01-09-2018, 11:48 AM | #89 |
Rep 1,615
Ralph335 Thankfully it warmed up today (36) so I finally switched off. (was getting boring and I was even starting to think negatively: trading for a 5 series!) Had to kill that thought haha
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
01-10-2018, 02:41 PM | #90 |
Rep 311
Drives: F31 M Sport
Sorry about the delay, I have a G3500.
https://no.co/g3500 |
01-11-2018, 08:24 PM | #91 | |
Rep 156
The wash spot is tucked away among other people's spots, so there's not a way to access that outlet without blocking people, unless you happen to be the owner of the spot next to the wash spot. |
01-11-2018, 11:04 PM | #92 | |
Rep 1,502
01-14-2018, 07:44 PM | #93 |
Rep 1,986
I've been getting this error on my 2016 340 xDrive w/16k miles on it. It also shuts down anything that uses the battery when i turn my car OFF such as the idrive, headlights, and even the ceiling lights!
I drove 120 miles today over the course of 5 hours and it still gave me a low battery message every time i started the car telling me to drive the car more. 120 miles is a long drive. Not sure how much more I need to drive it, but tomorrow, i'll be driving 125 miles each way to go skiing. Hopefully this is not an issue after. |
01-14-2018, 09:05 PM | #94 |
Rep 16,082
A full charge might take 12 miles, it certainly won't take 120. Did it do this the other day when the temperatures hit 50? Or only when it's down below 15?
01-16-2018, 08:37 AM | #95 | |
Rep 250
My apartment garage doesnt seem to care. I've ONRed my car numerous times in my spot with no complaints from security. I've even seen people spray paint their wheels up on the upper floors.
2014 335xi M-Sport : Alpine White | Coral Red
01-17-2018, 11:45 AM | #96 |
Rep 119
I thought you need to put the fob near the steering column if the battery is dead. The key is for the door and glove box isn't it?
01-17-2018, 12:36 PM | #97 |
Rep 1,170
You are correct, please substitute "on the steering column" for "in the steering column" and dam, can't put anything past this crowd. I guess I'd better spend some time and .
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
01-17-2018, 01:36 PM | #98 |
Rep 29
I had this problem of a battery discharge warning on my 2015 F30 328xi. The local dealer claims they reprogrammed the system so that it reduced the tolerance level before it would report the message. Long and the short of it is it did not work, revisited the issue with the dealer recently and the response was basically you will have to live with it as no fix from BMW is forthcoming. This issue and other issues (plastic timing guide prone to breaking) resulted in me getting rid of the vehicle before the warranty expired..............problems solved, permanently.
Daylights |
01-17-2018, 01:55 PM | #99 |
Rep 16,082
Notice the locations of all those reporting the issue. Conspicuously absent are places like Florida, Alabama, Louisiana. It's a cold weather thing, and all it takes to be sure that you're never left out in the cold, as it were, is to use a battery maintainer. If that's beyond your skill set put a piece of black tape over the dash warning, get on with your life.
01-17-2018, 02:05 PM | #100 | |
Rep 1,986
01-17-2018, 10:01 PM | #101 |
Rep 156
Here's a weird update: I got the message back, exactly once. After driving to a friend's place on the other side of the suburb (round trip about 50kms), leave my car outside till night, then drive back home. Got the message when turning off the car...
...but after driving a super short trip the next morning to the grocery store, no messages whatsoever. Even for the past week I've been leaving my car cold outside the train station for the whole day, still nothing. Still scratching my head over this one. |
01-18-2018, 01:49 PM | #102 | |
Rep 1,170
edit: I'm wondering if the outside temp is given more "weight" than the batteries actual State of Charge in the algorithm used to trigger the warning.
01-18-2018, 04:53 PM | #103 | |
Rep 156
Beek707.00 |
01-18-2018, 07:35 PM | #104 |
Rep 156
Because legally you don't own the spot when you own a condo/apartment. What you have is exclusive use to it, but it's part of the building's shared facilities and it's bound by the condo corporation's rules. Same goes for your unit's balcony... that's the key difference between a freehold and an apartment.
02-03-2018, 09:19 AM | #105 |
Rep 156
So.... more battery weirdness.
Was working from home on Thursday, didn't drive to the train station until Friday, car was parked underground. When I got to the train station on Friday, charge battery warning came back. Figured nothing I can do, left it there all day at -12C. When I returned, I drove from the train station to the grocery store a block away... everything was normal again, no warning. Can't explain that... aside from battery getting old and that overnight drain a while back nearly killing it. |
02-04-2018, 11:17 AM | #107 | |
Rep 156
Either way I parked all night outside again covered in snow, still no warning. Maybe I'll just do a battery test the next oil change. |
02-04-2018, 11:29 AM | #108 |
Rep 16,082
You can do a battery test every time you get into the car, just plug one of these into your auxiliary outlet:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
02-05-2018, 09:20 AM | #109 | |
Rep 156
02-05-2018, 09:40 AM | #110 |
Rep 16,082
Going on a charger for a few months won't have any more effect than a few hours, depending on the charger capacity. If you're putting the car up for the summer then having a maintainer on it is a good idea, as there's always drain on the battery.
ls3c6fartsucker, ls3c6sucksfarts |
