10-20-2015, 04:28 PM | #1 |
Rep 77
Snow Foam Lance - why are they so much money
Why are snow foam lances so much money.
I have been seeing prices for around £45. That is nuts for simply a bottle and some tubes. Anyone know of any cheaper ones as there is no way im paying that for some fittings and tubing. Cheers guys and gals |
10-26-2015, 05:00 PM | #3 |
Rep 1,101
When you see one up close you can see why it is worth a bit of money. I have the chemical guys foam cannon and it was around $80 US. The brass fitting on the top of the bottle is fairly heavy duty to stand up to the force from your pressure washer. There are cheaper methods...I saw a cheap version that you hook a hose up to and it sprays out "foam". It is made of plastic and doesn't work at all. Just sprays some soapy water onto the car it it all runs off...no foam.
The foam cannon works as advertised. Sprays out major amounts of foam. I have used the honeydew soap and the max suds soaps from Chemical guys and both work really well. Thick foam and it clings to the car. The only think to remember...if your car is at all dirty you still need to use a wash mitt and do some hand washing. Don't think you can just spray on the foam and rinse off the dirt with pressure washer. If your car is dusty or not very dirty then you certainly can just foam and rinse and you are good to go. |
10-29-2015, 06:20 PM | #5 |
Rep 143
When I bought the chemical guys mtm cannon as a gift last winter I paid close to $85 and thought it was crazy overpriced. I hesitated to buy my own until this summer when I started seeing cheaper foam cannons appearing on Amazon/eBay for closer to $30. Right before I pulled the trigger I noticed chemical guys mtm cannon with 1 gallon of their honeydew car wash came out to less than $55 so I got that instead.
I still think it's pretty expensive for essentially a high pressure hose nozzle but any high quality hose nozzle will even run you between $10-$20 so I suppose the prices are fair now between $30-$40 bucks. Stick with name brands like MTM as their foam comes out much nicer than other brands. I also tried CG torq foam cannon and could not achieve good foam with my electric ps. Another way to look at it is the money saved from winter auto car washes when it's too cold to get your two buckets out. One weekly wash and you can rinse off the salt and get your car 90% clean in about 15 min. |
11-06-2015, 07:51 AM | #6 |
Rep 77
Well i brought a cheep one.
http://www.ebay.co.uk/itm/2817997158...%3AMEBIDX%3AIT We will see how this works - the reviews seemed good |
11-06-2015, 05:46 PM | #8 | |
Rep 1,035
I dug up my old notes back when i was eval'ing all this stuff ... --- Soap makes a difference http://www.e90post.com/forums/showthread.php?t=984608 This guy says switching from Meguires NXT soap to CG maxi suds made a world of difference Foam guns make a difference http://www.autogeekonline.net/forum/...ric-model.html The new MTM next generation low-pressure foam gun (14.0263) outperforms the MTM Hydro. By outperforming, i mean it creates more of a dry clingy foam (not runny, but sticks to car better) vs the running soupy foam that runs off the car quickly and dries up forcing you to have to wash faster or else get dried soap stains on the car |
11-10-2015, 07:46 AM | #11 |
Rep 1,035
11-10-2015, 10:25 AM | #12 |
Rep 369
Challenge accepted, next time I wash the car it's on!!!
11-16-2015, 10:39 AM | #14 |
Rep 3,089
I am a total noob to pressure washers and foam lances. Any recommendations on what pressure washer to get with the MTM foam lance?
11-16-2015, 11:02 AM | #15 | |
Rep 369
This is the one I have.. http://m.screwfix.com/p/nilfisk-e140...FQ2NGwodovwPgw More than enough for home needs, ignore the little bottle that comes with it, that won't do for proper foam. |
11-16-2015, 03:33 PM | #17 |
Rep 3,089
Is this Karcher 1600 psi good enough for the weekend warrior only using this to wash the car? I assume it will work with the MTM foam lance reference in this thread?
11-17-2015, 12:10 AM | #19 |
Rep 1,035
I started with a Pacific Hydrostar 1650 PSI Electric pressure washer from Harbor Freight and returned it after finding out it couldn't foam up the car with a thick dry lather. The foam was rather soupy, thin, and runny. It was like $79 on sale. I don't know how it compares to the Karcher, and i wouldn't make judgements strictly by the PSI rating. It also could have been to the cheaper foam lance i was using at the time. The thing that sucked about this HF PW was that it didn't have standard fittings/adaptors for the foam lance so i was scurrying around to find adapters and that was part of the problem. It only took Nilfisk Kew Alto type of connectors. It was a small nightmare to get sorted out.
I finally decided i didn't want to mess around anymore and put the $$$ in the game, and I got a gas powered PW that had more common fittings that worked with this MTM foam lance I got and I haven't looked back. I got the Generac 6596 2800 psi 2.5GPM pressure washer from Pressure Washers Direct and it was night and day difference. But it ran me $300, but its been over a year and the thing is still going way strong. It got great reviews on both Amazon and Lowes site, and i haven't been disappointed so far. I still owe Mr. Versailles a video I plan on washing the car this weekend (or for sure over Thanksgiving weekend), so i'll show you how amazing a great PW and a great lance foam canon work together. Live (and die) by the code, brah... |
11-17-2015, 07:22 AM | #20 |
Rep 5,316
Drives: G80 M3 6MT
I had a similar one and for some reason the twist on wand basically just wouldn't work anymore, its spring loaded and you couldn't push the wand and twist after only a few months. When I brought it back to home depot the repair guy told me lot of people have this issue and he has no idea why or whats happening.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
11-17-2015, 08:48 AM | #21 |
Rep 3,089
Thanks for the input to try and help a total noob guys. From what I have gathered so far I think I will stick with Karcher only because the MTM foam lance will work with it (sorry versailles ) unless someone can let me know what I need to make the foam lance work with Nilfisk???? Again, sorry for being a total beginner to this.
11-17-2015, 06:57 PM | #22 |
Rep 1,101
1600 psi is enough for a snow foam lance. It will produce loads of snow foam! There is some manual hand washing required...don't expect to just foam the car and pressure wash off all the dirt! If the car is dusty or just has minor dirt then you can do this. However, most times it is foam, hand wash then pressure wash off, You don't need 3000psi to blast it all off!
Pressure washer is great around wheel wells and in hard to reach areas of wheel! |
