BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Brakes Upgrade to M Brakes, Covered under maint. plan?
proTUNING Freaks
      08-23-2014, 05:02 PM   #1
spitcool
Drives: 2014 BMW 335i M-Sport
i have a 2014 335i msport and want to put the m performance brakes on it.
since i have the extended maintenance plan, when the pads/rotors run out, will they be covered under my existing maintenance plan? i checked the terms and it doesn't exclude upgraded parts per se, but i want to check if anyone has experience...
      09-24-2014, 08:25 AM   #2
hankcah
Drives: BMW 335i E90
2007 335i  [0.00]
When I was last in the dealer, They cover just about everything besides wear & tear items. So they don't cover tires, brakes, nor gas. Last one was a joke.
In the service PDF I was hoping to see something regarding Pads or Rotors, but it only said this: Brakes & ABS: Master cylinder; brake booster
assembly; wheel cylinders; brake calipers; hydraulic
lines and fittings; brake pedal assembly; parking
brake assembly. (ABS): hydraulic pump assembly;
ABS control module; wheel speed sensors; relays.
But it does depend on your SA, if you have a nice one, they can be very generous.
