09-14-2013, 05:02 PM | #221 |
Rep 1,659
I seem to think that memo showing the delay was either a fake or a mistake. I just took delivery today of a 2013 335xi, M Sport, M Performance Power Kit, late July 2013 build. It was installed at the VPC. No issues and shows 400/400.
09-14-2013, 10:33 PM | #222 | |
Super Spectacular Awesome Dude
69
Rep 577
09-14-2013, 11:18 PM | #223 | |
Rep 1,659
Only have a day with it so far and love it. Crazy fast. In terms of the exhaust, I do not thing it's any louder. The only difference I notice is the burble when you let off the throttle. |
09-14-2013, 11:27 PM | #224 | ||
Rep 2,564
09-15-2013, 06:04 AM | #225 |
Rep 124
PPK was accepted and confirmed (via paper anyway) on my August 1 build. It arrived at port on Thursday, due to the dealer next couple of days.
2018 X3 M40I - Alpine White with Cognac, Premium, Executive, 21" Wheels, Adaptive Suspension...
Gone - 2017 Genesis G80 Ultimate (OOPS); 2013 335I X-Drive - M-Sport; 2011 535I X-Drive M-Sport; 2010 535I RWD Sport Pkg; 2006 530XI |
09-15-2013, 06:52 AM | #226 | |
Rep 2,564
09-15-2013, 08:29 AM | #227 |
Rep 124
When we located this vehicle, the question of availability was flying around. I added PPK to the order around August 20th.
Gone - 2017 Genesis G80 Ultimate (OOPS); 2013 335I X-Drive - M-Sport; 2011 535I X-Drive M-Sport; 2010 535I RWD Sport Pkg; 2006 530XI Last edited by mrich1353; 09-15-2013 at 08:48 AM.. |
09-15-2013, 08:33 AM | #228 |
Rep 3,619
400/400 displays
I know I owe people here a video of the sport displays, I have not got the chance to record it yet. Continuing with the speculation that 400/400 displays imply one has the new PPK I made a couple of observations. The display will show peak hp of 335hp mostly when accelerating from a stop before shifting from 2nd to 3rd. N55 with AT will shift from 2nd to 3rd around 55mph That's where I have observed 335hp the most. Hopefully others can describe what they are seeing too
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
09-15-2013, 10:01 AM | #229 |
Rep 1,659
09-15-2013, 04:27 PM | #230 | |
Rep 2,564
09-15-2013, 06:14 PM | #231 |
mhmmmm
136
Rep 633
I have a June build car, and had the PPK installed at the dealership at the beginning of August. My sport display is the same as a non PPK sport display (i.e. I don't get 400/400 on the display)
09-15-2013, 08:11 PM | #232 |
Rep 228
Had my PPK installed pre delivery at the end of May. Last month I went in to have the ASS recoded and to have the display recoded from the Euro measurements. Mine now shows NA measurements and 400/400. Must be a software update that is needed.
09-15-2013, 08:29 PM | #233 |
Rep 503
It feels like there's a lot of bad info on here. The impression I got fort he MPPK memo was the MY 2014 cars. There is no reason why 2013 cars would change from one month to the other. Does anyone have a MY2014 335i that had the MPPK installed? I didn't see anyone specifically mention that.
09-15-2013, 08:45 PM | #234 | |
Rep 7,047
This goes for NA engines, turbo or supercharged. The MPG benefit to turbo/supercharging is that you can have a smaller displacement engine that can produce larger displacement power. So if you drive with lighter throttle applications you get the benefit of a smaller displacement engine with plenty of power to move you in normal traffic situations. Then, when you want more power you can have it with larger throttle applications and the turbo/supercharged engine will effectively put out as if it were a larger engine. That is when MPG goes down, simply because you are calling on the engine to produce more power, and to produce more power it will suck in more air, pressurize it to effectively pack air in as if it were a larger engine, and that additional air will need more fuel to produce the power you want. Any tune should let you get the same MPG as before the tune, if and when you drive it with lighter throttle applications. If you typically use around 150hp/150lb ft to accelerate under normal driving, then you will use a certain amount of fuel. So even if you have a tune to give your engine a higher potential power output, that doesn't mean that you will be using more power under the same normal driving conditions. Only when you want to use the greater power will you use more fuel. It's all under your control. In some engines a tune has shown a slight increase in MPG when driving normally compared to stock, but that isn't always the case. BMW says that average MPG remains the same with the PPK, and it will as long as you don't call on the greater power now available. If you do, then average MPG will be lower, no getting around that. Typically though when a driver gets a higher power tune they want to experience it and enjoy it. That's why average MPG tends to drop once a tune gets installed. It's simply because the driver is getting into the throttle more and more often to enjoy the added power, not because the tune hurts average MPG during normal driving. Once the newness of the tune fades the cars average MPG goes up as the driver settles in and doesn't use the added power most or all of the time. When the driver returns to normal/typical throttle use the average MPG goes back up. Your best MPG control is your throttle foot. Using it better with more precision will give you best average MPG, tune or stock. Adding a few PSI to your tires if you do more highway miles can also help. |
09-15-2013, 08:56 PM | #235 | |
Rep 128
If you go back a couple of pages there's a couple of people saying a new DME was put into production 07/2013 (MEVD176G), and subsequent cars (MY13 and 14), use this new DME. That seems plausible to me. So what we're waiting to hear -- those of us with a car produced prior to 7/13 -- is this: 1) Do we get new DME if we buy MPPK? or 2) Do we just live with old version of MPPK? Obviously 1 is preferable to 2. And if you happen to have bought an MPPK before the new DME, you'r probably wondering if BMW will do the right thing and upgrade your DME and PPK free. |
09-15-2013, 09:13 PM | #236 | |
Rep 7,047
Interestingly, the July 2013 bulletin says that there will be an engine management update/change BEGINNING with July 2013 builds, and that the MPPK for those engines is expected later this year. But it's odd that the BMW site shows the MPPK kist available for 3 built up to and including 7/2013. The odd part is that July 2013 builds are 2014 models that supposedly have the new engine management software. If the new software is on the July 2013 builds, then why are those cars included but not August or September? Seems the site should list the kit for up to June 2013 builds, which would be the last of the 2013 model year. Confusing indeed. Last edited by RPM90; 09-15-2013 at 09:19 PM.. |
09-15-2013, 09:29 PM | #237 | |
Rep 7,047
July 2013 starts the production of MY 2014. July 1st has typically been the start of production for the next model year. So, MY 2013 3's shouldn't be being built in July 2013. And MY 2013 3's production orders stop before June, as BMW plants stop for a month to retool as necessary for the next model year, which starts July of the current year for the new model year. My 2013 335i Msport was built in July 2012. The F30 Msport's started MY 2013, and the beginning of the production for MY 2013 was July 2012. Those of us who were first to get the Msport's got really screwed as the PPK's were not available until a number of months later, and now the kit's don't include our production dates at all. We weren't able to get the PPK's included in our leases. And, there have been 2-3 steering rack changes in just 1 year, and we don't get those upgraded racks either, which would the "right thing to do", but BMW didn't do that either. I think the steering rack upgrades are more important that the PPK's, yet BMW doesn't seem to care about that either. |
09-15-2013, 10:32 PM | #238 | |
Rep 128
I think you're right... but I hope you're wrong! |
09-16-2013, 11:06 AM | #240 |
Rep 3,619
Why you should get PPK
CTS V Sport 420hp/430tq, 3900lbs http://www.motortrend.com/roadtests/...rt_first_test/ S4/335i type numbers. Not bad
09-16-2013, 11:13 AM | #241 | |
Rep 596
2013 BMW 335i xDrive Sport Line
09-16-2013, 11:21 AM | #242 | ||
Rep 3,619
Not a bad showing for the S4/335i IMO The turbo 6 will go in the ATS V which competes with the M3/M4.
