PM | #43 | |
Rep 77
The other 7 times the CEL came on as soon as the monitors were "Ready". |
08-13-2018, 06:39 PM | #44 | |
Rep 63
https://www.instructables.com/id/How...or-Smog-Check/ The guy on the N55 FB page said he has done this a couple of times now and if you follow it exactly, it will get all your readiness monitors minus O2 ready for emissions. He said the trick is to try and follow this procedure while using an OBDII reader to watch your readiness monitors in real time. As soon as you had all but one monitor ready, drive straight to the testing station and get it tested. A good tip would be to try and do the driving procedure as close to the testing facility as possible.
