02-27-2016, 03:30 PM | #1 |
Rep 89
Socket for torque wrench
Hi,
Today I've ordered a torque wrench (http://www.ebay.co.uk/itm/290847424907) that will help me apply the proper pressure when removing/putting back my car's wheels. Any ideas what kind of socket I need for that particular torque wrench (drive: 1/2")? Any ebay links would be much appreciated. Thank you! |
02-27-2016, 03:51 PM | #2 | |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
17mm Protective Rim Wheel Saver Socket for BMW, Mercedes Benz, Audi, Mini Cooper https://www.amazon.com/dp/B00QF72GYA..._EMH0wb3ZGBSQ7 You can also buy on their site https://www.burgertuning.com
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
02-27-2016, 04:59 PM | #3 | |
Rep 89
Which tool you use when removing the bolts using this, the torque wrench? |
02-27-2016, 05:21 PM | #4 | |
Rep 902
I use an impact wrench to remove my wheel bolts, since most of the shops I go to, especially BMW dealers, like to torque the hell out of my wheel bolts with an impact wrench. Last time i got my car back from the dealer my bolts were torqued to 700+ ftlbs, spec is 103 ft lbs. I use my air tools to remove and start to install bolts, but tighten them down entirely to 103 ftlbs with my 1/2" torque wrench. I keep my 1/2" torque wrench with one BMS wheel saver in my trunk just in case, and have another BMS wheel saver I use with my air tools.
02-27-2016, 05:27 PM | #5 | |
Rep 89
700+ ftlbs that's crazy. I'd never let them do that, would prefer to do it myself. I've just ordered something similar to the BMS wheel saver http://www.ebay.co.uk/itm/381488416467 Dispatch is cheaper. Hopefully the quality is similar. Thanks |
02-27-2016, 05:36 PM | #6 |
Rep 89
By the way, would something like this http://www.ebay.co.uk/itm/1-2-Drive-...MAAOSwll1WxBNW be a good option for bolt removal using the saver socket?
02-27-2016, 09:25 PM | #7 | |
Rep 16,082
02-27-2016, 10:40 PM | #8 | |
Rep 902
You'd struggle with that tool to break bolts tightened by power tools which basically all shops do.
