BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Throttle pedal position & kick down vs tracking/racing
      11-04-2022, 08:21 AM   #1
Lada-1
Czech_Republic
Drives: F31 340iX
How can I get a more "acceleration sensitivity" from the gas pedal while racing with a car equipped by auto transmission and featuring the kick down function. To me the throttle pedal path (incl the kick down activation at the end of the path) behaves like an ON/FFF switch at SPORT+ drive mode. I tend to full gas and full brake driving bad habit.
      11-05-2022, 10:10 AM   #2
visionaut
visionaut's Avatar
Drives: 2016 435iX GC & 1976 2002
Turning DSC off will enable a more sensitive throttle in Sport+
      11-05-2022, 11:03 AM   #3
p0p
Ninja
155
Drives: N54 & B58
maybe? https://burgertuning.com/products/bms-pedal-tuner
Or another Tune
I am 5% more sensitive (DinanFlash)
      11-07-2022, 09:54 PM   #4
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Tune it and set the throttle to linear. This is what happens when you turn off dsc like said above. But with the tune it's would be linear all the time. It's also the throttle map when you are in comfort, but obv a bunch of other stuff is turned down as well.
