06-23-2013, 02:48 PM | #1 |
Rep 1,048
DHP + Msport questions
Guys,
I am looking to order an M-Sport 335i...I dont really know what the DHP does, I tried searching as well. My questions are as follows: 1. Can you modify the suspension later if you get the DHP w/ the M-Sport package 2. What does VSS actually do. Does it make the steering more like the n54 cars? I dislike the electronic steering alot, and trying to figure out if VSS will help that 3. The msport by its self comes with m suspension, what does the DHP add other than VSS. $1000 for VSS not sure if worth it? 4. Will DHP help me take turns faster say in the auto-x? Or is it really just a "comfort" option Thanks for input, i really dont understand what it does. |
06-23-2013, 02:56 PM | #3 | |
Rep 1,048
Doesnt the M Sport package come with adaptive M suspension? Is there further customization beyond sport and sport+ Last edited by 04cobra; 06-23-2013 at 03:01 PM.. |
06-23-2013, 03:25 PM | #4 | |
Rep 936
06-23-2013, 03:27 PM | #5 | |
Rep 1,048
Especially since I would want to change springs/coils later. |
06-23-2013, 03:27 PM | #6 | |
Rep 936
If you always want stiff steering drive always in sport mode but thats going to kill your gas. Adaptive m suspension is part of DHP. |
06-23-2013, 03:31 PM | #7 |
Rep 148
If you get DHP you can alter sport settings so that you have sport chassis, but comfort drivetrain...which means stiffer steering with better gas savings.
2023 Audi A6 Allroad
2022 Porsche Boxster 25 Years 2014 Porsche 911 50 Past: 2019 540i xDrive, 2016 340i xDrive, 2013 BMW 335i xDrive, 2014 428xi 'vert, 2010 VW CC 2.0T, 2008 Audi Q7 4.2 Premium |
06-23-2013, 03:37 PM | #8 |
Rep 1,048
I should note that i am getting the 6MT...so all the sport setting would do is change the suspension and my MPG should not change...since I choose when to shift...correct?
06-23-2013, 03:42 PM | #9 |
Rep 1,388
06-23-2013, 03:55 PM | #10 | |
Rep 1,048
So if I go with M-Sport cant customize...if i get DHP I can customize? |
06-23-2013, 04:09 PM | #11 |
Rep 3,780
There are guys here that have added aftermarket springs like H&R in conjunction with DHP and quite happy.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
06-23-2013, 04:24 PM | #12 | |
Rep 2,385
However, I wouldn't let this impression of "loose" steering put you off. |
06-23-2013, 04:26 PM | #13 |
Rep 2,385
Sport and Sport+ change the throttle mappings (throttle is much more sensitive, or rather not as dull as it is in Comfort or Eco) so I can see how you would *tend* to use more gas in that mode. Probably why I only get 17MPG as I prefer it over Comfort for the steering feel, and the throttle response. Comfort (don't even know what Eco is like) just feels like you have to give it 75% throttle to get it to move.
06-23-2013, 07:24 PM | #16 |
Rep 2,290
06-23-2013, 10:25 PM | #18 |
Rep 1,730
If you want to drop for looks, then H&R springs with the DHP dampers will work fine. If you want to track/have properly matched struts/springs, then don't get DHP. DHP comes with adjustable electronic dampers which you'll just throw out. Put the money towards aftermarket coils or M performance suspension if you want to stick with OEM gear.
The VSS is another issue, but most people get DHP for the following reasons 1) Driving around town in comfort mode (more floaty) when wanted; 2) DHP + sport suspension is stiffer/rides flatter in sport mode than just sport suspension; 3) If you get xdrive there is no other way to get a stiffer ride since xdrive removes sport suspension from either Sport or M-Sport trims. Hope that helps! |
06-23-2013, 11:46 PM | #19 |
Rep 2
I have a related question, I am also looking at the 335i, is the sport line worthy of the price if I'm going to add the DHP. Would the money be better spent on a different option say the sport transmission.
I'm in US and on a tightish budget, around 3-4k, for options and would also be interested to know what people here would choose in that case? Would anyone go for a better equipped 328i? Thanks all. I would have probably created a different thread for this but being new don't have the permissions yet. |
06-24-2013, 12:40 AM | #20 | |
Rep 265
Also, many people would choose a loaded 328i over stripped 335i. You need to test drive both and see if the differences between them compel you one way or the other. |
06-24-2013, 01:18 AM | #21 |
Rep 436
If you liked the E90 steering thn you will be disappointed with the F30. I recently had an E90 loaner for a week and coming back to the F30 was very noticeable (I used to have an E46). Sport mode tightens thing up a little, but BMW is looking to reach a different segment of the market. Since it is electric, I have been asking my dealer about a coding fix, but no luck yet (stands to reason that since steering can be "tightened" up in the first place, then it can be programmed to fix thing a little more in say comfort mode too.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport |
06-24-2013, 12:44 PM | #22 |
Rep 198
I'm NOT coming from an older BMW, but I feel that the steering is just right. Are people liking the truck-like steering weight of older cars or is there something else going on? I know when taking corners tight I don't like an overly heavy steering because it slows me down.
