01-16-2015, 03:24 AM | #111 |
Rep 9,709
01-16-2015, 03:28 AM | #112 | |
Rep 19,982
Maybe I should steal some other M3 components whilst I'm at it then, try and get better value for the labour involved. Or just do the whole lot.
01-16-2015, 03:31 AM | #113 | |
Rep 9,709
I also wonder if M3 ARB are compatible? |
01-16-2015, 03:33 AM | #114 |
Rep 1,152
01-16-2015, 03:33 AM | #115 | ||
Rep 19,982
01-16-2015, 01:16 PM | #116 | |
Rep 355
I don't have adaptive, as I plan to go all the way, but the mix of springs & ARBs (delighted I've collected another TLA!) could well be a good option for people who want to keep adaptive. I notice ACS RS kit for xDrive cars includes a 'mandatory stabiliser' which I'd guess replaces the weedy standard effort at the rear. I'd guess the increase in diameter at front on the setup I'm getting is less to avoid making the car push on. Hoping the ride won't suffer too much, though I'd guess the bigger bars will mean harsher ride over motorway expansion joints and speed bumps. It'll be interesting to see ... |
01-16-2015, 01:27 PM | #117 |
Rep 19,982
Stiffer arbs shouldn't affect the ride on motorways too much, more when you've got a bump on one side, as you get a bit more lateral stiffness.
Curious to know what the various diameters are of what Birds fit, then what standard and then what the ACS RS kit is. I guess the main thing is that the rear is relatively stiffer than the front in order to dial out a bit of understeer.
01-16-2015, 01:52 PM | #118 |
Rep 32,881
M3 arb looks quite different:
01-16-2015, 03:59 PM | #119 |
Rep 9,709
Good find......yes looks like the M3 attaches underneath and the normal F3x series attaches on top of subframe. That''s that idea put to rest then.
Good news is the rear one looks very similar. Last edited by NISFAN; 01-16-2015 at 04:05 PM.. |
01-16-2015, 04:32 PM | #120 | |
Rep 355
In some ways, it feels like a crudely tuned car, where an inexperience owner has done engine mods before sorting out suspension - it really does feel that far out of balance in terms of the mix of sheer grunt and basic stability in bends at perfectly sensible road speeds. I could understand this if it was a 420d, but on something like this, it's plain daft. You do get the sense of something very good being buried deep down under all the crappy springs and dampers and the heavy feel. Really looking forward to seeing how it drives next week. All this makes me wonder how a 430d or a 435 would feel in stock form by comparison. I'm guessing BMW don't allow the 'joy-killer' team to spend as much time on joy killing on those models. |
01-16-2015, 04:48 PM | #121 |
Rep 19,982
Yes the beefy rear ARB is the key I'm sure!
I've no doubts that the basic fundamentals of the 3 series platform are great, but it's the decisions on set up and quality/spec of some of the componentry that let it down. I'd also be curious to see exactly what changes Alpina made with their cars. Different springs, but they use the same dampers, but run different settings, and they use different bushes I believe.
03-08-2015, 05:17 AM | #122 |
Rep 47
Since I haven't heard anything negative about the rear subframe bushings of the F30, I would like to know what did they do better?
Is it just a more solid bushing? Or are we still blinded by having a new car or the suspension components are only going to be soft in a couple of years time? |
03-08-2015, 05:28 AM | #123 | |
Rep 32,881
10-22-2016, 03:13 PM | #124 |
Rep 50
NISFAN, I'm in the US, and maybe I'm looking in the wrong places, but I can't seem to find the Bilstein PSS10 B16 Comfort coilovers. Is there a separate PN for the Comfort set vs standard B16?
Your help is truly appreciated! |
10-22-2016, 03:28 PM | #125 |
Rep 9,709
I will double check for you tomorrow, but pretty sure they were 48-229012
10-22-2016, 07:16 PM | #127 |
Rep 60
I was also looking for these on the Bilstein US website. This was the closest thing that I could find –
BILSTEIN B16 (PSS9/PSS10) http://www.bilsteinus.com/products/p...-b16-pss9pss10 I did confirm that the part number: 48-229012 is correct for this set of coilovers. They also have a video here – BILSTEIN B14 & B16 Suspension Kits - Product Spotlight https://www.youtube.com/watch?v=YwgvjKnaKdU |
09-13-2017, 12:55 PM | #130 |
Rep 9,709
09-13-2017, 01:03 PM | #131 |
Rep 2
09-19-2017, 06:53 AM | #132 | |
Rep 922
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
