09-28-2014, 03:17 PM | #1 |
Rep 74
ecopro coasting
I own a 07/12 made n13 8AT f30. I notice that newer f30s with the same engine come up with coasting feature in ecopro. i learnt that i could force this onto my vehicle by simply changing the production date however I wonder whether this coasting feature has been brought along with some other mechanical improvements on the transmission.
09-28-2014, 07:31 PM | #2 | |
Rep 4,976
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
09-29-2014, 04:21 PM | #3 |
Rep 524
What is needed to FDL code Eco-Pro Sailing? I have the CIC so
I coded: Kombi>3000 Anzeige_Konfigration>SEGELN_Enable>aktive HU_CIC>3000 HMI>EFF_DYN_SAILING>aktive ICM>3000 Daten>C_Segeln_vorhanden>enable but don't see the option under Eco-pro for coasting. What else am I missing? |
09-29-2014, 04:52 PM | #4 | |
Rep 1,892
EGS / 3000 / SEGELN to aktiv EGS / 3000 / POCHEN to aktiv EGS / 3000 / NIC_alt to aktiv Note that I have not actually tried this, so I can't verify that it actually works or not. Also heed the warning above by TheScout about overheating your transmission if you enable Sailing with a transmission that does not have the auxiliary cooling pump. |
09-29-2014, 05:42 PM | #5 |
Rep 524
Thanks for the info. Probably not something I will have 'on' and risk overheating the transmission. Though I edited the 3 EGS sections, still don't see the option for coasting under Eco-Pro.
09-30-2014, 12:37 PM | #6 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Doesn't work if you have CIC. Coasting is a feature only available on Fxx vehicles built after 07/13 and those cars would have HU_ENTRY or HU_NBT. It's a limitation on the HU_CIC firmware. Coasting shows up on my HU_NBT and my friend's HU_ENTRY but when I tried with my old HU_CIC, it will not show up regardless of whether I VO code it or FDL code it.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
09-30-2014, 12:41 PM | #7 |
Rep 1,976
I only had overheating issues when I VO coded EGS with 07/13. Enabling the sailing never gave me the heating issue but the car has definitely stalled on more than one occasion.
11-19-2014, 06:05 PM | #9 |
Rep 524
Not to beat a dead horse on this subject, but if you have coded the parameters listed above on a CIC and don't have the option to turn on Sail Mode ON or OFF, does the Sail Mode default to ON when you're on Eco-Pro mode? Or would the coding have no affect since it can't be seen or controlled through the CIC? Just curious since Aritaurus got the overheat transmission code and felt stalling on his vehicle which had the CIC, so curious as to how the Sail Mode was turned on.
11-19-2014, 07:22 PM | #10 | |
Rep 1,976
I have a feeling that I need to VO code the 07/13 build date to another ECU before this works but it's not worth trying since my car has stalled a number of times with this feature on.
11-23-2014, 11:03 AM | #11 |
Rep 1,436
Can someone tell me if it will work on my car ? I have NBT but no idea on build date.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
11-24-2014, 12:07 AM | #13 |
Rep 1,436
11-24-2014, 06:51 AM | #14 |
Rep 524
My build is May 2013 with the CIC. When I went to FDL code, all the options to enable sailing were there, but from others, it was not working correctly because there may be other modules that may or may not need to be updated plus I can't even see the option to turn on or turn off sailing due to the limitation of the CIC system.
11-24-2014, 08:26 AM | #15 |
Rep 1,976
In your case, you would need to enable sailing on your EGS module since your vehicle is a pre-2014 model even though you have NBT.
11-24-2014, 08:42 AM | #16 | |
Rep 1,436
I did a video showing how it works, very simple and it did save some gas at least in our roads !
11-24-2014, 08:45 AM | #17 | |
Rep 1,436
EGS / 3000 / SEGELN to aktiv EGS / 3000 / POCHEN to aktiv EGS / 3000 / NIC_alt to aktiv Kombi>3000 Anzeige_Konfigration>SEGELN_Enable>aktive HU_NBT>3000 HMI>EFF_DYN_SAILING>aktive ICM>3000 Daten>C_Segeln_vorhanden>enable.
11-24-2014, 10:05 AM | #18 | |
Rep 524
Glad sailing works for you, though. |
11-24-2014, 10:25 AM | #19 |
Rep 1,976
He's probably from Europe where NBT was available on the F30 since November 2012.
11-24-2014, 10:37 AM | #20 |
Rep 1,436
No, it was NBT since I bought it
11-24-2014, 10:40 AM | #21 |
Rep 1,436
Exactly
11-26-2014, 04:14 PM | #22 |
Rep 54
One more parameter might be required for other people, on top of rustyminded's parameters:
ICM > 3000 Daten > IcmKod_B_AuskuppelnOK > aktiv Before coding this, my revs would not go to idle. Is this parameter active in your ICM Rustyminded? |
