BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Who says the factory boost control system can't make big power?
01-03-2008, 12:49 PM | #1 |
Rep 2,587
Hey gang,
For kicks I decided to throw a dual cone air filter setup on the car to see what it would do. In the process I might have set a 335i record for the most power for the least dollars spent. Here is the mod sheet: JB2HR: $499 UR DP: $550 Cone air filters: $80 Total: $1129 Everything else on the car including catback, 2nd cats, resonator, diverter valves, etc is all stock. Only other mod is K1 rims w/ drag radials @ 28psi tire pressure. The car doesn't even have the golf tee mod. The car is using the factory boost control system with one solenoid bypassed, and boost was very steady across the board with a light roll off to redline. No spikes, camel bumps, boost bombs, or surprises. Also before I post the graphs I do not suggest people push their cars this far, at 15psi+ boost, even on race gas, bad things can happen. It's not good for the long term. But it does make for a dyno day! Runs 16 & 17 are the normal JB2HR with the new air intake. Power jumped up to 392rwhp/432rwtq! Boost spiked to 15.5psi and held around 14. Then for runs 18 & 19 I decided to throw in a second hot pill (not suggested!), and power jumped up to 402rwhp/453rwtq!!! Boost spiked to 16.5psi and held around 15. Ambient temp was 65 degrees and the correction factor was 2%. |
01-03-2008, 12:58 PM | #6 |
Rep 660
Nice "JUICeY" Numbrs Terry!
Need to change your sig. now...... Looks like your the Big Al of the Bimmer "tooners"!!!!!!!! Cheap flow "$" .......Big Go !!!!!!!! |
01-03-2008, 12:58 PM | #7 |
Rep 2,587
Nah I just bought them from another forum member, they kind of suck on the street but the power is there. Just buy two filters w/ 3" opening, have a muffler shop make two 2" -> 3" transitions, and away you go.
01-03-2008, 01:00 PM | #8 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
haha... those are the home brew intakes I made a few weeks back. Funny to see them end up on your car
Shiv |
01-03-2008, 01:00 PM | #10 |
Rep 6,608
01-03-2008, 01:01 PM | #12 |
Rep 1,743
Nice numbers!!! I see raising the boost on this motor even by 1 to 1.5psi makes a pretty big difference in the WHP... Must feel nice on the road running 15psi thru the band
01-03-2008, 01:03 PM | #13 |
Rep 2,587
I was on ~98 octane. 104 would be a nice bit of extra margin. But like I said I don't endorse this kind of power on the factory drivetrain, turbo hardware, etc .
01-03-2008, 01:04 PM | #14 |
Rep 2,587
01-03-2008, 01:06 PM | #16 |
Rep 455
If I get my 335 I will run the 104 and just use the switch for when I want to really get into trouble.I havnt been folowing your pills and switches,but do you think you can make 2 switches,one for like 14 psi/race gas and one for like 15-16 psi for people that can get up to 110 oct.
01-03-2008, 01:07 PM | #17 |
Rep 660
01-03-2008, 01:08 PM | #18 | |
Rep 6,608
JB2 always one, switch for hot pill, another switch for R....is that possible? |
01-03-2008, 01:09 PM | #19 | |
Rep 2,587
The JB2 is designed for guys who want something inexpensive and reliable, so I don't see myself spending much time on new race switches, etc. But, it would be easy to rig on your own. The hot pill is just a 270ohm resistor, so if you made up a switch that added say 750ohms (1/2 watt, 2% tol) it would work. |
01-03-2008, 01:12 PM | #21 |
Rep 2,587
01-03-2008, 01:12 PM | #22 | |
Rep 455
I will also be getting an xi 6spd to put the power down. |
