05-23-2015, 05:41 AM | #1 |
Rep 7
Calculation keeps showing CMB_MEDIA in SVT
I'm trying to flash NBT with v55.4 my VO only has 609 and 6NS added. But when I do a TAL Calculation it shows CMB_MEDIA ecu in Red in SVT. All other ecu's are in black.
I've no idea why it's showing CMB_MEDIA but no matter what I do to VO it always shows up in SVT after TAL Calculation. It doesn't show in normal Read SVT in coding expert mode. It's picking up this ECU from somewhere !!. Confusing. Anybody know what is going on ?. |
05-23-2015, 05:45 AM | #2 |
Rep 7
The main issue I specified here is the fact that when ever I do TAL Calculation to flash, it always shows CMB_MEDIA in ECU. And I don't know why ?.
The problem I had last time was that the flashing started and it seemed to skip parts of the flashing process. By this I mean, that it started the process with HMI B, then went on to CoreMediaConNav. Missing out TTS, SPEECH, SSs etc. The NBT stayed at version NBT_i14725A same as 54.1 but I actually used PsdZData 55.4 and I have now learned that there was no update for NBT in 55.4 so this may answer this problem. |
05-23-2015, 05:52 AM | #3 |
Rep 7
Tried re flashing NBT with update PsdZData 55.0 and it only flashed one section as below. Now navigation does not work properly, the map is moving me sideways and the spoken instructions are random. GPS seems faulty or corrupted.
If I try to re flash it does not see the NBT as requiring an update now in ESYS. It is since I flashed and it updated 'CoreMediaConNav' part of NBT. How can I get a full reflash for NBT because it will not see NBT as requiring update now. Is it possible for downgrade ?. How ?. A lot to take in I know but any help appreciated with this. Thanks. |
