09-22-2017, 12:23 PM | #23 | |
Rep 579
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
09-22-2017, 12:25 PM | #24 | |
Rep 521
kern4174446.50 |
09-27-2017, 08:22 PM | #26 |
Rep 723
My 2017 340i/6MT is RWD and late October 2016 production. I have experienced the exact same change as you have since my software was "upgraded" about 2 weeks ago. Old behavior it would rev match on any downshift, but now only rev-matches on next-lower-gear downshift.
More frustrating was that my phone would disconnect randomly while trying to play TuneIn Radio App via bluetooth. Worked flawlessly before and it may be working now, but I'm really not sure. I've been with the same SA at the same dealer for 12+ years and this was the first service visit that didn't get 10's/exceptional (they almost always are). However I made it clear it was not the service experience, it was the software BMW told them to install that the dealer doesn't control. It really sucks. |
09-28-2017, 08:28 AM | #27 |
Team Zissou
3065
Rep 10,197
Just to throw more data into the mix... for my 2016 340i:
As of now i've only had oil changes from the dealer, no major service that would require some bigger software update. My car rev-matches whenever i want (ie i can go from 4 -> 2 and it will rev-match). It does not try to rev while jiggling the shifter in neutral. Last edited by jpsimon; 09-28-2017 at 04:00 PM.. |
10-14-2017, 11:07 AM | #29 | |
Rep 4,103
Drives: BMW M3
My car was built in spring 2017 (I think March) and it will auto rev-match 6 to 4, 5 to 3 etc. I'll be a little disappointed if they only rev match the gear below the current one, there's just no point to going 6 > 5 > 4 when you know you want to end up in 4th ...on the bright side, this will give me an excuse to blip the throttle on my own.
Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
10-26-2017, 09:35 AM | #30 |
Rep 84
I'll be really upset if this is the case. What's the point of having rev matching if it doesn't do it on skip shifts? That's when you have the largest difference in revs and need it the most. Very stupid decision by BMW, though I'm sure they did it because someone botched a downshift and overreved... Would seem far more logical to just apply a limiter in those cases.
I also concur on revving while wiggling in neutral. It's just one of those habits I learned early when I first started driving standard, so it's a hard-wired reflex to wiggle the shifter when I'm coming to a stop. Sometimes it's fun to hear it, but sometimes it just makes me feel like an asshat, especially if it's late and I'm in a residential neighborhood since I have the MPPSK and like to ride around in Sport whenever I can. |
10-26-2017, 12:02 PM | #31 | ||
Rep 521
10-28-2017, 02:48 PM | #32 |
Rep 97
I think I now have this same issue. I took my car in yesterday for oil change (it's a '17 340) and had them look at an issue with my trunk. When I picked it up they said they applied an update to the car. Driving home I noticed the rev matching didn't always work. I believe this is the issue.
I think I am going to call them and schedule another appointment. If they can't fix the issue then they need to roll back the update. I have gotten so use to the rev matching that it is frustrating to drive now. I didn't pay over 50k for a car that had rev matching only to have it break less than a year later. |
10-28-2017, 06:03 PM | #33 |
Cheapskate
4447
Rep 4,993
I'm going to go out on a limb and say they can't roll back programming, but good luck.
10-29-2017, 10:44 AM | #34 | |
Rep 521
So, based on what my advisor has told me, they can't normally, but it might be an option if they escalate and that's the answer. I'm still waiting for them to get an answer from escalating my case. I tried going through BMW NA customer service too, and they told me to just wait for my dealer to hear back. If they don't hear back in another week or two, I'll try and escalate on the BMW NA side again. |
10-29-2017, 11:59 AM | #35 |
Cheapskate
4447
Rep 4,993
I could see it possibly if it was causing an issue, but it just changed the operation. Stuff like that typically doesn't get changed unless they think it's causing an issue or wasting money on BMW's end. Someone had to make that decision to go change how it functions.
10-29-2017, 04:55 PM | #36 | |
Rep 97
On a side note there is another issue I am having now. Every time I start the car now it wants to confirm the profile I am using. This never use to happen. Maybe part of a different update they did or same one? |
10-29-2017, 05:57 PM | #37 | |
Rep 521
10-29-2017, 06:26 PM | #38 | |
Rep 1,170
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
10-31-2017, 09:23 AM | #39 |
Rep 97
So just an update...I have an appointment scheduled for Wed next week to have them look at this change in Rev Matching. The other thing I have noticed now that I have had the car back for a while is that I no longer can access Traffic Info (this has worked perfectly fine before I dropped it off). It isn't even sporadic...just has not worked once since having my car back. I will bring that up to them when the car is dropped off as well. I will post an update if i have one late next week.
11-09-2017, 09:01 AM | #40 | |
Rep 97
Additionally, they did not fix my traffic info not working issue. They blamed the fact i have a USB stick plugged into the USB port for it not working. They will however have a genius sit with me when i pick it up so we will see if he can figure it out. This whole situation has really pissed me off and makes me not want to deal with BMW anymore. I will try to escalate the Rev Matching issue to BMW if only to exhaust any options i may have even though I know i have little shot to change anything. |
11-09-2017, 06:38 PM | #41 |
Rep 521
My dealer has had no replies to the PUMA case in about a month, so I'm trying to go through social media channels to get a reply.. I may get the same answer though.
11-09-2017, 08:11 PM | #42 |
Rep 97
I really want to press BMW on why they would change this. Let me know if you want me to pile on the comments...long shot but maybe if we get enough people asking we can get an answer.
11-10-2017, 09:47 AM | #43 | ||
Rep 201
11-11-2017, 07:27 AM | #44 |
Rep 245
I have a '17 M240i however I can confirm I have the same issue. Before service I could dowshift and skip gears with it rev matching but instantly after getting an update I noticed I no longer can. It's annoying either having to go down each gear until I get where I want or having to manually rev match since I never had to do it since I've owned this car. If you figure out a way to get BMW to downgrade I would be all in!
