05-13-2015, 10:02 AM | #23 |
Rep 577
Ive also heard and read that the 8AT is being used in the 335 and other autotrans cars, so it should be good for way more than 350lbft.
05-13-2015, 10:08 AM | #24 |
Rep 134
He also has the Sports transmission which shifts differently than non , although same trans it just coded to shift differently
2018 440i M Sport 2013 328i M-Sport sold 2003 745li sold 2000 528i sold |
05-13-2015, 11:07 AM | #25 |
Rep 383
Drives: F13 M6 | E92 M3 | '15 Mustang
Copy that. For some reason I thought it was x-drive. We've also confirmed with the guys we are working with over in Indonesia that they are experiencing the same thing across all N20 based cars. As torque moves well into the 300 wtq range it's happening which seems to be when people are getting that little extra umf with the addition of a downpipe. The 228i we are going to be testing out here in the next week or so is a stage 2 auto car so we will see what we find. If we don't run into the issue we can just keep adding octane to bump up the numbers and see at what torque levels it starts to trigger the torque limit.
05-13-2015, 11:17 AM | #26 | |
Rep 383
Nick... |
05-13-2015, 11:21 AM | #27 |
Rep 383
If we can replicate it our here on a car that we have direct access to we might be able to answer that question. If we can find the binary that controls that torque limit and raise it we might be able eliminate the problem all together - it happening and it logging anything.
05-13-2015, 11:21 AM | #28 | |
Rep 1,490
And for proof here it is: http://en.wikipedia.org/wiki/ZF_8HP_...F_8HP_variants 450 N*m = 331 ft lb.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I Last edited by bahasad; 05-13-2015 at 11:26 AM.. |
05-13-2015, 11:26 AM | #29 | ||
Rep 586
I'll give you a call, thanks
G05 - M Performance roof spoiler
05-13-2015, 11:28 AM | #30 | |
Rep 134
05-13-2015, 11:41 AM | #31 | |
Rep 1,490
Either way, it is rated to 331 FT-LBs for the 3-series, 1-series, and chrysler products. The 328 with all these bolt ons will easily surpass that, therefore causing potential issues/failures. There is a reason why BMW put the safety-factor in the calibration for the Trans. I'm not even going to argue the fact that the con-rods for the 328 motor and are only built to about 331 HP. Tuning is great and all, and I highly support GSRs work. I'm just saying this tune is exceeding the limits of the Powertrain. Just my 0.02cents.
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
05-13-2015, 11:56 AM | #32 | |
Rep 383
05-13-2015, 12:00 PM | #33 | |
Rep 1,490
05-13-2015, 03:25 PM | #34 | ||
Rep 577
In my experience automotive parts like this will have a 1.5 to 2 and higher safety factor built into the design. So it's probably failure tested to 700+ Nm or over 500lbft. I would be very comfortable running my trans at 500Nm - 368lbft (10% more). If you can figure this out Im in. |
05-20-2015, 11:03 PM | #35 | |
Rep 577
05-20-2015, 11:21 PM | #36 | |
Rep 383
We put a more aggressive tune in the 28 AT Stage 1 test car with a few additional changes to see if we can get it to the torque limit but nothing yet - running normal. We need to get it back on the dyno and see what kind of torque it is making as we didn't dyno it before we sent in back into the wild. Nick... |
05-28-2015, 04:43 PM | #38 |
Rep 383
06-22-2015, 10:05 PM | #39 |
IG @bmwF9xG80
3812
Rep 7,593
goon any updates
60-130mph 6.5s X4M #HCP
06-23-2015, 07:51 AM | #40 |
Rep 265
Drives: 2014 328i AW
You would have to ask GSR Autosport I flashed back to stock and went with an afe scorcher module. It does not compare to the ecu tune, but I feel better and safer these days.
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
06-26-2015, 01:14 AM | #41 |
Rep 577
Guys, I'm starting to wonder if there is an interaction between the tune and downpipe that may be causing the hesitation/misfire issue. That seems to be the common theme with the cars that experienced this.
I don't even think it is the 93 octane. I have stage 1 with DP cel delete, and I'm also getting the occasional stutter. An easy to replicate stutter is going 60mph up hill (so under mid to heavy load), in 6th gear (8AT) - 2500rpm and firm acceleration. Almost always stutters around 2800rpm. Once passed 3000rpm it doesn't come back and goes smoothly to redline. |
06-26-2015, 02:33 AM | #42 |
Rep 4,311
i put a down payment for a stage 1 gsr tune however (stubok) your misfire issue is a bit disconcerting. hope more people with gsr stage 1 chime in.
06-27-2015, 11:53 AM | #43 | |
Rep 577
In addition, I may have a boost leak, which if so is more than likely contributing to the stuttering. I never got it with the piggyback, so I'm assuming it's a result of the flash. Wrinkles that will be resolved I'm sure. |
07-02-2015, 02:17 PM | #44 |
IG @bmwF9xG80
3812
Rep 7,593
Stubok Seen a lot of issues with DP + Aggressive tunes on N20/N26.
