03-18-2017, 07:47 PM | #1 |
Rep 63
Any N20 Performance radiators?
The difference between the 328 and 320 engine is the water pump and pistons. My assumption is the these two items allow the 328 to take more abuse then the 320. Performance radiators normally allow for the cars to reduce engine temps by 10% - 20% and was thinking of adding one if my local dealership would allow it, but does anyone make a performance radiator for the 320 or 328? I have gone to Bimmerworld, Turner, ECS, Active Autowerke and searching the interweb with no success, does any know of a performance radiator for the N20 engine currently on the market or will I have to have a custom unit made?
03-18-2017, 09:34 PM | #2 |
Rep 15,966
Where high speed use is concerned there tends to be less need for a high capacity radiator, because the increased air flow keeps the temperature down.
03-21-2017, 03:30 PM | #5 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I used to use RedLine WaterWetter (coolant additive) to the coolant mix. Was a proven product..but not sure if it'll work on a BMW and/or turbo car.
If it's just the waterpump, why couldn't you put the 328 pump on if the radiators are the same? Wouldn't that help (a bit, maybe?)
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-12-2020, 10:18 AM | #6 | |
Rep 19
2014 BMW 328i xDrive
Setup: 255/35/19 35ET (Replika R163A; Ironman iMove Gen2 AS); BM3 (Stage 2, ACN91 Oct & 8AT Trans); AWE Touring Edition Exhaust; Bilstein B14 PSS Coilovers; Power Stop Z23 Brakes; 4.5" VRSF CD; VRSF 6.5" HD Competition FMIC; NGK LISP; MST Turbo Inlet Pipe; FTP Chargepipe; Injen Air Intake; CSF HP Radiator; Ultra Racing Front Strut Brace |
07-14-2020, 10:19 AM | #8 |
Rep 63
I have a CSF radiator in the garage waiting to be install one weekend. I also have upgraded oil cooler with an improved performance thermal switch set for 185 degrees sitting next the CSF radiator.
2015 320i
2006 330i 2004 545i 2001 M Roadster |
sspade2460.00 |
07-14-2020, 10:57 AM | #9 | |
Rep 5,451
Drives: F30
Would be huge for us N20 guys, haven't heard of anyone upgrading the cooling system like this. Do you track the car at all? |
07-15-2020, 07:11 AM | #10 | ||
Rep 63
2015 320i
