12-12-2014, 02:29 PM | #1 |
Rep 817
Drives: bmw M3 F80
Seats electric bmw F30/F32/F80/F82
hello here is the wiring diagram to add the 2 front seats electric heating for BMW F30 identification taken under the seats Taken under the driver's seat: X14*1B et X14*2B Taken under the seat Passage X12*1B et X12*2B view of the connector position fuses F64 / F65 / F67 / F68 a fuse box engine compartment Z7 * 9B Rear Electronic Module A174 X227*1v A174*14B Front Electronic module A173 A173*8B view of the connector X154*1V/X154*2V In case the son is already set up on decision A173*8B then log on X154*1V/X154*2V Location of the masses under the driver and passenger carpets Wiring to connect the driver's seat X14*1B X14*2Bdecision should already be connected (airbag and safety belt) Last edited by david51; 04-11-2019 at 04:09 PM.. |
01-16-2017, 07:42 AM | #3 |
Rep 817
Drives: bmw M3 F80
02-06-2017, 08:20 AM | #5 |
Rep 817
Drives: bmw M3 F80
02-22-2017, 01:19 PM | #6 |
Rep 12
Hi Davis51,
I am doing a upgrade from manuel sportseats with heating to electric seats with memory and heating this weekend. I am a little confused about the wiring. Do I need both CAN and LIN bus to both seats or are LIN not necessary? |
02-22-2017, 04:25 PM | #7 | |
Rep 817
Drives: bmw M3 F80
Hello I think the LIN on the 2 seats is mandatory otherwise it will not work |
08-24-2017, 11:34 AM | #9 |
Rep 817
Drives: bmw M3 F80
11-25-2017, 12:57 PM | #11 |
Rep 31
electric seats
Hi Is it possible for me to read the notes please. I have fitted the seats power and Kcan to the seat modules in my F21 125d, the seats work for position and lumbar but not for heating and memory someone has tried to code them the option has been coded but the modules cant be discovered I know the Kcan is there because they wouldnt move at all before I connected the Kcal-l & Kcan-H on pins 5 & 6. The car came with heated (lin bus) and lumbar. Thanks Ed
11-25-2017, 01:24 PM | #12 |
Rep 817
Drives: bmw M3 F80
Hello
here is how to connect the heated seats Driver if you have the big module you have to plug in as the attached photo 5 vers 5 6 vers 6 15 vers 7 16 vers 8 passenger and for the passenger (small module) it's like that 8 vers 3 25 vers 7 26 vers 8 |
06-14-2018, 03:53 AM | #13 |
Rep 3
Hi David,
I know this is an old post but I am hoping that you are still on the forum. I swaped my manual seats with heating with full electric sport seats with memory and heating. Everything works except for the heating indicator, which is not working properly for the drivers side. I can switch on the heating but the 3 LED's turns of after a couple of seconds. The heating is on and I can adjust the heating, but the indicator LED's still turns off. Also I do not get any temperature reading from the backrest sensor, but maybe it is just faulty. As I understand the driver side seat heating on memory seats is controlled by K-can rather than LIN. So I tapped in PIN 5 and 6 in the yellow seat connector to PIN 4 and 3 on the iDrive controller (rather than wirering all the way to the FEM). Rheingold shows the error "E58C49 Seat heating, driver: missing LIN component" There is one more error which is also related to the seat, but I don't think it has anything to do with the heating: "802A08 Personal Profile porting restricted due to lack of calibration" When I try to do the seat standardisation it fails with the error "- Control unit is not encoded" Any help will be highly appreciated. Best, Niels |
06-14-2018, 07:41 AM | #14 | |
Rep 817
Drives: bmw M3 F80
Hello check if you have the 2 negative as in the picture attached |
06-14-2018, 04:11 PM | #15 | |
Rep 10,473
If so, have you made sure the ECU coding is recognizing them? |
06-14-2018, 08:56 PM | #16 |
Rep 817
Drives: bmw M3 F80
06-14-2018, 09:01 PM | #17 | |
Rep 10,473
When I changed mine that was issue. Didnt work until I switched with the older units originally in car. |
07-09-2018, 04:26 PM | #18 |
Rep 817
Drives: bmw M3 F80
04-01-2019, 05:05 AM | #19 |
Rep 3
Hello David,
Sorry for troubling you with this but I was hoping to do this seats conversion myself and was hoping if you can assist me with it. As I am not a smart cookie any detail/pictures you can provide would be much helpful including where to start etc. Many thanks |
04-01-2019, 06:45 AM | #20 | |
Rep 817
Drives: bmw M3 F80
I put the pictures back on the first page |
01-22-2020, 10:28 AM | #21 |
Rep 48
IT NOT view the pics.
i have this problem. MY f31 5/2015 basic, now it's have HU PRO ID4 and now installing the SEAT HEATING SPORT. but, now not working the MEMORY seat and HEATING. I HAVE PUT INSIDE THE A173*8b PIN 51 and 52 the pin 5 and 6 from X14*1B K-CAN-H and L. do you have an idea about WHY it not working? thanks in advanced for responding |
01-22-2020, 03:13 PM | #22 |
Rep 6
F80 Seats into F30
Wondering if anyone could help me.....
I've got a 2017 LCI F30 with heated seats and electrical lumbar support but manual adjustment. I've bought a 2015 m3 F80 interior but there is 4 extra pins on the connector block of the new seats. Does anyone have any know how to wire this into the main harness. Do I need to swap airbags/ seat tensioner etc. From the old seats onto the new seats? Is there any coding required ? Any help/advice will be greatly appreciated... |
