04-12-2015, 12:14 AM | #89 |
Rep 28
Drives: Estoril Blue 2014 335i xdrive
hey, my M235i was built 11/13!
2014 Estoril 335i xdrive 6sp: M Sport, m perf power/brakes/sound kit, AA8 400 hp/ 420 ft-lbs. 10/15mm spacers. Dinan 3/4" spring kit, Misc coding. Mud flaps.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor. |
04-12-2015, 12:16 AM | #90 | |
Rep 123
Given the massive failure of the N54 fuel pumps and turbo wastegates getting stuck requiring twin turbo replacements this is just another reason to be prepared to pony up big bucks in long-term ownership costs buying a BMW. |
04-12-2015, 12:19 AM | #91 | ||
Rep 70
04-12-2015, 12:25 AM | #92 |
Rep 261
Does the recall affect out of warranty vehicles differently than under warranty vehicles? I just crossed 50k and I'm in the production date range of affected vehicles.
2014 BMW F30 328i - Base line 8AT, Alpine White, metallic black roof, Megan Racing CF decklid, CF canards, CF eyelids, CF rear diffuser, matte black kidney grills, gunsmoke tail lights/reflectors, VMR 721 Hyper Silver 19x9.5/19.x8.5, 5mm spacers all around, Bilstein B8s, Injen CAI, H&R Sport Springs, muffler-deleted quad pipe, 20% 3M rear tint, M Performance Pedals
04-12-2015, 12:33 AM | #93 |
Rep 238
Drives: 2009 BMW 335i
Why is everyone going on about this in the E Series? Completely different fault. Just happens to be the same pump. Different failure mechanism tho
04-12-2015, 12:36 AM | #94 | |
Rep 1,135
So perhaps those early production cars were eventually turned into loaners or sold as CPO executive specials and are out in the wild, still need to be recalled and corrected. |
04-12-2015, 12:51 AM | #95 | |||
Rep 805
Drives: BMW 335i
I started to feel that every turbo engine from BMW will have this problem!
The Best Is Yet To Come!
E36 - E39 - E53 - E60 - E87 - E90 |
04-12-2015, 02:20 AM | #96 |
Rep 175
04-12-2015, 02:22 AM | #97 | |
Rep 175
Warranty has nothing to do with recalls. Safety is the issue so BMW wants to have all its cars corrected. |
04-12-2015, 08:09 AM | #98 | |
Rep 1,998
X1, R58 JCW, M2 in my future if planets align
04-12-2015, 09:19 AM | #99 | |
Rep 10,185
High pressure pump has no impeller, so its the low pressure pump. Pump is also only a piece of the part you see in the pic as that includes the one fuel level sensor. They will most probably only replace the pump and filter. Quick easy job. Most will probably be done at their next service as with many other easy recalls.
BMW if you are reading, I need a job, Please. |
04-12-2015, 09:53 AM | #100 |
Rep 513
When will this actually start showing up in local dealers systems? Mine failed, car cranks but won't turn over, but the dealer's system doesn't show any recalls pending for my car.
04-12-2015, 10:24 AM | #101 | |
Rep 10,185
Dealer can just submit a PUMA case for your car that has problems and get the same work done before the recall becomes effective, if its the same problem and the car is under warranty .
04-12-2015, 10:36 AM | #102 | ||
Rep 2,049
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
04-12-2015, 10:42 AM | #103 | |||
Rep 2,049
'10 e92 N54
04-12-2015, 11:18 AM | #105 |
Rep 10,185
The diesels had more than their fare share of major problems over the years
04-12-2015, 11:23 AM | #106 | |
Rep 3,071
Nickel plating is used to avoid wear due to cavitation / various fuel blends E0-E100 / and slower spinning pumps due to ERFS. (Electronic returnless fuel systems - PWM for fuel pumps) Sounds like a process issue to me. No worries - Bosch/AFCO know what they are doing is probably already fixed. |
04-12-2015, 04:38 PM | #108 |
Rep 1,268
Hmmm this sounds familiar.... at least this time they seem to have figured out the root of the issue from the get go.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
04-12-2015, 06:40 PM | #109 |
Rep 1,061
It would be nearly impossible for BMW, on incoming inspection, to tell if the nickel plating was to spec or not. It could be as simple as a contaminated cleaning solution prior to plating, or the temperature being off a little, or the concentration of the materials or the timer, and many other numerous factors.
IOW, only by long-term endurance testing would this show up AFTER it was built unless you were sitting in the plant where it was built and monitoring every detail carefully. Part of that process is to take an occasional part and run it through endurance testing, but results, obviously, take awhile. Bosch (based on what was said) discovered this during their (probably required, certainly prudent) testing of their delivered products. The design works, but when not manufactured properly, it may have premature failure. There are many thousands of parts in the car, and while BMW assembles it and is responsible for the entirety, they rely (as does every manufacturer) on their suppliers holding up their end. Few manufacturers, if any, can afford to design and build all parts used in their cars. Things have moved a long ways from the vertical conglomerate that was pioneered by Ford, where they started with raw materials and made essentially everything in the ModelT. The current BMW is a long ways from that, and it's a good thing, too. SOme things can be detected on incoming inspection, some can't...this one couldn't be. It's being resolved. Calm down... |
04-12-2015, 09:09 PM | #110 |
Rep 906
Sigh...
I wish Bosch would step up to the plate for the HPFP on the VW TDIs.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
