03-30-2017, 03:32 PM | #45 | |
Rep 2,302
03-30-2017, 04:08 PM | #46 | |
Rep 14
I tried to add HO-Wort=HELC, but get an error when I calculate FP. PSdZ Error "No FP could be generated from FA" (C002) Not all elements of the FA were found in the FA2FP: HO-Word HELC (72) Could my PSdZ files be too old? Thanks |
03-30-2017, 04:21 PM | #47 | |
Rep 2,302
OK, so you have to change all values manually. REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv |
05-15-2017, 03:06 PM | #49 | |
Rep 59
09-22-2017, 03:11 PM | #51 | |
Rep 48
09-22-2017, 03:27 PM | #52 | |
Rep 18,798
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-05-2017, 12:46 PM | #54 |
Rep 18,798
Install steps will be slightly different, coding is same.
10-05-2017, 03:38 PM | #55 |
Rep 29
Tried retrofitting this and stupidly unplugged a module from the R.E.M and forgot to plug it back in. Shut the boot and now cannot open the boot. Think it was the A174*13B. Now I'm locked out the boot what do I do?
10-05-2017, 03:42 PM | #56 | |
Rep 18,798
10-06-2017, 10:42 AM | #57 | |
Rep 29
10-09-2017, 12:51 PM | #58 | |
Rep 29
Dealers had to get in through rear seat lol, bummed mme with labour. Fitted lights but inner blinkers are not working. Do I need to VO code? |
10-09-2017, 12:53 PM | #59 |
Rep 18,798
No need to VO code for F30, just follow the steps outlined in the OP.
12-11-2017, 11:52 AM | #61 |
Rep 18,798
We only offer US version (red).
05-25-2018, 03:16 PM | #62 |
Rep 1,953
Drives: 2013 328i xDrive
Quick question guys, just did this to my car but when I looked at:
MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default] MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default] There was only an option for voltage changes. It was at 11V or something. I left it as is, is this okay? Or was I supposed to adjust the Werte? That was at 85. |
06-11-2018, 09:32 AM | #64 | |
Rep 2,302
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 100% or 13.7V REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 100% or 13.7V |
11-08-2018, 06:14 AM | #65 |
Rep 7
Hey atzebmw, I did the manual coding you said on my F31. Inner blinkers are working on lock/unlock and emergency perfectly. One issue is with the left blinker. After one blink it gets a failure on computer. The right is working fine.
11-08-2018, 08:20 AM | #66 | |
Rep 2,302
REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default] and REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default] have to set to nicht_aktiv. In general, you can say that all values with KALTUEBERWACHUNG or WARMUEBERWACHUNG have to set to nicht_aktiv. |
