BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WA Extended Cluster Retrofit
      04-15-2015, 12:52 AM   #1
Coolala
Japan
38
Drives: 2013 F30
Hi,
I'm going to retrofit 6WA extended cluster to a F20 (with NBT) and also to a F30 (with NBT) for my friend. I found some posts here mentioned that after we add new 6WA unit and with MOST connected NBT and cluster, the Esys cannot recognize the new hardware and thus cannot even code it.
1. Is there something (hardware?) needs to do if I encounter this problem?
2. There also mentioned "inject cadf", what is it and how this can be done using Esys?
Since I may transplant my old cluster to another car...
3. How to clear VIN? Mis-match VIN will make the red dot appear.
4. How to reset or adjust the mileage meter to 0, so after connecting to the car the car's own mileage memory will write on it?
Any help appreciate!
      04-30-2015, 06:45 AM   #2
mightycrown
Drives: f31 320d black sport
Originally Posted by Coolala View Post
Hi,
Check the pdf
      05-01-2015, 09:36 AM   #3
Coolala
Japan
38
Drives: 2013 F30
Originally Posted by mightycrown View Post
Check the pdf
Thanks!
      06-16-2015, 07:52 AM   #4
Paul13F30
Drives: 2013 328xi
Sorry to hi-jack but I was looking to do this as well and was wondering if I need any additional hardware or is the cluster all that's required.
I'm going from basic kombi with no nav. I've read some posts that a most cable is needed but I'm assuming that's for not equipped cars
Thanks and pardon my ignorance
      06-16-2015, 02:27 PM   #5
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
you need most cable otherwise kombi will not communicate with your car
Kombi communicates through your head unit via MOST
if you are coming from non-nav head unit you may not have a MOST connection on it. If that is the case you will need to upgrade your head unit as well
if you have basic kombi with no nav and HK sound system you will have a most loop that goes to HK system and back.
you will need to modify this loop to incorporate your 6WA as well.
fe7565552.50
      06-16-2015, 04:30 PM   #6
Paul13F30
Drives: 2013 328xi
Is there a way to tell without taking the front apart? I have no nav or HK sound. It's a base model.
      06-17-2015, 08:27 AM   #7
Chris@codemybimmer
unfortunately there is no way to tell without taking out the head unit in your car.
it seems to be hit or miss.
my car is a base 328 xdrive but i have the most connection. my buddies 328 x drive base model does not and we have the exact same options xenons and premium pack (sunroof and folding rear seats).
      03-19-2019, 07:20 AM   #8
Elmo111
Drives: BMW 118d Urban
      03-20-2019, 01:19 AM   #9
Vortex8
Drives: BMW GT 328xi
Hello,
I have also a question. When I have the HU_ENTRY and basic KOMBI, do I need to upgrade to 6WA in order to facilitate NBT_EVO retrofit ?
      09-24-2020, 08:38 AM   #10
Milenlukov
Drives: bmw f31 320d
Hello colleagues, today I decided to upgrade to 6wa, but when I downloaded the eeprom, I accidentally broke it ... can any of you send me the bin file for the eeprom, please, thank you for
      01-22-2022, 01:38 AM   #11
Veba21
Drives: Bmw 328 f30
I did the same, have you found the bin file if you have it can you send me please? Thank you!
      01-23-2022, 04:30 PM   #12
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
Check the pdf
this is very bad HOWTO for newbies who does not know what they are actually doing, as it involves flashing which is totally not needed for a KOMBI retrofit and is very risky to brick that new and dreamed of instrument cluster.
if your KOMBI does not show up in ECU list you need to change your SVT tree in VCM.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      04-10-2022, 09:46 PM   #13
Lamora01153
Lamora01153's Avatar
Drives: 2013 BMW 328i
Check the pdf
How does one go on about making Kombi show up? Mine does not show up in my BimmerCode but the vehicle features say it does have 6WA included
6wa, nbt, retrofit, vin
