06-15-2014, 04:26 PM | #1 |
Rep 268
Is it possible to change the interior trim?
I would like to place an order for a 428i GC M-sport with coral red interior, but the configurator forces you to choose the aluminum trim on the dash and door handles. I personally prefer the high-gloss black trim that is available in Sportline. Since I don't have this option, I am thinking about placing the order with the aluminum trim and then hopefully swapping it with high-gloss black. Is this easily doable? Any idea about the cost?
Previous
2018 M3, 2015 F36 428i GC; 2007 E92 335i; 2002 E46 325i |
06-15-2014, 04:39 PM | #2 |
Rep 1,029
You should ask your CA if the BLACK PIANO trim is available as individual option.
It will be a bit more $$$ but it will look very nice!!! Good luck!!
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
06-15-2014, 08:45 PM | #5 |
Rep 169
Even better, ask your CA if you can request the trim you want along with the M-Sport line. I'm honestly not sure if it is possible, but worth the try since it would save you time and money. I find it rather annoying that some of the color, trim, and other options are so limited by line, model, series, etc.
06-15-2014, 10:33 PM | #6 |
Rep 1,093
Of course it's possible. Check out the trims people are selling under member classifieds -> interior. There's also a detailed thread about how to change the trim in the DIY section.
But what I doubt is, whether 3 series and 4 series trims are interchangeable i.e can you put a 3 series trim on a 4 series car? The dash looks the same at a glance, but there could be subtle shape/size differences making them incompatible.. Of course, buying the car with the right trim will save you money if you can pull that off. But in some cases I believe it's not possible. For example you can't get anthracite wood with sportline.
Has a bad car addiction
