02-09-2014, 11:00 AM | #1 |
Rep 260
Lane Departure Warning / Speed Limit Info
Hi all,
I have been doing some research around lane departure warning. All indications are that the LDW, uses the same camera as the Speed Limit info. The questions I have: 1. Does anyone know if the above is in fact the truth 2. If yes could one enable LDW via coding (I see references to it everywhere in the FDL's) 3. When I was test driving a car with SLI, I noticed it reconized not only speed limit info but also indicated certain road signs in this case it showed the speed limit and above it, it showed: Do we know what signs the SLI system can show and / or is it codeable? |
02-09-2014, 06:30 PM | #3 |
Rep 40,650
I am pretty sure LDW uses KAFAS camera, as does SLI and HBA, unless you have only HBA in which case you get the cheaper FLA Only Camera.
I think if you have KAFAS Camera and factory SLI, LDW should be codeable. However, if one has KAFAS Camera and factory LDW, SLI can be coded, but it can't be enabled without a 7E FSC Enabling Code issues by BMW AG.
02-10-2014, 06:23 AM | #4 | |
Rep 260
Looks like this: I know for LDW it vibrates the steering wheel, and has lights on the side mirrors. But I also I know that you get a message on the Kombi and on the HUD. @shawnsheridan you want to give it a go with me see if we can get it working ? I am sure I can get a FSC code for it |
02-10-2014, 06:31 AM | #5 | |
Rep 260
Wonder if we can go the other way |
02-10-2014, 06:55 AM | #6 | |
Rep 260
Ok what do you need from me so I can show you all th eoptions |
02-10-2014, 07:14 AM | #7 |
Rep 260
here is my option list (minus some paint and trim things )
[1163] 8TH_SPEED_LIMIT_INFO [1195] 6WA_INSTRUMENT_CLUSTER_WITH_EXT_CONTENTS [7] 216_SERVOTRONIC [17] 302_ALARM_SYSTEM [28] 3AG_REAR_VIEW_CAMERA [30] 403_GLASS_ROOF_ELECTR [34] 423_FLOOR_MATS_VELOUR [35] 428_WARNING_TRIANGLE [37] 431_INTERIOR_REAR_VIEW_MIRROR_ANTI_DAZZLE [38] 441_SMOKERS_PACKAGE [51] 481_SPORT_SEATS_DRIVER_FRONT_PASSENGER [53] 493_STORAGE_COMPARTMENT_PACKAGE [59] 502_HEADLIGHT_WASHER_SYSTEM [60] 508_PARKDISTANCECONTROL [61] 520_FOG_LIGHTS [62] 521_RAIN_SENSOR [63] 522_XENON_LIGHT [65] 524_ADAPTIVE_HEADLIGHTS [66] 534_AUTOM_AIR_CONDITION [69] 544_CRUISE_CONTROL_BRAKING_FUNCT [72] 5AC_HIGH_BEAM_ASSISTANT [79] 609_NAVIGATION_SYSTEM_PROFESSIONAL [80] 610_HEAD_UP_DISPLAY [103] 698_DVD_CODE_2_ECE_ME_SA_JP [113] 775_HEADLINER_ANTHRACITE [125] 823_HOT_CLIMATE_VERSION [133] 8SD_SUMP_GUARD_COUNTRIES [134] 8SM_VIN_VISIBLE_FROM_OUTSIDE [191] 337_M_SPORTS_PACKAGE [196] 710_M_LEATHER_STEERING_WHEEL [203] 861_MODIFICATION_CODING_DATASET [303] 704_M_SPORTS_SUSPENSION [558] 249_MULTIFUNCTION_F0R_STEERING_WHEEL [612] 614_PREPARATION_INTERNET [615] 715_M_AERODYNAMICS_PACKAGE [1101] 8TG_ANTI_THEFT_SYSTEM [1163] 8TH_SPEED_LIMIT_INFO [1195] 6WA_INSTRUMENT_CLUSTER_WITH_EXT_CONTENTS [1305] 4MR_INT_TR_FIN_ALU_HEXAGON [1318] 2NH_M_SPORT_BRAKE [1350] 8TN_DAYTIME_LIGHTS_ABOUT_LIGHTMENU_ADJUSTABLE [1411] 6NR_BMW_APPS [1470] 688_HARMAN_KARDON_SURROUND_SYSTEM [1777] 6AL_BMW_LIVE [2096] 6NS_COMFORTTELEPHONY_WITH_EXT_SMARTPHONE |
02-10-2014, 09:00 AM | #9 | |
Rep 67
2014 335xi | Luxury | Technology | Imperial Blue Metallic | Saddle Brown Dakota | Driver Assist Plus | Cold Weather | Active Cruise Control | Harman Kardon
02-10-2014, 09:10 AM | #10 |
Rep 260
In my country we do use those signs, I see its off on my car maybe using the USA setting do you know where it is?
02-10-2014, 09:19 AM | #11 | |
Rep 67
02-10-2014, 09:54 AM | #12 |
Rep 260
02-10-2014, 09:56 AM | #13 |
Rep 67
Yes, I have LDW.
02-10-2014, 10:07 AM | #14 |
Rep 260
I have seen some forum postings of people trying to turn on SLI when they have LDW and other Driver assists, apparently they work on the same cameras.
Now I have SLI and High Beam assist (Two cameras). I am wondering if I could turn on LDW... I notice you have KAFAS2 - I have the same module.. |
02-10-2014, 10:17 AM | #15 | |
Rep 67
LDW uses the cameras in the side mirrors (see post #2), not sure what they are called or what module controls them. SLI and HBA cameras are in the windshield, so I don't think having SLI and HBA implies that you can get LDW. Edit: Post #3 says LDW is on KAFAS, and shawnsheridan tends to know about these things.... Edit: see http://www.bmw.com/com/en/insights/t...e_warning.html "Lane Departure Warning is a driver assistance system that is based on a video sensor. A camera integrated near the rear-view mirror takes an image of the 50 m of road ahead of your BMW during the day or within the headlight beam at night."
02-10-2014, 11:06 AM | #16 | |
Rep 260
From what I have read LDW is based on the cameras in the windscreen. Since I have both that's why I was wondering if I could get it working. The guys over at F10 forum tried to do the things the other way round they had LDW and tried enabling SLI since they use the same /similar cameras (depending on what settings / options you have as per Shauns post). |
stuiver0.00 |
02-10-2014, 11:42 AM | #17 | |
Rep 67
02-10-2014, 12:16 PM | #18 |
Rep 260
Thanks for the help so far. If you don't mind could you send me your file so I can compare?
02-10-2014, 12:36 PM | #19 |
Rep 67
Sent.
02-10-2014, 02:16 PM | #21 | |||
Rep 40,650
If one has KAFAS ECU, it should be capable of being coded to do SLI, LDW, and or HBA; however, SLI also requires a 7E FSC Enabling Code before it can work, and LDW will work, however it will not vibrate the steering wheel unless the Vibrator is retrofitted in the Steering Wheel. The Triangles on the Side Mirrors are for 5AG Active Blind Spot Detection and have nothing to do with LDW. You have KAFAS ECU which is one single ECU that is capable of SLI, LDW, and HBA. It may have multiple cameras or lenses, but it is a single ECU. To add LDW, you do not need an FSC Code. The FSC Code is needed for SLI only. You should be able to add 5AD to your VO and VO Code Kombi and KAFAS for LDW to work (without vibration of course).
02-10-2014, 11:45 PM | #22 | |
Rep 260
