BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > N47 timing chain recall
      01-22-2015, 10:47 AM   #1
Bala
Romania
Drives: E60 520d
Finally it is official.
A few days ago, a recall action was started for the N47 timing chain problem.
Only some cars are selected for the recall so you will have to ask first your dealer if your car is included in this action or not.
My car was built in dec 2007 and it will be repaired by BMW
      01-24-2015, 06:51 AM   #2
HighlandPete
Drives: BMW F11 535i Touring
What counties does this apply to?
Any direct links to the recall info?
HighlandPete
      01-27-2015, 01:46 AM   #3
Bala
Romania
Drives: E60 520d
In Romania and in Moldavia. I guess it is available all over Europe.
It started as a rumour on a forum and several users (including me) contacted the dealers. The dealers confirm it.
I don't have links to the official announcement.
      01-28-2015, 01:44 PM   #4
swagon
swagon's Avatar
Drives: F80 6MT
Any more info?
      01-28-2015, 03:20 PM   #5
Rufio
Poland
20
Drives: E93 330d
Here is info:
https://drive.google.com/file/d/0B52...o4NE8wanc/view
      01-29-2015, 04:39 AM   #6
Bala
Romania
Drives: E60 520d
Thanks ! Yes, that`s the recall.
      01-29-2015, 05:27 AM   #7
HighlandPete
Thanks for the link to a BMW document.
I wonder how big this recall will become?
HighlandPete
      01-29-2015, 10:05 AM   #8
swagon
swagon's Avatar
Drives: F80 6MT
Thank you very much indeed. They're right in time as the chain on my car has started recently making noise.
      02-03-2015, 01:28 AM   #9
Bala
Romania
Drives: E60 520d
Mine too (108.000km).
Hopefully, they will replace also the chains, not only the tensioner.
      02-03-2015, 04:13 AM   #10
swagon
swagon's Avatar
Drives: F80 6MT
I'm at 96k km. It can be hear when you're close to a wall or something and when you're turning off the engine. I'll call the local BMW dealer and ask them.
      02-06-2015, 04:57 AM   #11
Bala
Romania
Drives: E60 520d
Only the upper timing chain will be replaced in my case. And of course the tensioner.
      02-06-2015, 10:44 AM   #12
HighlandPete
To clarify... the dealer called you in to investigate whether your N47 had timing chain issues? Or were you already in discussions?
HighlandPete
      02-26-2015, 04:09 AM   #13
mitchgixer6
Drives: E61
Hi guys. Thanks very much for posting this information. I own an E61 so wouldn't normally look here, but I came across this thread whilst looking for something else.
I called my dealer and they had no information regarding this recall. I'm in the UK. They checked my vin and there were no outstanding recalls, so can only presume either I'm not covered by this or that BMW UK don't have any plans to honour it. If anyone has anymore info that would be great.
      02-26-2015, 06:40 AM   #14
Bala
Romania
Drives: E60 520d
I had my upper chain and tensioner replaced for free at the dealer based on this recall so for sure the recall is real.
      02-26-2015, 01:54 PM   #15
mitchgixer6
Drives: E61
Bala
Did you have a noisy chain before the repair? Or did your dealer call you to bring the car in for repair?
      02-27-2015, 12:49 AM   #16
Bala
Romania
Drives: E60 520d
They are not measuring the noise of the timing chains.
The only measurement that they are performing is to measure the length of the upper chain. Depending on the result, they are replacing:
- the tensioner only (no elongation or minimal)
- the tensioner and the upper chain (elongation is between some limits)
- the tensioner, the upper chain and the lower chain + guides if the elongation is above a limit
In my case, the lower chain is still making noise so the recall did not solved the problem entirely.
      02-27-2015, 02:38 AM   #17
mitchgixer6
Drives: E61
Yes I understand that. But normally you wouldn't suspect a problem unless the chain was noisy. Was yours noisy which caused you to go to the dealers and request a repair? Or was your car OK as far as you were concerned until the dealer got in touch to suggest you might need some work done?
      02-27-2015, 02:54 AM   #18
Bala
Romania
Drives: E60 520d
Yes, the care was OK (at least the dealer didn't check it before).
I just asked the dealer by email if my car is included in the recall or not.
      02-27-2015, 06:52 AM   #19
mitchgixer6
Drives: E61
Ok thanks for that. Just to confirm where do you live? I think they're treating it differently here in the UK.
      03-02-2015, 01:04 PM   #20
steff87
Drives: e61 & e36
@mitchgixer6
When was your e61 built?
In Germany only the 07 / 08 models are affected by this recall.
And it isnīt an official recall here in Germany too. You must ask your dealer if the vin is affected or not.
      03-02-2015, 01:37 PM   #21
mitchgixer6
Drives: E61
Build date was September 08. I've got the CIC idrive controller but running CCC, so I'm thinking I may be just late enough to miss this. :-(
      03-04-2015, 09:59 AM   #22
mitchgixer6
Drives: E61
Hi all. I've just signed up after reading this post. I own an E61 so wouldn't normally look here. Thanks for the info. I phoned my dealer today to be told there are no outstanding recalls for my car. I asked specifically about this but they had no knowledge of it. I'm in Scotland. I might ask at a different dealers in a few weeks.
