04-14-2020, 06:07 PM | #23 |
Rep 7,620
Good info and thanks for the responses both. Im going to get the blue and the OE, because why not. I will report back with that i notice once i get/install them.
I drive like 5k per year, and never really in dusty environments or anything, so ill replace every 1-2 years or when i start to smell something. Edit: Here is what i ordered: https://www.fcpeuro.com/products/cab...r-cto-80004354 https://www.fcpeuro.com/products/bmw...119237555-blue Last edited by thejeremyman9; 04-14-2020 at 09:51 PM.. |
04-16-2020, 09:35 PM | #24 |
Rep 211
i had to do a friend of mines cabin filter today and we ordered the blue filter for him off fcp euro. it looks eye appealing (even though you will never see it until you take it back out). and it is definitely directional as u can see from pics. i installed mine arrows facing forward. it makes me feel better seeing his car is protected by a facemask especially in a time like this lololololol
04-17-2020, 02:42 PM | #26 | |
Rep 5,457
Drives: F30
No way that process takes less than a full week... always wondered about this aspect of their lifetime warranty. Unless you have two vehicles, Im guess there is always at least a week of downtime between free replacements? |
04-17-2020, 02:55 PM | #27 | ||
Rep 7,620
sspade2467.00 |
04-17-2020, 03:00 PM | #28 | |||
Rep 3,540
Onizukachan1116.50 |
04-17-2020, 03:08 PM | #29 |
Rep 2,815
Drives: F33 430 and F39 M35i
arrow points toward engine.
04-17-2020, 03:18 PM | #30 |
Rep 211
i agree arrows forward! and i think these filters should be changed every year. ive had my car almost 2 years, i swapped the filter out about a year ago and mine was gross coming out
04-18-2020, 09:50 AM | #31 | |
Rep 424
04-26-2020, 03:08 PM | #32 |
Rep 7,620
Just installed the blue filter today. No difference in dimensions or anything comapred to the BMW one or the non-BMW replacement (not blue one). My old one didnt look too bad, some dirt and lent along the bottom, but i did notice it weighted probably 5x as much as the new one, so it had likely captured quite a bit of material. It was in the car when i bought it late 2018, so i expect it was around 4 years old.
04-26-2020, 07:48 PM | #34 | |
Rep 7,620
Aside from that, you can try BG Frigi-Fresh. I used it on another car of mine that does not have a cabin air filter. In that case i pulled the blower fan, cleaned out the air ducts and condense (which was quite dirty), then turned the fan into max and sprayed a bunch of the frigifresh into the inlet below the window. I ended up using only about half the small can and it seemed to make a big difference. Let the fan run about 5 minutes after i was done to clear out anything left. https://www. bgprod .com /catalog/climate-control/bg-frigi-fresh/ In the case of this car, you might have to do this with the filter removed... I would be a little concerned though as i am not exactly sure how the HVAC system is setup in the BMW. EDIT: There is also ozone treatment. |
04-26-2020, 11:53 PM | #35 | |
Rep 5,457
Drives: F30
If you do a search... you'll find that some others have had success with spraying an AC system cleaner directly through the drain tube and presumably up into/against the condenser. |
04-27-2020, 01:49 PM | #36 | |
Rep 787
Anybody on here install a new oem filter recently? Are they heavy out of the box or do they get bogged down with contaminates over time?
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
04-28-2020, 06:37 AM | #37 | |
Rep 10,367
Living in the humid SE US and never a problem with this set up in a BMW. From my own experience operating the fan at low speed with thermostat set below 72F is more likely to result in a smell. I'm not exactly sure why.
"Drive more, worry less. "
04-28-2020, 06:41 AM | #38 | ||
Rep 10,367
04-28-2020, 09:31 AM | #39 | |||
Rep 787
04-28-2020, 10:25 AM | #40 | ||||
Rep 10,367
04-28-2020, 10:44 AM | #41 | |
Rep 7,620
It has a layer of carbon: https://www.fcpeuro.com/products/bmw...119237555-blue
The overall structure may be different though, aside from the blue layer on this one. To me it sounded like the new filter made things flow a little better/easier, could have been placebo though. Quote:
05-02-2020, 10:28 PM | #42 |
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I just changed my cabin air filter after I forgot to change it for 1.5 years. I bought OEM, but now I really wanna try the blue one next! Anyone notice any differences at all?
I see FCP Euro and ECS Tuning both sell blue filters, they look the same but have a different label. I guess I'll order whichever has cheaper shipping to Canada. Re: weight. The OEM one I bought wasn't very heavy. |
05-03-2020, 02:05 PM | #43 | |
Rep 7,620
The dimensions of old BMW vs. New OEM non-BMW vs. new blue were exactly the same. |
