06-08-2023, 02:40 PM | #1 |
Rep 27
rwd 340i 15mm front 12mm back? (spacers)
Has anyone had this setup? I bought 12mm and 15mm but 15 rubbed in the back. So idk if I should swap them or run 12mm all around
06-08-2023, 03:53 PM | #2 | |
Rep 332
12mm front 15mm rear Are you running oem alloys as this is size for oem spec alloys. As if you already have a wider rear with the spacer may be causing the issue. Oem 704m 422m 19’s are only 9.5 wide. |
06-08-2023, 07:52 PM | #3 |
Rep 27
I’m running 403m on hr super sport springs.
06-09-2023, 12:17 PM | #4 |
Rep 332
