04-21-2024, 10:07 AM | #1 |
Mr OEM
675
Rep 88
Drives: 2012 BMW 335i
EDC Shocks to Standard Shocks?
Good day,
My 2012 F30 335i has the Adaptive M Suspension, which don't get me wrong is a great optional extra, however it has been 385, 000km (240,000mls) and they are 100% toast. I would like to install standard F30 shocks as they are much cheaper, lighter and there is less to go wrong with them. Will the standard shocks fit correctly? And how do I code out the EDC from the car's computer? |
04-21-2024, 10:41 AM | #2 |
Rep 545
Hello. Please review my thread. I replaced EDC with non-EDC.
https://f30.bimmerpost.com/forums/sh....php?t=1657753 The code was done remotely. |
04-21-2024, 10:56 AM | #3 | |
Mr OEM
675
Rep 88
I have searched the forums but haven't been able to find anything about this for some reason So if I buy OEM shocks do you think I will need to replace the springs as well or could I leave them alone? And before you coded the car, what warning lights did you have? |
samspiderman312545.50 |
04-21-2024, 01:36 PM | #5 |
Mr OEM
675
Rep 88
04-22-2024, 09:25 AM | #6 |
Rep 41
You could go the route of remote tuning, or you could code out the errors with a hardwire kit that you mount in or near the wheel well. This kit basically tricks the car into thinking that the EDC system is still working. (https://www.ecstuning.com/b-kw-suspe...t/68510301~kw/)
My car is still under warranty from some large repairs that BMW did. So for me, tuning is out of the question because I'm unable to tamper with my ECU. I've heard good things about both so it doesn't seem like you could make the wrong choice here. If you do not want to find a way to fasten these EDC kits, then just go with tuning. Let me know how it goes! Last edited by F30_Drew; 04-22-2024 at 11:07 AM.. |
04-22-2024, 09:35 AM | #7 | |
Mr OEM
675
Rep 88
I am hoping that remote tuning works out to start with, just waiting for my mechanic to get back to me about it! Hopefully I can get it done soon, will let you know how it goes |
04-23-2024, 08:25 AM | #8 |
Rep 545
I had some issues after the EDC removal. What that coding did was to update the Vehicle Order (VO) to pretend the car came out of the factory without the EDC option.
A couple of years ago, I needed to replace a part (Fuel Control Pump Unit P/N 16147411596) which required to be coded into the car. My mechanic had a lot of trouble to make this work. His notes say "Unable to code EKPM3 with standard BMW ISTA+. Found vehicle order has been modified which caused the ISTA+ programming issues. The EKPM3 is now coded successfully (the only way to code this vehicle is E-SYS only)." He also said any new part that requires coding will have similar issues. |
04-23-2024, 11:09 AM | #9 | |
Mr OEM
675
Rep 88
I will have to look into this further, appreciate you letting me know! |
