11-19-2015, 08:42 AM | #1 |
Rep 369
Coding help
I bought a cable and it arrived today, iv downloaded the software from BMWesys and although the vin is showing up I don't seem to be able to get the connect button to light up?
Iv downloaded the token as well. Iv also tried to download the PSdZDATA from the same place but when it downloads it asks for me to select what program I want to open it with? Do I need the PDd file? |
11-19-2015, 08:49 AM | #2 |
Rep 3,089
Probably best to post in the DIY forums.
However, I assume you are using laptop? If so, have you turned off your wireless? If so, when you connect to the car, does your laptop show "Unrecognized network"? As for the PSdZData, it should be a .rar file. Did you use the link from shawnsheridan??
11-19-2015, 08:55 AM | #3 | |
Rep 369
Yes I'm using my laptop but I wasn't connected to a network, do I still need it switched off? No I downloaded it myself from BMWesys.com What does the PSdZDATA file do, should it just install itself or do I have to save it somewhere specific? |
11-19-2015, 09:06 AM | #4 |
Rep 3,089
I am going to PM you. It is the message I got from shawnsheridan that provides everything you need to get coding including instructions. Follow them exactly and you should have no problems.
11-19-2015, 09:13 AM | #5 | |
Rep 369
11-19-2015, 12:06 PM | #6 | |
Rep 1,668
thanks in advance.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
11-19-2015, 12:34 PM | #7 |
Rep 369
Tbooe
Thanks iv got the message and I'm currently trying to get it downloaded but when the first link downloads it asks me to run or save so when I press run it asks me again what file I want to open it? |
11-19-2015, 12:59 PM | #8 |
Rep 3,089
Weird, you should be getting option to only save it. You will then need to unpack it because the file is a compressed file. What browser are you using to download from? I am using Chrome.
11-19-2015, 01:05 PM | #9 | |
Rep 369
11-19-2015, 01:07 PM | #10 | |
Rep 3,089
11-19-2015, 01:23 PM | #11 | ||
Rep 369
Everything's downloaded so I'll go out to the car and try and do some shizzle Get ready for the "Iv messed everything up and now my car won't start" thread |
11-19-2015, 02:41 PM | #13 |
Rep 369
Still not working!!! It's still not showing any options for the "series" :
Iv checked all the PSdZDATA files and followed the guild and everything is done properly but it's still not there |
11-20-2015, 08:37 AM | #15 | |
Rep 369
I deleted the PSdZDATA file and re extracted it and now I can get into the ECU's, I followed the cheat sheet on here to enable the ASS (thought I'd start small) but then I went for a quick drive and it hasn't worked? After I changed the code I just shut the system down and it asked me if I wanted to save something that I'd changed so I clicked yes? Any ideas what I might be doing wrong? |
11-20-2015, 08:39 AM | #16 |
Rep 3,089
Glad to hear you are connected at least.
Did you follow the directions after you made the code changes to actually code the FDL to your car?? You need to follow the instructions on pages 2-13 of the pdf "E-sys Getting Started Coding v2" which is included with the links I sent.
11-20-2015, 10:30 AM | #17 |
Rep 369
I have now!! Sorry missed that part,
It's helped a lot and I've got a couple of things to work, digital speedo/m idrive start up/m performance logo I can't get the ASS to stop though and I can't get video in motion to work, I don't seem to have the file "video speed lock condition" iv deactivated the other two and now it will still play with the handbrake off and in drive but as soon as I move it cuts out. |
11-20-2015, 10:37 AM | #18 | |
Rep 3,089
For video in motion did you edit the following: HU_NBT/ 3000 / SPEEDLOCK_X_KMH_MAX werte from 00 to FF HU_NBT/ 3000 / SPEEDLOCK_X_KMH_MIN werte from 00 to FF HU_NBT / 3000 / VIDEO_HANDBRAKE from aktiv to nicht_aktiv HU_NBT / 3000 / VIDEO_SPEEDLOCK_CONDITION from handbrake_or_gearbox_p to none For ASS, by default my car came with the coding to remember my last ASS setting. So in your car, it always defaults to ASS being on? Did you code these: FEM_BODY 3023 TCM_MSA_MEMORY
11-20-2015, 11:06 AM | #19 |
Rep 369
No I didn't code those I didn't know they were part of it, I will try again.
Regards the ASS yes I changed that function and now it's at least remembering my last setting which will do for now tbh Thanks for all your help and patience |
11-20-2015, 11:29 AM | #21 |
Rep 3,089
It depends on what you want to do. I have only coded the remember last setting. This way if I want it on its on, and if i want it off its off. I wont have to continually turn it on or off.
11-20-2015, 11:56 AM | #22 | |
Rep 369
