06-02-2015, 03:16 PM | #8736 |
Rep 40,763
PM sent.
06-04-2015, 06:09 AM | #8737 |
Rep 1
Afternoon all,
Is there anybody or anywhere in the north west (uk) who would be willing to replace 6nh for 6ns for me on f30. I believe this is what I need to add the additional bluetooth and office functions to idrive. Obviously I'm happy to cough up a few quid. |
06-04-2015, 05:55 PM | #8738 |
Rep 40,763
PM sent.
06-04-2015, 06:37 PM | #8739 |
Rep 1,130
Drives: '16 340i AW MSport
Shawn,
I emailed tokenmaster 4-5 days ago for the PRO or whatever paid version and no response, any better way to reach him? *EDIT: Nvm, emailed him again after this post and got his auto-reply. He's traveling as of June 2nd, limited email access. Thanks! |
06-06-2015, 09:24 AM | #8740 |
Rep 1,035
When you do a Detect CAF for SWE to generate a new CAFD, then select your I-Step from the dialog (first pic), doesn't E-Sys honor that request and use that I-Step? After selecting my I-Step (F020_13_7_506), i took a screenshot of E-SYS immediately afterwards and it shows an earlier I-Step (F020-14-11-502).
Some questions: - Does E-Sys try to honor your requested I-Step then revert back to something else if it detects that another I-Step is "more correct" - Or am i just reading E-Sys wrong in the screenshot? To provide some context, i replaced my original (newer) REM for an older REM that has PDC rear sensor support and was generating a new CAF for it. |
06-06-2015, 10:53 AM | #8741 | |
Rep 40,763
This has nothing to do with the CAFD being injected into ECU via Detect CAF for SWE.
06-06-2015, 05:48 PM | #8742 | |
Rep 1,035
I'm pretty sure that i messed up something when inserting hardware pins/wiring into the REM when i went to do my PDC sensor retrofit, and i just want to reverse/back out everything to factory equipment just to get to an error-free and clean slate before i plan my next move. I went back to my old REM (one that does not have the pins to support rear PDC sensors) and sure enough Rheingold no longer detects PDC sensor issues, and the Parking Assistance error on the dash has also gone away. So far so good. But when i try to generate/code a new CAFD for the original REM by doing a Detect CAF For SWE, why do i still get the old error? The new default CAFD file generates fine after specifying my I-step, however, when i go do the Code of the REM ECU, I still get this error: Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. [] use default timing parameters as an exception occured [] - [Exception - REM_72_ETHERNET] openECUConnection for link REM_72_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name REM_72_ETHERNET doesn't map to an item ExecutionID=2015/06/04-19:22:26.855 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [REM - 72] There was an error during TAL execution, please check the log files. [REM - 72] - [Exception - REM_72_ETHERNET] openECUConnection for link REM_72_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name REM_72_ETHERNET doesn't map to an item [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "6s". [C206] Abarbeitung beendet Now that my original REM is back in place, the PDC sensor wiring faults have gone away (confirmed in Rheingold) and the dash error has also gone away. So why does E-Sys still detect an error? Its like E-Sys is not reading the current REM ECU and reading some old state from someplace else. How would i clear out this old error in E-Sys and start with a fresh REM CAFD? |
06-06-2015, 06:47 PM | #8743 | |
Rep 40,763
"REM_72_ETHERNET doesn't map to an item" Are you using E-Sys Launcher, and is it set for Car Series = F30?
06-07-2015, 06:07 PM | #8744 |
Rep 100
Hello, I want to turn my package bmw f21 lighting, lighting package S563A code, someone can tell me how can I activate it?
I also want to activate kit reequipacion alpine 6 channels for the same car. Activate photosensitive same car mirror. I have active sports watches but they only make 160hp, I can raise these cv to dial more? Thanks greetings! |
06-07-2015, 06:51 PM | #8745 | |
Rep 817
Drives: bmw M3 F80
hi Here is the manipulation for HiFi Alpine http://f30.bimmerpost.com/forums/sho...d.php?t=982910 |
06-08-2015, 02:16 AM | #8746 |
Rep 100
Thanks! one less thing.
Anyone know how to code F21 BMW lighting package? And photosensitive interior mirror? I have active sports watches but they only make 160hp, I can raise these cv to dial more? Thanks ! |
06-10-2015, 04:27 AM | #8747 |
Rep 50
Hi.
Some time ago I was coding my F30 and changed languages in CIC/KOMBI. I wanted polish language so I changed MASTER LANGUAGE => UK (was US) added LANGUAGE_4 => polish. After this coding I lost interactive manual in CIC. 1. is there a way to add polish interactive manual in CIC ? 2. eventually how to activate English manual in CIC dispite that language is set to polish ? 3. also how to activate English voice control ? Last edited by __mkw; 06-10-2015 at 04:40 AM.. |
06-11-2015, 12:12 AM | #8748 |
Rep 1
Hello & greetings from AUSTRIA. Can I get the link to the E-Sys program & datafiles as well? Thanks, Mario!
berzlchef@gmx.net |
06-11-2015, 11:17 AM | #8749 | |
Rep 40,763
06-11-2015, 03:14 PM | #8751 |
Rep 40,763
PM sent.
06-12-2015, 02:55 AM | #8753 |
Rep 40,763
PM sent.
06-12-2015, 12:23 PM | #8755 |
Rep 40,763
No. RPM in HUD only possible in ///M Car.
06-12-2015, 10:44 PM | #8756 |
Rep 2
