06-01-2018, 08:55 AM | #23 | |
Rep 1,288
Drives: 2014 435iX, FBO
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
06-08-2018, 10:11 AM | #24 | |
Rep 3,535
06-20-2018, 11:13 AM | #25 |
Rep 3,535
So I contacted K-Mac and they said the camber bushing really does give you +/- 2deg of adjustment (4deg range).
They also said if I can get them measurements of my xDrive caster bushing that they can manufacture a compatible one in one week. I'm going to try and get those measurements this weekend. |
03-05-2019, 02:30 AM | #27 | ||
Rep 10,473
Comments or Results? |
03-05-2019, 11:41 AM | #28 |
Cheapskate
4445
Rep 4,993
IK6SPEED4486.00 |
03-05-2019, 11:46 AM | #29 |
Rep 10,473
So you haven't moved forward with this, based on comments there?
03-05-2019, 12:07 PM | #30 | |
Rep 3,535
Kern's linked my thread for the camber bushings.
For the tension strut/caster bushings I've only mentioned some initial things here and there on the 2-series forums, and am still feeling them out. Here's my initial impressions: Quote:
One thing I noticed the week after my off-roading was I started to get some creaking when braking and accelerating from a stop. This past weekend I put the car up on my quickjack and found that was due to the bolts that hold the tension strut bushing to the subframe weren't properly tightened (100 Nm, 74 ft-lbs). They each had about a quarter turn to go before being fully tightened. I'm not sure whether this was due to the alignment shop not fully tightening them, or the vibration of the harder bushing making them loosen up. I'm going to be hitting the dirt trails again this weekend and will see if the noise returns. Thus far I'd say if you're prepping your car for HPDEs or just weekend sportiness the tension strut caster bushings can give you what you're looking for, for better steering response, feel, and caster adjustment. If you want your car to be a comfy cruiser, I'd probably skip them due to the added NVH. I'm on the fence whether I'll keep these or not (I might try the powerflex "street" non-adjustable tension strut bushings for more road comfort). Last edited by FaRKle!; 03-05-2019 at 12:12 PM.. |
01-25-2020, 12:28 AM | #31 | ||
Rep 5,390
'15 335ix, KoniSA's, Eibachs, H&R Sways, strut brace, 245/40-18 MPS4S tires It's a street performance sleeper car that we also drive on trips so I don't want to lose the comfort that we've put in with some of the suspension choices like KoniSA's and tires. Any advice is appreciated. |
01-25-2020, 05:12 PM | #32 |
Rep 128
Good luck with anything KMAC.
I used to recommend them as they are a local Australian manufacturer and are just down the road here. But one cracked camber plate and one out-of-spec camber plate later, I no longer trust in Kev's work. At the end of the day, the eccentric camber bushes from KMAC are still a very hard PU. And from what Graham of Superpro has told me (and many others on these forums already know), PU isn't a suitable material for the lower control arm joint. |
01-26-2020, 12:14 AM | #33 | ||
Rep 3,535
The caster monoballs I've had for 15,261mi and 6 track days (day 7 tomorrow) and also still recommend.
01-26-2020, 06:23 PM | #34 |
Rep 128
