12-27-2015, 10:00 PM | #1 |
Rep 95
uh oh. Got a lemon?
So had the vehicle a week now. I no longer get any sound from the HK system. doesn't matter if its bluetooth, radio, satellite, connected services etc. tried different key fobs that load independent settings etc. checked fuses.
Trunk is intermittently only opening half way, today wouldn't close using the lock button on the hatch, but after a dozen tries, finally closed. One of the fog lights randomly works. sometimes both are on and other times only the left side and the right is out. cant figure out how to recreate it. One time I was looking at the reflection in the glass of a business i was parked in front of, both were on while I was backing up, went into drive and the right one went out? Super pissed off that a $70k freaking vehicle is having stupid problems like this. Not a happy owner. |
12-27-2015, 10:10 PM | #2 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
What model, line, etc?
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-27-2015, 11:38 PM | #4 |
Rep 50
The fog lights actually work like that it depends which way you are turning and they turn on accordingly and when reversing both turn on
"To provide this additional light, the fog lamps are fitted with integrated swivelling reflectors; alternatively, the headlights are equipped with an additional lamp. When the indicator is activated at speeds below 40 km/h, these lights illuminate an area to the side of the vehicle, up to 80° of the direction of travel. After the corner is taken, the cornering lights dim and extinguish automatically. Cornering lights also facilitate safe reversing: when reverse gear is selected, both the left and right lights illuminate the area around the vehicle." Last edited by 335penguin; 12-27-2015 at 11:56 PM.. |
12-28-2015, 01:26 AM | #5 |
Rep 902
I'd bring it to the dealer it's a new car but you can also check the amp connections in the trunk under the carpet. Simple check for the HK issues. Trunk opener you gotta go to dealer most likely. Also fogs ^^^
12-28-2015, 06:30 AM | #6 |
Rep 964
Sorry to hear that. Straight back to the dealership with it.
I hope they will be as keen to sort everything out as they were keen enough to take you bill fold!
E46, F30 lastest F34 GT 330D M-Sport Plus
12-28-2015, 09:35 AM | #7 | |
Rep 95
Do you know where about the amp is located one I lift up the floor panel? I looked for it but wasn't quite sure how the carpet came out. Had a leak in my Z4 and the trunk filled with water and fried the amp. $800 for a used one. Sure would hate to think this car is leaking. Will call the dealer this morning. |
12-28-2015, 10:36 AM | #8 | ||
Rep 902
12-28-2015, 12:33 PM | #9 |
Rep 95
Update
Ok, in the daylight was able to go through the fuses, thought the fuses in the guide with the speaker icon would be the ones, they all checked out fine, there is another icon for i guess is a head unit, a 40amp fuse was blown so that likely is the culprit. Question is why is that blown? I don't listen to music loud because of my tinnitus. I lifted up the back panel and didn't see anything suspicious but will everything there is kind of covered by a metal panel that needs to be unbolted. |
12-28-2015, 02:20 PM | #10 | |
Rep 902
12-29-2015, 12:23 PM | #11 |
Rep 95
Got an Update from dealer today:
Trunk Hatch only opening part way. the alignment on the arms was out and would sometimes get stuck. They have re-adjusted that. Defective amp and battery: They are installing a new amp and battery today and re-installing all the software on the car? not sure why they have to do the software but lets hope that works. The behaviour with the lights going on and off is normal when they are not manually turned on. They will auto turn on while parking and turning or something like that. will have to check that out when I get the car back. |
