02-12-2013, 01:28 AM | #2619 | |
Rep 1,892
If you are at F020-12-11-505, then you need 48.3. You can check your integration level of your car using this procedure: http://www.f30post.com/forums/showpo...postcount=1403 When you successfully coded your CIC and others, did you do it with just the new 48.3 CAFD files, or with a complete 48.3 install? |
02-12-2013, 01:46 AM | #2620 | |
Rep 51
02-12-2013, 04:13 AM | #2621 | |
Rep 67
02-12-2013, 06:42 AM | #2623 | |
Rep 67
6NH to 6NK
Can you send me instructions on how to code my car from 6NH to 6NK. I have Prof Navigation with 6NH. Also, where can I find all the coding files and how can I get them. Thanks Rajesh |
02-12-2013, 07:56 AM | #2624 |
Rep 49
02-12-2013, 09:11 AM | #2625 |
Rep 51
There are some steps necessary. Basically you have to follow Guide 3 (E-Sys - Getting Started Supplement - Part 3.pdf ) of the documents which are attached on initial post of this thread to change from 6nh to 6nk. Afterwards you just hit the code button for HU_CIC and CMB_Media in the code section in expert mode.
02-12-2013, 09:21 AM | #2626 | |
Rep 51
<<<<------ That was last night. This morning started my car and went to BMW Live. Now I got a wizard for selecting my country and so on. But after setting up - I now get a different error message. Whats up there? Do I still need to change VIN? The wizard did not came up last night. |
02-12-2013, 10:27 AM | #2627 | |
Rep 40,720
Changing from 6NH to 6NK is quite simple. Edit your FA (VO) to replace 6NH with 6NK. Load and activate modified FA, and VO code Head Unit and Combox if you have one.
02-12-2013, 11:29 AM | #2628 | |
Rep 49
02-12-2013, 11:31 AM | #2629 |
Rep 40,720
No. Assuming you had the hardware required for Voice Control, Voice Control requires an FSC Code Imported and Activated in CIC or NBT.
02-12-2013, 12:12 PM | #2630 | |
woof
84
Rep 1,233
When I coded my CIC, I did not do a complete install. Just removed the old psdzdata folder, and moved in the 48.3 psdzdata folder -this is the method which worked for cic, rem, kombi, but not fem_body. I attached the log here. It's capturing when I try to code fem_body and it's consequent failure.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
02-12-2013, 12:23 PM | #2631 |
Rep 49
02-12-2013, 12:23 PM | #2632 |
Rep 40,720
To get BT Streaming.
02-12-2013, 12:28 PM | #2633 | |
Rep 1,892
Don't hassle with 48.3 until you need it. |
02-12-2013, 12:40 PM | #2634 |
Rep 10
I configured and installed a virtual XP and 7 with E-sys 3.18.4 and psdz 48.1 on my MacBook with both Parallels and VMware fusion but I was unable to get a working connection. Now troubleshooting back I found I do not even receive an ip address on my MacBook 's network adapter other as a 169.254.x.x (apipa address). This basically explains why it is not working in a virtual windows xp/7 as I do not receive an IP address on a normal network adapter.
Now I am wondering if anybody knows which IP address, subnetmask has to be configured manually to make a connection if dhcp is not working ? Grtz, Ray Last edited by RayF31; 02-12-2013 at 12:51 PM.. |
02-12-2013, 01:09 PM | #2635 | |
woof
84
Rep 1,233
Would anyone mind PMing me the download links for 48.1?
02-12-2013, 03:56 PM | #2639 |
Rep 18
Hello everybody. I'm an F20's 125i italian owner.
I looked for a topic where introduce me but didn't find anything. I have some problem with my car: I bought it in Germany and it's fully specced with all the necessary for connectivity: nav prof,internet,bmw online, bmw live,apps etc... The problem is I can't connect to bmw online via bluetooth connection of my phone, neither I can access to emails and text messages from it. I can just look at my contacts but nothing more and so I cant access internet via my phone neither via car's connection. I've read that maybe there's something to code to make internet or bmw live or bmw online (didn't understood well ) works on my car. Can someone help me? Thanks very much! |
02-12-2013, 05:15 PM | #2640 |
Rep 83
